The 5 & 6 cylinders have a Bosch ECM. The V8 has a Denso ECM. The 3.2 is a SI6 ( Short Inline 6 cylinder ) not a V6.T5Luke wrote: ↑12 Apr 2021, 13:49 I know this V8s from 2006 and newer respond to P3 protocol on HS bus. Can bus logging shows only short IDs instead of extended CAN IDs in P2. When you look to the screenshots on page 45, the V8 and the 3.2 V6 are listed together as seperate P28. But 3.2 V6 here is not to find. From my testing i know the latest P2 based XC90 2015 D5, 2.5T engines run on P2 protocol. But it is hard to get an complete overview.
Vida CEM swapping
- RickHaleParker
- Been thanked: 958 times
Re: Vida CEM swapping
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
Ok, in Europe nearly not to find, what does the 6 cylinder have?
The non turbos are normaly by Denso and the turbos are by Bosch also the turbo diesels.
Did you try the cracker on your S60 V8 build?
- RickHaleParker
Which 6 cylinder? ..... Year and model.
Yes and it fails. It is the 2011 P2 CEM below. Yagger has already bench cracked the CEM and has done some of the reprogramming with the CEM in the car. Still got a ways to go on the electrical and software.
Part number from logs: 2005 = 000030765643, 2011 = 000031394157. The Arduino code is calling this number ECU. This is a Volvo Part number for a P2-L CEM.
In general Automotive terminology ECU = Electronic Control Unit. In Volvo terminology ECU = Engine Control Unit same as ECM = Engine Control Module. Might be clearer if ECU where to be changed to CEM in the code.
Could the CEM part number could be use to automatically define the platform ( P1 or P2-H or P2-L ) in the setup.
Edited
CEM P1 Part numbers.
8690719 | 8690720 | 30728906 | 30765015 | 31254317 | 31327215 | 3125903 | 31254749
CEM P2 (Brick shaped 1999-2004 with K-line ) Part numbers.
8645716 | 8645719 | 8688434 | 8688436 | 8688513 | 30657629 | 9494336 | 9494594 | 8645171 | 9452553 | 8645205 | 9452596
CEM P2 CEM-L & CEM-H ( L shaped 2003? - 2014 ) Part numbers. ( May need to sort the H from the L versions )
30682981 | 30682982 | 30728357 | 30728539 | 30728542 | 30759114 | 30765148 | 30765149 | 30765643 | 30765646 | 30765646 | 30786475 | 30786476 | 30786889 | 30786890 | 30795115 | 31282455 | 31282457 | 31314468 | 31394157
End edit
Tried to crack a 2011 P2 today. All three candidates pins[0 - 2] are too close to call and the crack fails. The pin cracker works on a my 2005 P2. I attached the log files from both sessions. Can anybody extract any insight from them?
Code: Select all
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.04.12 17:00:20 =~=~=~=~=~=~=~=~=~=~=~=
2005 CEM-L
CPU Maximum Frequency: 600000000
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
Minimum CEM Reply Time: 30us
Platform: P2
PIN bytes to measure: 3
Number of samples: 30
Number of loops: 1000
CAN high-speed init done.
CAN low-speed init done.
Initialization done.
Putting all ECUs into programming mode.
---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50
---> ID=000ffffe data=50 88 00 00 00 00 00 00
<--- ID=00000003 data=50 8e 00 00 30 76 56 43
Part Number: 000030765643
Calculating bytes 0-2
1000 pins in 657 ms, 1522 pins/s, average response: 86
[ 00 -- -- -- -- -- ]: 000 000 000 013 166 097 1261 091 1235 010 127 000 000 000 000 : 260631
[ 01 -- -- -- -- -- ]: 000 000 000 012 182 099 1281 104 1173 014 135 000 000 000 000 : 260533
[ 02 -- -- -- -- -- ]: 000 000 000 016 157 124 1313 082 1148 009 151 000 000 000 000 : 260523
[ 03 -- -- -- -- -- ]: 000 000 000 015 165 104 1247 112 1208 011 138 000 000 000 000 : 260634
[ 04 -- -- -- -- -- ]: 000 000 000 012 163 097 1250 115 1196 016 151 000 000 000 000 : 260700
[ 05 -- -- -- -- -- ]: 000 000 000 012 163 115 1283 097 1170 013 147 000 000 000 000 : 260587
[ 06 -- -- -- -- -- ]: 000 000 000 015 162 106 1239 083 1243 014 138 000 000 000 000 : 260688
[ 07 -- -- -- -- -- ]: 000 000 000 020 145 113 1310 092 1159 012 149 000 000 000 000 : 260579
[ 08 -- -- -- -- -- ]: 000 000 000 014 149 109 1253 090 1228 014 143 000 000 000 000 : 260711
[ 09 -- -- -- -- -- ]: 000 000 000 015 149 102 1287 108 1163 015 161 000 000 000 000 : 260678
[ 10 -- -- -- -- -- ]: 000 000 000 014 173 126 1287 099 1144 007 150 000 000 000 000 : 260494
[ 11 -- -- -- -- -- ]: 000 000 000 016 156 114 1268 092 1187 017 150 000 000 000 000 : 260643
[ 12 -- -- -- -- -- ]: 000 000 000 008 159 116 1313 113 1127 011 153 000 000 000 000 : 260554
[ 13 -- -- -- -- -- ]: 000 000 000 019 170 086 1300 118 1165 011 131 000 000 000 000 : 260522
[ 14 -- -- -- -- -- ]: 000 000 000 015 165 116 1247 098 1200 007 152 000 000 000 000 : 260636
[ 15 -- -- -- -- -- ]: 000 000 000 011 133 091 1328 117 1146 014 160 000 000 000 000 : 260701
[ 16 -- -- -- -- -- ]: 000 000 000 010 157 103 1310 095 1165 015 145 000 000 000 000 : 260603
[ 17 -- -- -- -- -- ]: 000 000 000 014 135 094 1301 109 1177 009 161 000 000 000 000 : 260728
[ 18 -- -- -- -- -- ]: 000 000 000 011 165 108 1270 096 1194 007 149 000 000 000 000 : 260630
[ 19 -- -- -- -- -- ]: 000 000 000 021 128 098 1282 095 1220 017 139 000 000 000 000 : 260725
[ 20 -- -- -- -- -- ]: 000 000 000 022 191 097 1282 097 1129 011 171 000 000 000 000 : 260527
[ 21 -- -- -- -- -- ]: 000 000 000 021 142 097 1278 089 1198 012 163 000 000 000 000 : 260729
[ 22 -- -- -- -- -- ]: 000 000 000 008 138 094 1287 094 1207 013 159 000 000 000 000 : 260789
[ 23 -- -- -- -- -- ]: 000 000 000 021 130 094 1279 100 1203 014 159 000 000 000 000 : 260767
[ 24 -- -- -- -- -- ]: 000 000 000 011 150 104 1291 100 1183 014 147 000 000 000 000 : 260659
[ 25 -- -- -- -- -- ]: 000 000 000 021 142 093 1260 108 1211 007 158 000 000 000 000 : 260743
[ 26 -- -- -- -- -- ]: 000 000 000 009 153 104 1227 107 1231 012 157 000 000 000 000 : 260796
[ 27 -- -- -- -- -- ]: 000 000 000 016 131 097 1278 105 1194 016 163 000 000 000 000 : 260786
[ 28 -- -- -- -- -- ]: 000 000 000 013 170 116 1259 087 1179 019 157 000 000 000 000 : 260635
[ 29 -- -- -- -- -- ]: 000 000 000 012 141 109 1296 100 1191 007 144 000 000 000 000 : 260652
[ 30 -- -- -- -- -- ]: 000 000 000 016 180 114 1274 100 1150 012 154 000 000 000 000 : 260530
[ 31 -- -- -- -- -- ]: 000 000 000 011 158 106 1271 091 1203 016 144 000 000 000 000 : 260666
[ 32 -- -- -- -- -- ]: 000 000 000 014 172 111 1230 115 1182 014 162 000 000 000 000 : 260672
[ 33 -- -- -- -- -- ]: 000 000 000 016 136 094 1250 107 1224 017 156 000 000 000 000 : 260816
[ 34 -- -- -- -- -- ]: 000 000 000 011 154 095 1305 103 1174 014 144 000 000 000 000 : 260633
[ 35 -- -- -- -- -- ]: 000 000 000 017 134 105 1326 104 1139 017 158 000 000 000 000 : 260641
[ 36 -- -- -- -- -- ]: 000 000 000 013 150 113 1277 079 1205 011 152 000 000 000 000 : 260678
[ 37 -- -- -- -- -- ]: 000 000 000 011 150 127 1281 095 1173 009 154 000 000 000 000 : 260624
[ 38 -- -- -- -- -- ]: 000 000 000 010 176 112 1264 092 1169 011 166 000 000 000 000 : 260633
[ 39 -- -- -- -- -- ]: 000 000 000 012 142 104 1265 121 1203 007 146 000 000 000 000 : 260708
[ 40 -- -- -- -- -- ]: 000 000 000 014 166 098 1258 111 1208 010 135 000 000 000 000 : 260625
[ 41 -- -- -- -- -- ]: 000 000 000 014 185 110 1260 115 1172 011 133 000 000 000 000 : 260502
[ 42 -- -- -- -- -- ]: 000 000 000 011 165 113 1243 113 1192 014 149 000 000 000 000 : 260659
[ 43 -- -- -- -- -- ]: 000 000 000 015 165 111 1240 102 1210 012 145 000 000 000 000 : 260652
[ 44 -- -- -- -- -- ]: 000 000 000 016 148 114 1296 102 1147 015 162 000 000 000 000 : 260631
[ 45 -- -- -- -- -- ]: 000 000 000 012 183 106 1231 090 1218 011 149 000 000 000 000 : 260647
[ 46 -- -- -- -- -- ]: 000 000 000 012 162 117 1272 103 1178 012 144 000 000 000 000 : 260594
[ 47 -- -- -- -- -- ]: 000 000 000 010 134 124 1309 099 1142 013 169 000 000 000 000 : 260676
[ 48 -- -- -- -- -- ]: 000 000 000 009 160 109 1226 104 1203 013 176 000 000 000 000 : 260797
[ 49 -- -- -- -- -- ]: 000 000 000 011 151 106 1246 099 1200 010 177 000 000 000 000 : 260796
[ 50 -- -- -- -- -- ]: 000 000 000 010 153 106 1270 114 1181 010 156 000 000 000 000 : 260688
[ 51 -- -- -- -- -- ]: 000 000 000 010 148 102 1240 101 1237 012 150 000 000 000 000 : 260783
[ 52 -- -- -- -- -- ]: 000 000 000 012 165 088 1229 113 1217 014 162 000 000 000 000 : 260783
[ 53 -- -- -- -- -- ]: 000 000 000 016 139 097 1229 107 1241 017 154 000 000 000 000 : 260833
[ 54 -- -- -- -- -- ]: 000 000 000 009 177 099 1196 097 1233 012 177 000 000 000 000 : 260827
[ 55 -- -- -- -- -- ]: 000 000 000 020 184 093 1267 119 1158 012 147 000 000 000 000 : 260538
[ 56 -- -- -- -- -- ]: 000 000 000 014 168 124 1244 099 1188 010 153 000 000 000 000 : 260615
[ 57 -- -- -- -- -- ]: 000 000 000 017 161 089 1248 118 1192 012 163 000 000 000 000 : 260728
[ 58 -- -- -- -- -- ]: 000 000 000 008 156 118 1306 083 1171 012 146 000 000 000 000 : 260591
[ 59 -- -- -- -- -- ]: 000 000 000 014 161 105 1258 112 1171 019 160 000 000 000 000 : 260682
[ 60 -- -- -- -- -- ]: 000 000 000 008 174 095 1254 115 1199 014 141 000 000 000 000 : 260652
[ 61 -- -- -- -- -- ]: 000 000 000 012 154 106 1251 092 1209 015 161 000 000 000 000 : 260749
[ 62 -- -- -- -- -- ]: 000 000 000 013 172 096 1222 104 1251 009 133 000 000 000 000 : 260686
[ 63 -- -- -- -- -- ]: 000 000 000 010 157 101 1269 103 1177 016 167 000 000 000 000 : 260728
[ 64 -- -- -- -- -- ]: 000 000 000 012 180 116 1238 099 1196 013 146 000 000 000 000 : 260602
[ 65 -- -- -- -- -- ]: 000 000 000 017 171 103 1221 097 1201 015 175 000 000 000 000 : 260748
[ 66 -- -- -- -- -- ]: 000 000 000 016 165 103 1210 098 1242 017 149 000 000 000 000 : 260748
[ 67 -- -- -- -- -- ]: 000 000 000 014 154 110 1261 103 1201 016 141 000 000 000 000 : 260657
[ 68 -- -- -- -- -- ]: 000 000 000 014 147 099 1235 118 1187 011 189 000 000 000 000 : 260846
[ 69 -- -- -- -- -- ]: 000 000 000 014 165 124 1217 101 1206 016 157 000 000 000 000 : 260693
[ 70 -- -- -- -- -- ]: 000 000 000 016 142 106 1299 119 1142 007 169 000 000 000 000 : 260662
[ 71 -- -- -- -- -- ]: 000 000 000 016 165 097 1252 101 1219 012 138 000 000 000 000 : 260652
[ 72 -- -- -- -- -- ]: 000 000 000 015 160 103 1240 097 1190 014 181 000 000 000 000 : 260775
[ 73 -- -- -- -- -- ]: 000 000 000 013 160 106 1245 086 1223 016 151 000 000 000 000 : 260719
[ 74 -- -- -- -- -- ]: 000 000 000 021 144 114 1229 089 1234 012 157 000 000 000 000 : 260756
[ 75 -- -- -- -- -- ]: 000 000 000 011 141 107 1309 110 1152 009 161 000 000 000 000 : 260663
[ 76 -- -- -- -- -- ]: 000 000 000 014 153 102 1215 089 1259 011 157 000 000 000 000 : 260818
[ 77 -- -- -- -- -- ]: 000 000 000 014 151 101 1223 116 1203 012 180 000 000 000 000 : 260833
[ 78 -- -- -- -- -- ]: 000 000 000 020 182 085 1199 099 1253 017 145 000 000 000 000 : 260727
[ 79 -- -- -- -- -- ]: 000 000 000 018 174 103 1247 095 1192 021 150 000 000 000 000 : 260637
[ 80 -- -- -- -- -- ]: 000 000 000 010 169 097 1298 096 1187 011 132 000 000 000 000 : 260566
[ 81 -- -- -- -- -- ]: 000 000 000 019 170 094 1253 115 1160 013 176 000 000 000 000 : 260687
[ 82 -- -- -- -- -- ]: 000 000 000 013 174 107 1273 108 1154 013 158 000 000 000 000 : 260593
[ 83 -- -- -- -- -- ]: 000 000 000 013 159 092 1274 101 1192 018 151 000 000 000 000 : 260694
[ 84 -- -- -- -- -- ]: 000 000 000 008 162 093 1267 113 1191 019 147 000 000 000 000 : 260699
[ 85 -- -- -- -- -- ]: 000 000 000 009 149 119 1211 093 1254 018 147 000 000 000 000 : 260799
[ 86 -- -- -- -- -- ]: 000 000 000 013 180 095 1273 116 1170 008 145 000 000 000 000 : 260566
[ 87 -- -- -- -- -- ]: 000 000 000 015 171 089 1208 124 1222 016 155 000 000 000 000 : 260760
[ 88 -- -- -- -- -- ]: 000 000 000 019 177 096 1191 103 1230 012 172 000 000 000 000 : 260780
[ 89 -- -- -- -- -- ]: 000 000 000 015 160 094 1279 106 1181 012 153 000 000 000 000 : 260657
[ 90 -- -- -- -- -- ]: 000 000 000 010 154 093 1263 105 1214 009 152 000 000 000 000 : 260737
[ 91 -- -- -- -- -- ]: 000 000 000 015 173 107 1201 108 1246 011 139 000 000 000 000 : 260691
[ 92 -- -- -- -- -- ]: 000 000 000 009 152 087 1278 110 1185 016 163 000 000 000 000 : 260762
[ 93 -- -- -- -- -- ]: 000 000 000 007 096 089 1199 113 1154 026 316 000 000 000 000 : 261461
[ 94 -- -- -- -- -- ]: 000 000 000 016 164 113 1228 100 1225 013 141 000 000 000 000 : 260664
[ 95 -- -- -- -- -- ]: 000 000 000 010 161 109 1233 110 1214 009 154 000 000 000 000 : 260720
[ 96 -- -- -- -- -- ]: 000 000 000 009 152 104 1267 109 1203 012 144 000 000 000 000 : 260692
[ 97 -- -- -- -- -- ]: 000 000 000 015 152 106 1263 100 1199 011 154 000 000 000 000 : 260692
[ 98 -- -- -- -- -- ]: 000 000 000 010 159 104 1233 096 1225 016 157 000 000 000 000 : 260770
[ 99 -- -- -- -- -- ]: 000 000 000 008 171 090 1226 104 1216 024 161 000 000 000 000 : 260796
0: 93 = 261461
1: 68 = 260846
2: 77 = 260833
3: 53 = 260833
4: 54 = 260827
5: 76 = 260818
6: 33 = 260816
7: 85 = 260799
8: 48 = 260797
9: 26 = 260796
10: 99 = 260796
11: 49 = 260796
12: 22 = 260789
13: 27 = 260786
14: 51 = 260783
15: 52 = 260783
16: 88 = 260780
17: 72 = 260775
18: 98 = 260770
19: 23 = 260767
20: 92 = 260762
21: 87 = 260760
22: 74 = 260756
23: 61 = 260749
24: 65 = 260748
pin[0] candidate: 93 with latency 261461
[ 93 00 -- -- -- -- ]: 000 000 000 006 091 091 1194 100 1172 034 312 000 000 000 000 : 261503
[ 93 01 -- -- -- -- ]: 000 000 000 005 088 109 1237 096 1140 032 293 000 000 000 000 : 261344
[ 93 02 -- -- -- -- ]: 000 000 000 005 078 098 1212 110 1165 033 299 000 000 000 000 : 261466
[ 93 03 -- -- -- -- ]: 000 000 000 004 085 102 1251 096 1137 025 300 000 000 000 000 : 261361
[ 93 04 -- -- -- -- ]: 000 000 000 006 092 097 1173 093 1213 027 299 000 000 000 000 : 261497
[ 93 05 -- -- -- -- ]: 000 000 000 010 086 102 1228 106 1130 021 317 000 000 000 000 : 261393
[ 93 06 -- -- -- -- ]: 000 000 000 006 090 096 1242 110 1120 021 315 000 000 000 000 : 261379
[ 93 07 -- -- -- -- ]: 000 000 000 006 098 095 1263 089 1110 025 314 000 000 000 000 : 261331
[ 93 08 -- -- -- -- ]: 000 000 000 009 093 118 1217 084 1191 022 266 000 000 000 000 : 261265
[ 93 09 -- -- -- -- ]: 000 000 000 007 099 103 1238 104 1151 022 276 000 000 000 000 : 261254
[ 93 10 -- -- -- -- ]: 000 000 000 003 112 111 1251 093 1136 024 270 000 000 000 000 : 261173
[ 93 11 -- -- -- -- ]: 000 000 000 005 114 107 1229 088 1129 033 295 000 000 000 000 : 261275
[ 93 12 -- -- -- -- ]: 000 000 000 005 105 114 1249 088 1142 027 270 000 000 000 000 : 261194
[ 93 13 -- -- -- -- ]: 000 000 000 009 094 093 1187 113 1199 032 273 000 000 000 000 : 261391
[ 93 14 -- -- -- -- ]: 000 000 000 009 108 094 1232 102 1155 025 275 000 000 000 000 : 261250
[ 93 15 -- -- -- -- ]: 000 000 000 002 109 100 1222 098 1147 032 290 000 000 000 000 : 261324
[ 93 16 -- -- -- -- ]: 000 000 000 009 100 098 1181 103 1154 033 322 000 000 000 000 : 261473
[ 93 17 -- -- -- -- ]: 000 000 000 010 094 098 1214 096 1160 028 300 000 000 000 000 : 261384
[ 93 18 -- -- -- -- ]: 000 000 000 008 095 104 1241 096 1140 019 297 000 000 000 000 : 261303
[ 93 19 -- -- -- -- ]: 000 000 000 011 081 095 1237 097 1176 026 277 000 000 000 000 : 261345
[ 93 20 -- -- -- -- ]: 000 000 000 006 101 093 1278 102 1090 025 305 000 000 000 000 : 261264
[ 93 21 -- -- -- -- ]: 000 000 000 003 108 098 1172 106 1168 032 313 000 000 000 000 : 261467
[ 93 22 -- -- -- -- ]: 000 000 000 008 116 092 1170 097 1195 026 296 000 000 000 000 : 261401
[ 93 23 -- -- -- -- ]: 000 000 000 009 093 107 1223 098 1137 018 315 000 000 000 000 : 261366
[ 93 24 -- -- -- -- ]: 000 000 000 007 108 111 1213 085 1161 023 292 000 000 000 000 : 261296
[ 93 25 -- -- -- -- ]: 000 000 000 008 103 090 1178 109 1182 026 304 000 000 000 000 : 261447
[ 93 26 -- -- -- -- ]: 000 000 000 008 087 086 1193 099 1161 037 329 000 000 000 000 : 261564
[ 93 27 -- -- -- -- ]: 000 000 000 009 099 102 1210 103 1157 031 289 000 000 000 000 : 261339
[ 93 28 -- -- -- -- ]: 000 000 000 007 089 091 1220 115 1129 025 324 000 000 000 000 : 261454
[ 93 29 -- -- -- -- ]: 000 000 000 006 113 107 1197 095 1145 028 309 000 000 000 000 : 261354
[ 93 30 -- -- -- -- ]: 000 000 000 008 091 088 1227 093 1156 030 307 000 000 000 000 : 261429
[ 93 31 -- -- -- -- ]: 000 000 000 011 098 103 1165 110 1173 024 316 000 000 000 000 : 261460
[ 93 32 -- -- -- -- ]: 000 000 000 008 098 098 1156 102 1184 026 328 000 000 000 000 : 261542
[ 93 33 -- -- -- -- ]: 000 000 000 013 077 118 1205 098 1155 029 305 000 000 000 000 : 261404
[ 93 34 -- -- -- -- ]: 000 000 000 014 093 105 1164 093 1216 029 286 000 000 000 000 : 261423
[ 93 35 -- -- -- -- ]: 000 000 000 005 114 109 1179 097 1176 028 292 000 000 000 000 : 261349
[ 93 36 -- -- -- -- ]: 000 000 000 011 094 113 1180 096 1176 021 309 000 000 000 000 : 261413
[ 93 37 -- -- -- -- ]: 000 000 000 008 090 085 1179 101 1175 028 334 000 000 000 000 : 261582
[ 93 38 -- -- -- -- ]: 000 000 000 009 072 105 1214 104 1164 019 313 000 000 000 000 : 261465
[ 93 39 -- -- -- -- ]: 000 000 000 009 096 120 1186 095 1158 021 315 000 000 000 000 : 261395
[ 93 40 -- -- -- -- ]: 000 000 000 010 101 123 1205 085 1143 028 305 000 000 000 000 : 261320
[ 93 41 -- -- -- -- ]: 000 000 000 010 080 093 1259 084 1120 041 313 000 000 000 000 : 261416
[ 93 42 -- -- -- -- ]: 000 000 000 009 090 094 1179 106 1163 030 329 000 000 000 000 : 261537
[ 93 43 -- -- -- -- ]: 000 000 000 000 000 099 1160 116 1204 026 395 000 000 000 000 : 262083
[ 93 44 -- -- -- -- ]: 000 000 000 008 109 087 1213 110 1145 029 299 000 000 000 000 : 261354
[ 93 45 -- -- -- -- ]: 000 000 000 016 097 102 1185 110 1150 019 321 000 000 000 000 : 261407
[ 93 46 -- -- -- -- ]: 000 000 000 006 103 103 1154 102 1164 024 344 000 000 000 000 : 261551
[ 93 47 -- -- -- -- ]: 000 000 000 008 104 100 1158 099 1167 027 337 000 000 000 000 : 261530
[ 93 48 -- -- -- -- ]: 000 000 000 010 101 112 1220 106 1131 027 293 000 000 000 000 : 261277
[ 93 49 -- -- -- -- ]: 000 000 000 011 101 115 1135 102 1201 030 305 000 000 000 000 : 261464
[ 93 50 -- -- -- -- ]: 000 000 000 007 093 113 1216 116 1143 027 285 000 000 000 000 : 261303
[ 93 51 -- -- -- -- ]: 000 000 000 009 104 098 1184 099 1135 029 342 000 000 000 000 : 261491
[ 93 52 -- -- -- -- ]: 000 000 000 008 080 089 1208 095 1180 029 311 000 000 000 000 : 261513
[ 93 53 -- -- -- -- ]: 000 000 000 009 096 089 1214 107 1135 022 328 000 000 000 000 : 261447
[ 93 54 -- -- -- -- ]: 000 000 000 006 079 108 1183 100 1193 022 309 000 000 000 000 : 261504
[ 93 55 -- -- -- -- ]: 000 000 000 011 092 091 1193 115 1145 022 331 000 000 000 000 : 261487
[ 93 56 -- -- -- -- ]: 000 000 000 009 091 101 1191 094 1158 036 320 000 000 000 000 : 261488
[ 93 57 -- -- -- -- ]: 000 000 000 005 098 094 1217 112 1106 027 341 000 000 000 000 : 261464
[ 93 58 -- -- -- -- ]: 000 000 000 015 091 095 1183 104 1179 028 305 000 000 000 000 : 261444
[ 93 59 -- -- -- -- ]: 000 000 000 006 091 104 1173 106 1187 024 309 000 000 000 000 : 261484
[ 93 60 -- -- -- -- ]: 000 000 000 011 088 112 1263 091 1110 031 294 000 000 000 000 : 261259
[ 93 61 -- -- -- -- ]: 000 000 000 009 095 101 1209 093 1144 033 316 000 000 000 000 : 261426
[ 93 62 -- -- -- -- ]: 000 000 000 005 116 093 1169 104 1157 026 330 000 000 000 000 : 261476
[ 93 63 -- -- -- -- ]: 000 000 000 006 107 086 1175 114 1157 030 325 000 000 000 000 : 261500
[ 93 64 -- -- -- -- ]: 000 000 000 002 088 116 1243 081 1145 040 285 000 000 000 000 : 261333
[ 93 65 -- -- -- -- ]: 000 000 000 013 105 093 1179 109 1145 030 326 000 000 000 000 : 261451
[ 93 66 -- -- -- -- ]: 000 000 000 003 091 100 1157 106 1175 025 343 000 000 000 000 : 261612
[ 93 67 -- -- -- -- ]: 000 000 000 008 098 101 1200 105 1126 024 338 000 000 000 000 : 261460
[ 93 68 -- -- -- -- ]: 000 000 000 007 098 102 1246 116 1114 030 287 000 000 000 000 : 261263
[ 93 69 -- -- -- -- ]: 000 000 000 011 099 092 1146 091 1190 035 336 000 000 000 000 : 261597
[ 93 70 -- -- -- -- ]: 000 000 000 006 087 116 1250 091 1148 030 272 000 000 000 000 : 261257
[ 93 71 -- -- -- -- ]: 000 000 000 011 086 096 1202 114 1144 018 329 000 000 000 000 : 261471
[ 93 72 -- -- -- -- ]: 000 000 000 005 094 091 1156 105 1161 028 360 000 000 000 000 : 261657
[ 93 73 -- -- -- -- ]: 000 000 000 011 094 097 1150 104 1181 034 329 000 000 000 000 : 261566
[ 93 74 -- -- -- -- ]: 000 000 000 011 082 115 1213 098 1155 031 295 000 000 000 000 : 261369
[ 93 75 -- -- -- -- ]: 000 000 000 007 082 101 1163 107 1174 031 335 000 000 000 000 : 261602
[ 93 76 -- -- -- -- ]: 000 000 000 010 095 091 1209 102 1116 026 351 000 000 000 000 : 261505
[ 93 77 -- -- -- -- ]: 000 000 000 006 092 115 1160 107 1191 023 306 000 000 000 000 : 261465
[ 93 78 -- -- -- -- ]: 000 000 000 007 080 107 1224 105 1144 018 315 000 000 000 000 : 261419
[ 93 79 -- -- -- -- ]: 000 000 000 013 116 122 1141 099 1170 033 306 000 000 000 000 : 261369
[ 93 80 -- -- -- -- ]: 000 000 000 007 088 086 1219 108 1165 036 291 000 000 000 000 : 261427
[ 93 81 -- -- -- -- ]: 000 000 000 012 102 095 1205 103 1157 026 300 000 000 000 000 : 261360
[ 93 82 -- -- -- -- ]: 000 000 000 005 084 114 1255 090 1139 031 282 000 000 000 000 : 261292
[ 93 83 -- -- -- -- ]: 000 000 000 011 095 105 1230 100 1123 028 308 000 000 000 000 : 261334
[ 93 84 -- -- -- -- ]: 000 000 000 007 080 095 1236 093 1152 031 306 000 000 000 000 : 261438
[ 93 85 -- -- -- -- ]: 000 000 000 009 099 094 1200 098 1142 028 330 000 000 000 000 : 261467
[ 93 86 -- -- -- -- ]: 000 000 000 008 085 099 1181 109 1142 028 348 000 000 000 000 : 261576
[ 93 87 -- -- -- -- ]: 000 000 000 012 077 101 1125 110 1186 036 353 000 000 000 000 : 261711
[ 93 88 -- -- -- -- ]: 000 000 000 016 113 104 1201 094 1166 023 283 000 000 000 000 : 261249
[ 93 89 -- -- -- -- ]: 000 000 000 010 098 092 1160 098 1198 029 315 000 000 000 000 : 261523
[ 93 90 -- -- -- -- ]: 000 000 000 011 098 098 1219 115 1136 027 296 000 000 000 000 : 261325
[ 93 91 -- -- -- -- ]: 000 000 000 007 083 095 1141 085 1203 041 345 000 000 000 000 : 261712
[ 93 92 -- -- -- -- ]: 000 000 000 011 088 098 1185 104 1157 024 333 000 000 000 000 : 261515
[ 93 93 -- -- -- -- ]: 000 000 000 012 109 105 1131 106 1197 023 317 000 000 000 000 : 261478
[ 93 94 -- -- -- -- ]: 000 000 000 005 087 095 1240 105 1118 029 321 000 000 000 000 : 261428
[ 93 95 -- -- -- -- ]: 000 000 000 007 089 106 1144 082 1194 036 342 000 000 000 000 : 261641
[ 93 96 -- -- -- -- ]: 000 000 000 011 101 098 1180 103 1182 026 299 000 000 000 000 : 261408
[ 93 97 -- -- -- -- ]: 000 000 000 006 108 106 1162 101 1150 031 336 000 000 000 000 : 261498
[ 93 98 -- -- -- -- ]: 000 000 000 017 094 114 1254 100 1100 027 294 000 000 000 000 : 261204
[ 93 99 -- -- -- -- ]: 000 000 000 011 091 107 1140 095 1184 039 333 000 000 000 000 : 261590
0: 43 = 262083
1: 91 = 261712
2: 87 = 261711
3: 72 = 261657
4: 95 = 261641
5: 66 = 261612
6: 75 = 261602
7: 69 = 261597
8: 99 = 261590
9: 37 = 261582
10: 86 = 261576
11: 73 = 261566
12: 26 = 261564
13: 46 = 261551
14: 32 = 261542
15: 42 = 261537
16: 47 = 261530
17: 89 = 261523
18: 92 = 261515
19: 52 = 261513
20: 76 = 261505
21: 54 = 261504
22: 00 = 261503
23: 63 = 261500
24: 97 = 261498
pin[1] candidate: 43 with latency 262083
[ 93 43 00 -- -- -- ]: 000 000 000 000 000 100 1101 111 1284 032 372 000 000 000 000 : 262163
[ 93 43 01 -- -- -- ]: 000 000 000 000 000 107 1086 123 1267 037 380 000 000 000 000 : 262181
[ 93 43 02 -- -- -- ]: 000 000 000 000 000 103 1229 099 1206 027 336 000 000 000 000 : 261833
[ 93 43 03 -- -- -- ]: 000 000 000 000 000 108 1264 102 1164 039 323 000 000 000 000 : 261731
[ 93 43 04 -- -- -- ]: 000 000 000 000 000 119 1214 111 1160 027 369 000 000 000 000 : 261869
[ 93 43 05 -- -- -- ]: 000 000 000 000 000 120 1259 106 1171 027 317 000 000 000 000 : 261677
[ 93 43 06 -- -- -- ]: 000 000 000 000 000 102 1222 111 1223 025 317 000 000 000 000 : 261798
[ 93 43 07 -- -- -- ]: 000 000 000 000 000 120 1244 107 1175 024 330 000 000 000 000 : 261729
[ 93 43 08 -- -- -- ]: 000 000 000 000 000 102 1180 107 1228 028 355 000 000 000 000 : 261965
[ 93 43 09 -- -- -- ]: 000 000 000 000 000 106 1267 095 1173 028 331 000 000 000 000 : 261743
[ 93 43 10 -- -- -- ]: 000 000 000 000 000 103 1206 101 1222 025 343 000 000 000 000 : 261889
[ 93 43 11 -- -- -- ]: 000 000 000 000 000 109 1247 122 1159 030 333 000 000 000 000 : 261753
[ 93 43 12 -- -- -- ]: 000 000 000 000 000 120 1236 086 1163 036 359 000 000 000 000 : 261836
[ 93 43 13 -- -- -- ]: 000 000 000 000 000 098 1218 102 1196 028 358 000 000 000 000 : 261912
[ 93 43 14 -- -- -- ]: 000 000 000 000 000 092 1241 115 1180 035 337 000 000 000 000 : 261836
[ 93 43 15 -- -- -- ]: 000 000 000 000 000 110 1259 109 1148 032 342 000 000 000 000 : 261759
[ 93 43 16 -- -- -- ]: 000 000 000 000 000 108 1247 106 1165 031 343 000 000 000 000 : 261793
[ 93 43 17 -- -- -- ]: 000 000 000 000 000 119 1195 097 1180 033 376 000 000 000 000 : 261941
[ 93 43 18 -- -- -- ]: 000 000 000 000 000 108 1191 117 1191 028 365 000 000 000 000 : 261935
[ 93 43 19 -- -- -- ]: 000 000 000 000 000 108 1258 115 1172 017 330 000 000 000 000 : 261722
[ 93 43 20 -- -- -- ]: 000 000 000 000 000 104 1126 103 1261 037 369 000 000 000 000 : 262108
[ 93 43 21 -- -- -- ]: 000 000 000 000 000 100 1296 104 1133 038 329 000 000 000 000 : 261700
[ 93 43 22 -- -- -- ]: 000 000 000 000 000 129 1289 088 1147 029 318 000 000 000 000 : 261612
[ 93 43 23 -- -- -- ]: 000 000 000 000 000 117 1215 111 1169 030 358 000 000 000 000 : 261854
[ 93 43 24 -- -- -- ]: 000 000 000 000 000 114 1259 096 1170 038 323 000 000 000 000 : 261728
[ 93 43 25 -- -- -- ]: 000 000 000 000 000 109 1252 101 1168 026 344 000 000 000 000 : 261782
[ 93 43 26 -- -- -- ]: 000 000 000 000 000 116 1189 103 1225 034 333 000 000 000 000 : 261871
[ 93 43 27 -- -- -- ]: 000 000 000 000 000 133 1180 105 1216 019 347 000 000 000 000 : 261849
[ 93 43 28 -- -- -- ]: 000 000 000 000 000 095 1165 120 1207 035 378 000 000 000 000 : 262056
[ 93 43 29 -- -- -- ]: 000 000 000 000 000 114 1238 090 1205 025 328 000 000 000 000 : 261773
[ 93 43 30 -- -- -- ]: 000 000 000 000 000 104 1187 094 1217 030 368 000 000 000 000 : 261986
[ 93 43 31 -- -- -- ]: 000 000 000 000 000 109 1284 110 1146 023 328 000 000 000 000 : 261674
[ 93 43 32 -- -- -- ]: 000 000 000 000 000 113 1306 104 1136 026 315 000 000 000 000 : 261601
[ 93 43 33 -- -- -- ]: 000 000 000 000 000 115 1268 097 1161 028 331 000 000 000 000 : 261712
[ 93 43 34 -- -- -- ]: 000 000 000 000 000 111 1225 110 1167 039 348 000 000 000 000 : 261842
[ 93 43 35 -- -- -- ]: 000 000 000 000 000 112 1245 100 1178 019 346 000 000 000 000 : 261785
[ 93 43 36 -- -- -- ]: 000 000 000 000 000 105 1300 119 1125 024 327 000 000 000 000 : 261644
[ 93 43 37 -- -- -- ]: 000 000 000 000 000 095 1222 102 1205 029 347 000 000 000 000 : 261892
[ 93 43 38 -- -- -- ]: 000 000 000 000 000 098 1277 102 1191 030 302 000 000 000 000 : 261684
[ 93 43 39 -- -- -- ]: 000 000 000 000 000 106 1312 101 1123 029 329 000 000 000 000 : 261644
[ 93 43 40 -- -- -- ]: 000 000 000 000 000 114 1243 106 1193 037 307 000 000 000 000 : 261717
[ 93 43 41 -- -- -- ]: 000 000 000 000 000 105 1207 110 1204 021 353 000 000 000 000 : 261888
[ 93 43 42 -- -- -- ]: 000 000 000 000 000 086 1058 117 1315 037 387 000 000 000 000 : 262320
[ 93 43 43 -- -- -- ]: 000 000 000 000 000 079 1055 112 1284 048 422 000 000 000 000 : 262433
[ 93 43 44 -- -- -- ]: 000 000 000 000 000 091 1027 141 1303 040 398 000 000 000 000 : 262368
[ 93 43 45 -- -- -- ]: 000 000 000 000 000 103 993 135 1302 035 432 000 000 000 000 : 262469
[ 93 43 46 -- -- -- ]: 000 000 000 000 000 095 1039 116 1305 035 410 000 000 000 000 : 262376
[ 93 43 47 -- -- -- ]: 000 000 000 000 000 100 1047 107 1317 043 386 000 000 000 000 : 262314
[ 93 43 48 -- -- -- ]: 000 000 000 000 000 096 1068 117 1282 033 404 000 000 000 000 : 262300
[ 93 43 49 -- -- -- ]: 000 000 000 000 000 091 1037 107 1305 042 418 000 000 000 000 : 262424
[ 93 43 50 -- -- -- ]: 000 000 000 000 000 108 1111 113 1284 029 355 000 000 000 000 : 262080
[ 93 43 51 -- -- -- ]: 000 000 000 000 000 078 1030 124 1292 043 433 000 000 000 000 : 262491
[ 93 43 52 -- -- -- ]: 000 000 000 000 000 086 1032 125 1296 031 430 000 000 000 000 : 262444
[ 93 43 53 -- -- -- ]: 000 000 000 000 000 081 1004 108 1337 032 438 000 000 000 000 : 262549
[ 93 43 54 -- -- -- ]: 000 000 000 000 000 094 1045 111 1283 036 431 000 000 000 000 : 262415
[ 93 43 55 -- -- -- ]: 000 000 000 000 000 107 1027 117 1302 034 413 000 000 000 000 : 262368
[ 93 43 56 -- -- -- ]: 000 000 000 000 000 099 1005 108 1338 048 402 000 000 000 000 : 262437
[ 93 43 57 -- -- -- ]: 000 000 000 000 000 093 1058 106 1304 041 398 000 000 000 000 : 262336
[ 93 43 58 -- -- -- ]: 000 000 000 000 000 093 1101 109 1253 031 413 000 000 000 000 : 262267
[ 93 43 59 -- -- -- ]: 000 000 000 000 000 106 1061 103 1269 035 426 000 000 000 000 : 262344
[ 93 43 60 -- -- -- ]: 000 000 000 000 000 109 1234 104 1209 028 316 000 000 000 000 : 261761
[ 93 43 61 -- -- -- ]: 000 000 000 000 000 086 1008 107 1329 039 431 000 000 000 000 : 262520
[ 93 43 62 -- -- -- ]: 000 000 000 000 000 081 1062 131 1265 038 423 000 000 000 000 : 262386
[ 93 43 63 -- -- -- ]: 000 000 000 000 000 091 1092 112 1249 039 417 000 000 000 000 : 262304
[ 93 43 64 -- -- -- ]: 000 000 000 000 000 102 1027 112 1296 056 407 000 000 000 000 : 262398
[ 93 43 65 -- -- -- ]: 000 000 000 000 000 099 1044 113 1266 048 430 000 000 000 000 : 262410
[ 93 43 66 -- -- -- ]: 000 000 000 000 000 083 1043 124 1279 045 426 000 000 000 000 : 262438
[ 93 43 67 -- -- -- ]: 000 000 000 000 000 095 1074 113 1268 038 412 000 000 000 000 : 262316
[ 93 43 68 -- -- -- ]: 000 000 000 000 000 092 1078 102 1296 035 397 000 000 000 000 : 262295
[ 93 43 69 -- -- -- ]: 000 000 000 000 000 101 1053 096 1303 041 406 000 000 000 000 : 262348
[ 93 43 70 -- -- -- ]: 000 000 000 000 000 089 1160 119 1232 047 353 000 000 000 000 : 262047
[ 93 43 71 -- -- -- ]: 000 000 000 000 000 104 1014 116 1331 043 392 000 000 000 000 : 262371
[ 93 43 72 -- -- -- ]: 000 000 000 000 000 097 1040 101 1323 038 401 000 000 000 000 : 262368
[ 93 43 73 -- -- -- ]: 000 000 000 000 000 097 1037 108 1315 030 413 000 000 000 000 : 262383
[ 93 43 74 -- -- -- ]: 000 000 000 000 000 085 1044 117 1291 037 426 000 000 000 000 : 262429
[ 93 43 75 -- -- -- ]: 000 000 000 000 000 097 1018 126 1299 034 426 000 000 000 000 : 262433
[ 93 43 76 -- -- -- ]: 000 000 000 000 000 103 1032 105 1305 028 427 000 000 000 000 : 262404
[ 93 43 77 -- -- -- ]: 000 000 000 000 000 104 1105 118 1224 029 420 000 000 000 000 : 262229
[ 93 43 78 -- -- -- ]: 000 000 000 000 000 083 1047 118 1322 034 396 000 000 000 000 : 262365
[ 93 43 79 -- -- -- ]: 000 000 000 000 000 083 1100 109 1269 041 398 000 000 000 000 : 262279
[ 93 43 80 -- -- -- ]: 000 000 000 000 000 119 1230 100 1174 024 353 000 000 000 000 : 261813
[ 93 43 81 -- -- -- ]: 000 000 000 000 000 104 1264 105 1161 027 339 000 000 000 000 : 261760
[ 93 43 82 -- -- -- ]: 000 000 000 000 000 121 1210 101 1174 026 368 000 000 000 000 : 261878
[ 93 43 83 -- -- -- ]: 000 000 000 000 000 103 1216 103 1186 040 352 000 000 000 000 : 261900
[ 93 43 84 -- -- -- ]: 000 000 000 000 000 081 1021 116 1310 049 423 000 000 000 000 : 262494
[ 93 43 85 -- -- -- ]: 000 000 000 000 000 101 1044 105 1308 035 407 000 000 000 000 : 262353
[ 93 43 86 -- -- -- ]: 000 000 000 000 000 087 1054 115 1300 036 408 000 000 000 000 : 262368
[ 93 43 87 -- -- -- ]: 000 000 000 000 000 103 1052 110 1313 038 384 000 000 000 000 : 262283
[ 93 43 88 -- -- -- ]: 000 000 000 000 000 087 1107 113 1277 035 381 000 000 000 000 : 262209
[ 93 43 89 -- -- -- ]: 000 000 000 000 000 094 999 123 1346 031 407 000 000 000 000 : 262442
[ 93 43 90 -- -- -- ]: 000 000 000 000 000 107 1148 099 1238 034 374 000 000 000 000 : 262066
[ 93 43 91 -- -- -- ]: 000 000 000 000 000 089 1030 137 1301 033 410 000 000 000 000 : 262389
[ 93 43 92 -- -- -- ]: 000 000 000 000 000 083 1052 113 1301 042 409 000 000 000 000 : 262394
[ 93 43 93 -- -- -- ]: 000 000 000 000 000 087 934 108 1320 048 503 000 000 000 000 : 262817
[ 93 43 94 -- -- -- ]: 000 000 000 000 000 095 1058 116 1302 047 382 000 000 000 000 : 262294
[ 93 43 95 -- -- -- ]: 000 000 000 000 000 093 1047 114 1311 028 407 000 000 000 000 : 262355
[ 93 43 96 -- -- -- ]: 000 000 000 000 000 099 1038 104 1313 043 403 000 000 000 000 : 262372
[ 93 43 97 -- -- -- ]: 000 000 000 000 000 096 1101 116 1278 033 376 000 000 000 000 : 262179
[ 93 43 98 -- -- -- ]: 000 000 000 000 000 089 1086 106 1250 034 435 000 000 000 000 : 262359
[ 93 43 99 -- -- -- ]: 000 000 000 000 000 082 1037 107 1334 041 399 000 000 000 000 : 262412
0: 93 = 262817
1: 53 = 262549
2: 61 = 262520
3: 84 = 262494
4: 51 = 262491
5: 45 = 262469
6: 52 = 262444
7: 89 = 262442
8: 66 = 262438
9: 56 = 262437
10: 43 = 262433
11: 75 = 262433
12: 74 = 262429
13: 49 = 262424
14: 54 = 262415
15: 99 = 262412
16: 65 = 262410
17: 76 = 262404
18: 64 = 262398
19: 92 = 262394
20: 91 = 262389
21: 62 = 262386
22: 73 = 262383
23: 46 = 262376
24: 96 = 262372
pin[2] candidate: 93 with latency 262817
Candidate PIN 0x93 0x43 0x93 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 657 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..done
found PIN: 0x25 0x43 0x27 0x93 0x52 0x93
PIN is cracked in 921.64 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Code: Select all
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.04.12 16:36:03 =~=~=~=~=~=~=~=~=~=~=~=
2011 CEM-L
Platform: P2
<--- ID=00000003 data=50 8e 00 00 31 39 41 57
Part Number: 000031394157
1000 pins in 658 ms, 1519 pins/s, average response: 87
[ 00 -- -- -- -- -- ]: 000 000 000 000 000 072 1295 081 1111 030 411 000 000 000 000 : 261965
[ 01 -- -- -- -- -- ]: 000 000 000 000 000 088 1419 057 1015 028 393 000 000 000 000 : 261655
[ 02 -- -- -- -- -- ]: 000 000 000 000 000 084 1236 082 1253 027 318 000 000 000 000 : 261857
[ 03 -- -- -- -- -- ]: 000 000 000 000 000 072 1219 075 1312 024 298 000 000 000 000 : 261891
[ 04 -- -- -- -- -- ]: 000 000 000 000 000 085 1200 074 1291 023 327 000 000 000 000 : 261948
[ 05 -- -- -- -- -- ]: 000 000 000 000 000 066 1198 082 1352 019 283 000 000 000 000 : 261909
[ 06 -- -- -- -- -- ]: 000 000 000 000 000 068 1166 092 1377 015 282 000 000 000 000 : 261951
[ 07 -- -- -- -- -- ]: 000 000 000 000 000 083 1146 090 1352 016 313 000 000 000 000 : 262011
[ 08 -- -- -- -- -- ]: 000 000 000 000 000 078 1143 077 1344 026 332 000 000 000 000 : 262093
[ 09 -- -- -- -- -- ]: 000 000 000 000 000 064 1127 098 1410 021 280 000 000 000 000 : 262037
[ 10 -- -- -- -- -- ]: 000 000 000 000 000 078 1306 075 1177 022 342 000 000 000 000 : 261785
[ 11 -- -- -- -- -- ]: 000 000 000 000 000 074 1051 097 1483 013 282 000 000 000 000 : 262156
[ 12 -- -- -- -- -- ]: 000 000 000 000 000 079 1093 097 1436 012 283 000 000 000 000 : 262058
[ 13 -- -- -- -- -- ]: 000 000 000 000 000 055 1089 091 1487 018 260 000 000 000 000 : 262104
[ 14 -- -- -- -- -- ]: 000 000 000 000 000 076 1128 079 1407 019 291 000 000 000 000 : 262038
[ 15 -- -- -- -- -- ]: 000 000 000 000 000 069 1064 099 1500 014 254 000 000 000 000 : 262088
[ 16 -- -- -- -- -- ]: 000 000 000 000 000 068 1107 099 1447 014 265 000 000 000 000 : 262027
[ 17 -- -- -- -- -- ]: 000 000 000 000 000 055 1050 096 1506 026 267 000 000 000 000 : 262199
[ 18 -- -- -- -- -- ]: 000 000 000 000 000 061 1170 103 1329 024 313 000 000 000 000 : 262024
[ 19 -- -- -- -- -- ]: 000 000 000 000 000 066 1039 087 1523 017 268 000 000 000 000 : 262190
[ 20 -- -- -- -- -- ]: 000 000 000 000 000 079 1449 058 1006 029 379 000 000 000 000 : 261594
[ 21 -- -- -- -- -- ]: 000 000 000 000 000 047 1047 098 1530 012 266 000 000 000 000 : 262211
[ 22 -- -- -- -- -- ]: 000 000 000 000 000 062 1075 101 1505 010 247 000 000 000 000 : 262067
[ 23 -- -- -- -- -- ]: 000 000 000 000 000 067 1011 091 1575 013 243 000 000 000 000 : 262185
[ 24 -- -- -- -- -- ]: 000 000 000 000 000 068 1109 088 1422 022 291 000 000 000 000 : 262094
[ 25 -- -- -- -- -- ]: 000 000 000 000 000 072 1038 093 1533 015 249 000 000 000 000 : 262128
[ 26 -- -- -- -- -- ]: 000 000 000 000 000 075 1060 095 1487 015 268 000 000 000 000 : 262111
[ 27 -- -- -- -- -- ]: 000 000 000 000 000 072 1023 090 1561 023 231 000 000 000 000 : 262133
[ 28 -- -- -- -- -- ]: 000 000 000 000 000 072 1184 089 1342 024 289 000 000 000 000 : 261929
[ 29 -- -- -- -- -- ]: 000 000 000 000 000 052 1003 110 1567 022 246 000 000 000 000 : 262242
[ 30 -- -- -- -- -- ]: 000 000 000 000 000 073 1318 084 1165 024 336 000 000 000 000 : 261757
[ 31 -- -- -- -- -- ]: 000 000 000 000 000 058 1041 091 1530 023 257 000 000 000 000 : 262190
[ 32 -- -- -- -- -- ]: 000 000 000 000 000 067 1080 100 1460 018 275 000 000 000 000 : 262107
[ 33 -- -- -- -- -- ]: 000 000 000 000 000 060 996 102 1560 015 267 000 000 000 000 : 262275
[ 34 -- -- -- -- -- ]: 000 000 000 000 000 063 1149 089 1386 028 285 000 000 000 000 : 262022
[ 35 -- -- -- -- -- ]: 000 000 000 000 000 066 1081 099 1494 018 242 000 000 000 000 : 262043
[ 36 -- -- -- -- -- ]: 000 000 000 000 000 049 1113 108 1429 019 282 000 000 000 000 : 262102
[ 37 -- -- -- -- -- ]: 000 000 000 000 000 069 1033 091 1536 015 256 000 000 000 000 : 262163
[ 38 -- -- -- -- -- ]: 000 000 000 000 000 076 1183 074 1354 019 294 000 000 000 000 : 261939
[ 39 -- -- -- -- -- ]: 000 000 000 000 000 060 1049 086 1526 022 257 000 000 000 000 : 262172
[ 40 -- -- -- -- -- ]: 000 000 000 000 000 080 1183 072 1301 033 331 000 000 000 000 : 262017
[ 41 -- -- -- -- -- ]: 000 000 000 000 000 051 1216 106 1277 020 330 000 000 000 000 : 261989
[ 42 -- -- -- -- -- ]: 000 000 000 000 000 068 1117 089 1341 024 361 000 000 000 000 : 262219
[ 43 -- -- -- -- -- ]: 000 000 000 000 000 059 1138 087 1334 021 361 000 000 000 000 : 262203
[ 44 -- -- -- -- -- ]: 000 000 000 000 000 062 1193 086 1309 023 327 000 000 000 000 : 262019
[ 45 -- -- -- -- -- ]: 000 000 000 000 000 064 1104 087 1350 014 381 000 000 000 000 : 262289
[ 46 -- -- -- -- -- ]: 000 000 000 000 000 070 1175 086 1321 019 329 000 000 000 000 : 262031
[ 47 -- -- -- -- -- ]: 000 000 000 000 000 064 1148 087 1321 034 346 000 000 000 000 : 262151
[ 48 -- -- -- -- -- ]: 000 000 000 000 000 081 1171 086 1348 020 294 000 000 000 000 : 261937
[ 49 -- -- -- -- -- ]: 000 000 000 000 000 057 1129 095 1360 022 337 000 000 000 000 : 262172
[ 50 -- -- -- -- -- ]: 000 000 000 000 000 072 1213 083 1290 021 321 000 000 000 000 : 261938
[ 51 -- -- -- -- -- ]: 000 000 000 000 000 063 1095 087 1387 018 350 000 000 000 000 : 262252
[ 52 -- -- -- -- -- ]: 000 000 000 000 000 085 1144 076 1349 015 331 000 000 000 000 : 262058
[ 53 -- -- -- -- -- ]: 000 000 000 000 000 070 1118 087 1385 015 325 000 000 000 000 : 262132
[ 54 -- -- -- -- -- ]: 000 000 000 000 000 081 1162 087 1355 022 293 000 000 000 000 : 261954
[ 55 -- -- -- -- -- ]: 000 000 000 000 000 075 1113 083 1386 018 325 000 000 000 000 : 262134
[ 56 -- -- -- -- -- ]: 000 000 000 000 000 073 1184 074 1321 026 322 000 000 000 000 : 262009
[ 57 -- -- -- -- -- ]: 000 000 000 000 000 067 1163 083 1339 018 330 000 000 000 000 : 262068
[ 58 -- -- -- -- -- ]: 000 000 000 000 000 073 1176 077 1357 015 302 000 000 000 000 : 261971
[ 59 -- -- -- -- -- ]: 000 000 000 000 000 072 1128 076 1352 023 349 000 000 000 000 : 262173
[ 60 -- -- -- -- -- ]: 000 000 000 000 000 062 1234 069 1288 024 323 000 000 000 000 : 261947
[ 61 -- -- -- -- -- ]: 000 000 000 000 000 076 1110 081 1341 029 363 000 000 000 000 : 262226
[ 62 -- -- -- -- -- ]: 000 000 000 000 000 077 1137 080 1357 018 331 000 000 000 000 : 262095
[ 63 -- -- -- -- -- ]: 000 000 000 000 000 068 1128 092 1309 029 374 000 000 000 000 : 262225
[ 64 -- -- -- -- -- ]: 000 000 000 000 000 078 1155 080 1324 022 341 000 000 000 000 : 262080
[ 65 -- -- -- -- -- ]: 000 000 000 000 000 071 1100 098 1307 024 400 000 000 000 000 : 262313
[ 66 -- -- -- -- -- ]: 000 000 000 000 000 083 1127 088 1331 022 349 000 000 000 000 : 262129
[ 67 -- -- -- -- -- ]: 000 000 000 000 000 078 1085 091 1347 021 378 000 000 000 000 : 262282
[ 68 -- -- -- -- -- ]: 000 000 000 000 000 078 1163 079 1221 019 440 000 000 000 000 : 262260
[ 69 -- -- -- -- -- ]: 000 000 000 000 000 068 1133 086 1327 021 365 000 000 000 000 : 262195
[ 70 -- -- -- -- -- ]: 000 000 000 000 000 080 1200 081 1290 024 325 000 000 000 000 : 261953
[ 71 -- -- -- -- -- ]: 000 000 000 000 000 070 1111 086 1369 017 347 000 000 000 000 : 262193
[ 72 -- -- -- -- -- ]: 000 000 000 000 000 074 1133 086 1336 018 353 000 000 000 000 : 262150
[ 73 -- -- -- -- -- ]: 000 000 000 000 000 068 1147 094 1346 021 324 000 000 000 000 : 262077
[ 74 -- -- -- -- -- ]: 000 000 000 000 000 056 1143 098 1326 025 352 000 000 000 000 : 262177
[ 75 -- -- -- -- -- ]: 000 000 000 000 000 073 1133 091 1341 022 340 000 000 000 000 : 262126
[ 76 -- -- -- -- -- ]: 000 000 000 000 000 077 1111 074 1323 026 389 000 000 000 000 : 262277
[ 77 -- -- -- -- -- ]: 000 000 000 000 000 074 1128 084 1331 019 364 000 000 000 000 : 262185
[ 78 -- -- -- -- -- ]: 000 000 000 000 000 077 1163 084 1315 022 339 000 000 000 000 : 262059
[ 79 -- -- -- -- -- ]: 000 000 000 000 000 068 1169 083 1261 018 401 000 000 000 000 : 262195
[ 80 -- -- -- -- -- ]: 000 000 000 000 000 057 1220 091 1313 018 301 000 000 000 000 : 261918
[ 81 -- -- -- -- -- ]: 000 000 000 000 000 072 1184 086 1356 021 281 000 000 000 000 : 261913
[ 82 -- -- -- -- -- ]: 000 000 000 000 000 068 1186 082 1352 025 287 000 000 000 000 : 261941
[ 83 -- -- -- -- -- ]: 000 000 000 000 000 060 1140 087 1401 017 295 000 000 000 000 : 262060
[ 84 -- -- -- -- -- ]: 000 000 000 000 000 080 1158 078 1319 024 341 000 000 000 000 : 262072
[ 85 -- -- -- -- -- ]: 000 000 000 000 000 085 1144 080 1276 020 395 000 000 000 000 : 262187
[ 86 -- -- -- -- -- ]: 000 000 000 000 000 077 1171 071 1308 024 349 000 000 000 000 : 262078
[ 87 -- -- -- -- -- ]: 000 000 000 000 000 073 1152 088 1278 021 388 000 000 000 000 : 262186
[ 88 -- -- -- -- -- ]: 000 000 000 000 000 075 1150 082 1316 020 357 000 000 000 000 : 262127
[ 89 -- -- -- -- -- ]: 000 000 000 000 000 076 1142 093 1265 022 402 000 000 000 000 : 262221
[ 90 -- -- -- -- -- ]: 000 000 000 000 000 073 1158 089 1358 024 298 000 000 000 000 : 261996
[ 91 -- -- -- -- -- ]: 000 000 000 000 000 063 1102 092 1315 027 401 000 000 000 000 : 262344
[ 92 -- -- -- -- -- ]: 000 000 000 000 000 090 1158 083 1291 019 359 000 000 000 000 : 262068
[ 93 -- -- -- -- -- ]: 000 000 000 000 000 073 1162 084 1268 024 389 000 000 000 000 : 262175
[ 94 -- -- -- -- -- ]: 000 000 000 000 000 077 1155 069 1311 020 368 000 000 000 000 : 262146
[ 95 -- -- -- -- -- ]: 000 000 000 000 000 059 1134 079 1292 020 416 000 000 000 000 : 262328
[ 96 -- -- -- -- -- ]: 000 000 000 000 000 072 1149 077 1322 023 357 000 000 000 000 : 262146
[ 97 -- -- -- -- -- ]: 000 000 000 000 000 069 1131 080 1309 021 390 000 000 000 000 : 262252
[ 98 -- -- -- -- -- ]: 000 000 000 000 000 074 1165 072 1286 020 383 000 000 000 000 : 262162
[ 99 -- -- -- -- -- ]: 000 000 000 000 000 072 1122 080 1283 027 416 000 000 000 000 : 262319
0: 91 = 262344
1: 95 = 262328
2: 99 = 262319
3: 65 = 262313
4: 45 = 262289
5: 67 = 262282
6: 76 = 262277
7: 33 = 262275
8: 68 = 262260
9: 97 = 262252
10: 51 = 262252
11: 29 = 262242
12: 61 = 262226
13: 63 = 262225
14: 89 = 262221
15: 42 = 262219
16: 21 = 262211
17: 43 = 262203
18: 17 = 262199
19: 79 = 262195
20: 69 = 262195
21: 71 = 262193
22: 31 = 262190
23: 19 = 262190
24: 85 = 262187
pin[0] candidate: 91 with latency 262344
Warning: Selected candidate is very close to the next candidate!
Selection may be incorrect.
[ 91 00 -- -- -- -- ]: 000 000 000 000 000 058 1119 090 1291 023 419 000 000 000 000 : 262359
[ 91 01 -- -- -- -- ]: 000 000 000 000 000 072 1115 080 1308 035 390 000 000 000 000 : 262289
[ 91 02 -- -- -- -- ]: 000 000 000 000 000 068 1028 080 1329 034 461 000 000 000 000 : 262616
[ 91 03 -- -- -- -- ]: 000 000 000 000 000 066 1027 071 1287 029 520 000 000 000 000 : 262746
[ 91 04 -- -- -- -- ]: 000 000 000 000 000 070 1073 085 1339 031 402 000 000 000 000 : 262394
[ 91 05 -- -- -- -- ]: 000 000 000 000 000 065 1036 077 1303 034 485 000 000 000 000 : 262660
[ 91 06 -- -- -- -- ]: 000 000 000 000 000 070 991 090 1310 036 503 000 000 000 000 : 262760
[ 91 07 -- -- -- -- ]: 000 000 000 000 000 066 994 086 1346 033 475 000 000 000 000 : 262711
[ 91 08 -- -- -- -- ]: 000 000 000 000 000 065 1029 088 1304 033 481 000 000 000 000 : 262654
[ 91 09 -- -- -- -- ]: 000 000 000 000 000 065 962 079 1288 043 563 000 000 000 000 : 262971
[ 91 10 -- -- -- -- ]: 000 000 000 000 000 062 1098 088 1287 034 431 000 000 000 000 : 262426
[ 91 11 -- -- -- -- ]: 000 000 000 000 000 047 1026 081 1220 042 584 000 000 000 000 : 262936
[ 91 12 -- -- -- -- ]: 000 000 000 000 000 063 1068 074 1198 047 550 000 000 000 000 : 262748
[ 91 13 -- -- -- -- ]: 000 000 000 000 000 045 1022 078 1298 035 522 000 000 000 000 : 262822
[ 91 14 -- -- -- -- ]: 000 000 000 000 000 056 1067 089 1270 024 494 000 000 000 000 : 262621
[ 91 15 -- -- -- -- ]: 000 000 000 000 000 062 1050 088 1199 035 566 000 000 000 000 : 262793
[ 91 16 -- -- -- -- ]: 000 000 000 000 000 075 1059 081 1263 042 480 000 000 000 000 : 262578
[ 91 17 -- -- -- -- ]: 000 000 000 000 000 056 1033 088 1304 034 485 000 000 000 000 : 262682
[ 91 18 -- -- -- -- ]: 000 000 000 000 000 068 1090 069 1286 027 460 000 000 000 000 : 262494
[ 91 19 -- -- -- -- ]: 000 000 000 000 000 056 1043 084 1287 040 490 000 000 000 000 : 262682
[ 91 20 -- -- -- -- ]: 000 000 000 000 000 078 1104 080 1256 024 458 000 000 000 000 : 262418
[ 91 21 -- -- -- -- ]: 000 000 000 000 000 075 1043 083 1266 034 499 000 000 000 000 : 262638
[ 91 22 -- -- -- -- ]: 000 000 000 000 000 070 1087 079 1200 045 519 000 000 000 000 : 262620
[ 91 23 -- -- -- -- ]: 000 000 000 000 000 077 1010 081 1288 037 507 000 000 000 000 : 262719
[ 91 24 -- -- -- -- ]: 000 000 000 000 000 065 1105 084 1273 025 448 000 000 000 000 : 262432
[ 91 25 -- -- -- -- ]: 000 000 000 000 000 064 1041 078 1246 039 532 000 000 000 000 : 262751
[ 91 26 -- -- -- -- ]: 000 000 000 000 000 055 1081 091 1257 033 483 000 000 000 000 : 262581
[ 91 27 -- -- -- -- ]: 000 000 000 000 000 065 1033 083 1272 025 522 000 000 000 000 : 262725
[ 91 28 -- -- -- -- ]: 000 000 000 000 000 065 1108 087 1291 019 430 000 000 000 000 : 262381
[ 91 29 -- -- -- -- ]: 000 000 000 000 000 064 1094 085 1251 035 471 000 000 000 000 : 262512
[ 91 30 -- -- -- -- ]: 000 000 000 000 000 077 1097 087 1296 019 424 000 000 000 000 : 262355
[ 91 31 -- -- -- -- ]: 000 000 000 000 000 074 1018 083 1273 030 522 000 000 000 000 : 262733
[ 91 32 -- -- -- -- ]: 000 000 000 000 000 055 1046 079 1272 034 514 000 000 000 000 : 262726
[ 91 33 -- -- -- -- ]: 000 000 000 000 000 066 1004 085 1278 032 535 000 000 000 000 : 262811
[ 91 34 -- -- -- -- ]: 000 000 000 000 000 067 1110 091 1272 025 435 000 000 000 000 : 262383
[ 91 35 -- -- -- -- ]: 000 000 000 000 000 069 1058 068 1272 028 505 000 000 000 000 : 262647
[ 91 36 -- -- -- -- ]: 000 000 000 000 000 056 1075 086 1253 032 498 000 000 000 000 : 262624
[ 91 37 -- -- -- -- ]: 000 000 000 000 000 058 1028 095 1277 036 506 000 000 000 000 : 262723
[ 91 38 -- -- -- -- ]: 000 000 000 000 000 069 1046 085 1303 021 476 000 000 000 000 : 262589
[ 91 39 -- -- -- -- ]: 000 000 000 000 000 071 1003 098 1310 025 493 000 000 000 000 : 262694
[ 91 40 -- -- -- -- ]: 000 000 000 000 000 057 1036 083 1336 027 461 000 000 000 000 : 262623
[ 91 41 -- -- -- -- ]: 000 000 000 000 000 067 1067 074 1289 032 471 000 000 000 000 : 262565
[ 91 42 -- -- -- -- ]: 000 000 000 000 000 065 966 080 1322 034 533 000 000 000 000 : 262893
[ 91 43 -- -- -- -- ]: 000 000 000 000 000 061 1053 076 1285 038 487 000 000 000 000 : 262647
[ 91 44 -- -- -- -- ]: 000 000 000 000 000 074 1037 083 1303 028 475 000 000 000 000 : 262599
[ 91 45 -- -- -- -- ]: 000 000 000 000 000 065 977 088 1318 023 529 000 000 000 000 : 262844
[ 91 46 -- -- -- -- ]: 000 000 000 000 000 072 1028 077 1261 032 530 000 000 000 000 : 262743
[ 91 47 -- -- -- -- ]: 000 000 000 000 000 053 1052 085 1240 044 526 000 000 000 000 : 262748
[ 91 48 -- -- -- -- ]: 000 000 000 000 000 069 1034 086 1300 030 481 000 000 000 000 : 262631
[ 91 49 -- -- -- -- ]: 000 000 000 000 000 043 1043 088 1270 032 524 000 000 000 000 : 262777
[ 91 50 -- -- -- -- ]: 000 000 000 000 000 081 1048 083 1311 030 447 000 000 000 000 : 262502
[ 91 51 -- -- -- -- ]: 000 000 000 000 000 066 1015 086 1266 031 536 000 000 000 000 : 262789
[ 91 52 -- -- -- -- ]: 000 000 000 000 000 058 1004 072 1300 040 526 000 000 000 000 : 262838
[ 91 53 -- -- -- -- ]: 000 000 000 000 000 074 1056 069 1277 036 488 000 000 000 000 : 262609
[ 91 54 -- -- -- -- ]: 000 000 000 000 000 075 1011 078 1318 027 491 000 000 000 000 : 262684
[ 91 55 -- -- -- -- ]: 000 000 000 000 000 061 1021 071 1295 044 508 000 000 000 000 : 262764
[ 91 56 -- -- -- -- ]: 000 000 000 000 000 062 1054 088 1267 025 504 000 000 000 000 : 262651
[ 91 57 -- -- -- -- ]: 000 000 000 000 000 071 1041 087 1267 033 501 000 000 000 000 : 262653
[ 91 58 -- -- -- -- ]: 000 000 000 000 000 066 1064 086 1301 032 451 000 000 000 000 : 262522
[ 91 59 -- -- -- -- ]: 000 000 000 000 000 063 1064 086 1283 037 467 000 000 000 000 : 262568
[ 91 60 -- -- -- -- ]: 000 000 000 000 000 067 1072 088 1288 035 450 000 000 000 000 : 262502
[ 91 61 -- -- -- -- ]: 000 000 000 000 000 066 1046 080 1282 029 497 000 000 000 000 : 262653
[ 91 62 -- -- -- -- ]: 000 000 000 000 000 063 1037 074 1310 025 491 000 000 000 000 : 262670
[ 91 63 -- -- -- -- ]: 000 000 000 000 000 072 1031 068 1284 025 520 000 000 000 000 : 262719
[ 91 64 -- -- -- -- ]: 000 000 000 000 000 061 1055 081 1308 039 456 000 000 000 000 : 262577
[ 91 65 -- -- -- -- ]: 000 000 000 000 000 062 1009 091 1274 037 527 000 000 000 000 : 262796
[ 91 66 -- -- -- -- ]: 000 000 000 000 000 082 1053 082 1244 030 509 000 000 000 000 : 262614
[ 91 67 -- -- -- -- ]: 000 000 000 000 000 072 1022 076 1288 032 510 000 000 000 000 : 262716
[ 91 68 -- -- -- -- ]: 000 000 000 000 000 063 1070 067 1269 030 501 000 000 000 000 : 262636
[ 91 69 -- -- -- -- ]: 000 000 000 000 000 062 1045 089 1289 032 483 000 000 000 000 : 262633
[ 91 70 -- -- -- -- ]: 000 000 000 000 000 068 1054 095 1284 038 461 000 000 000 000 : 262553
[ 91 71 -- -- -- -- ]: 000 000 000 000 000 068 1050 065 1263 031 523 000 000 000 000 : 262708
[ 91 72 -- -- -- -- ]: 000 000 000 000 000 063 977 085 1312 037 526 000 000 000 000 : 262861
[ 91 73 -- -- -- -- ]: 000 000 000 000 000 072 1014 079 1288 025 522 000 000 000 000 : 262746
[ 91 74 -- -- -- -- ]: 000 000 000 000 000 074 1036 083 1317 027 463 000 000 000 000 : 262576
[ 91 75 -- -- -- -- ]: 000 000 000 000 000 073 1004 083 1317 022 501 000 000 000 000 : 262714
[ 91 76 -- -- -- -- ]: 000 000 000 000 000 065 995 079 1298 037 526 000 000 000 000 : 262825
[ 91 77 -- -- -- -- ]: 000 000 000 000 000 060 1045 073 1274 030 518 000 000 000 000 : 262723
[ 91 78 -- -- -- -- ]: 000 000 000 000 000 067 1042 078 1338 029 446 000 000 000 000 : 262558
[ 91 79 -- -- -- -- ]: 000 000 000 000 000 056 1044 096 1254 033 517 000 000 000 000 : 262715
[ 91 80 -- -- -- -- ]: 000 000 000 000 000 073 1102 079 1316 026 404 000 000 000 000 : 262332
[ 91 81 -- -- -- -- ]: 000 000 000 000 000 065 1022 093 1328 020 472 000 000 000 000 : 262632
[ 91 82 -- -- -- -- ]: 000 000 000 000 000 068 1033 080 1290 037 492 000 000 000 000 : 262671
[ 91 83 -- -- -- -- ]: 000 000 000 000 000 062 1055 089 1268 037 489 000 000 000 000 : 262630
[ 91 84 -- -- -- -- ]: 000 000 000 000 000 050 1036 086 1291 036 501 000 000 000 000 : 262730
[ 91 85 -- -- -- -- ]: 000 000 000 000 000 050 993 090 1317 040 510 000 000 000 000 : 262834
[ 91 86 -- -- -- -- ]: 000 000 000 000 000 064 1068 091 1261 025 491 000 000 000 000 : 262588
[ 91 87 -- -- -- -- ]: 000 000 000 000 000 063 1029 072 1303 034 499 000 000 000 000 : 262713
[ 91 88 -- -- -- -- ]: 000 000 000 000 000 064 1067 074 1285 039 471 000 000 000 000 : 262581
[ 91 89 -- -- -- -- ]: 000 000 000 000 000 060 1029 092 1311 026 482 000 000 000 000 : 262660
[ 91 90 -- -- -- -- ]: 000 000 000 000 000 062 1106 080 1279 025 448 000 000 000 000 : 262443
[ 91 91 -- -- -- -- ]: 000 000 000 000 000 070 1023 076 1309 034 488 000 000 000 000 : 262678
[ 91 92 -- -- -- -- ]: 000 000 000 000 000 059 996 097 1312 025 511 000 000 000 000 : 262781
[ 91 93 -- -- -- -- ]: 000 000 000 000 000 069 1041 068 1287 035 500 000 000 000 000 : 262678
[ 91 94 -- -- -- -- ]: 000 000 000 000 000 063 1041 088 1297 030 481 000 000 000 000 : 262633
[ 91 95 -- -- -- -- ]: 000 000 000 000 000 053 1052 089 1273 040 493 000 000 000 000 : 262674
[ 91 96 -- -- -- -- ]: 000 000 000 000 000 066 988 090 1309 037 510 000 000 000 000 : 262793
[ 91 97 -- -- -- -- ]: 000 000 000 000 000 052 1040 098 1290 031 489 000 000 000 000 : 262675
[ 91 98 -- -- -- -- ]: 000 000 000 000 000 067 1007 075 1289 024 538 000 000 000 000 : 262810
[ 91 99 -- -- -- -- ]: 000 000 000 000 000 069 1012 081 1296 027 515 000 000 000 000 : 262745
0: 09 = 262971
1: 11 = 262936
2: 42 = 262893
3: 72 = 262861
4: 45 = 262844
5: 52 = 262838
6: 85 = 262834
7: 76 = 262825
8: 13 = 262822
9: 33 = 262811
10: 98 = 262810
11: 65 = 262796
12: 15 = 262793
13: 96 = 262793
14: 51 = 262789
15: 92 = 262781
16: 49 = 262777
17: 55 = 262764
18: 06 = 262760
19: 25 = 262751
20: 47 = 262748
21: 12 = 262748
22: 73 = 262746
23: 03 = 262746
24: 99 = 262745
pin[1] candidate: 09 with latency 262971
[ 91 09 00 -- -- -- ]: 000 000 000 000 000 057 1005 092 1345 027 474 000 000 000 000 : 262702
[ 91 09 01 -- -- -- ]: 000 000 000 000 000 051 1039 075 1275 034 526 000 000 000 000 : 262780
[ 91 09 02 -- -- -- ]: 000 000 000 000 000 078 1008 089 1285 028 512 000 000 000 000 : 262713
[ 91 09 03 -- -- -- ]: 000 000 000 000 000 068 1028 076 1321 026 481 000 000 000 000 : 262652
[ 91 09 04 -- -- -- ]: 000 000 000 000 000 059 1065 087 1251 028 510 000 000 000 000 : 262654
[ 91 09 05 -- -- -- ]: 000 000 000 000 000 063 1032 087 1258 028 532 000 000 000 000 : 262752
[ 91 09 06 -- -- -- ]: 000 000 000 000 000 062 1053 098 1237 031 519 000 000 000 000 : 262679
[ 91 09 07 -- -- -- ]: 000 000 000 000 000 068 1042 073 1253 034 530 000 000 000 000 : 262733
[ 91 09 08 -- -- -- ]: 000 000 000 000 000 075 1033 085 1264 031 512 000 000 000 000 : 262679
[ 91 09 09 -- -- -- ]: 000 000 000 000 000 061 1075 090 1278 040 456 000 000 000 000 : 262529
[ 91 09 10 -- -- -- ]: 000 000 000 000 000 058 1034 064 1311 033 500 000 000 000 000 : 262727
[ 91 09 11 -- -- -- ]: 000 000 000 000 000 063 1024 083 1232 034 564 000 000 000 000 : 262842
[ 91 09 12 -- -- -- ]: 000 000 000 000 000 064 1016 078 1300 038 504 000 000 000 000 : 262744
[ 91 09 13 -- -- -- ]: 000 000 000 000 000 049 1048 090 1294 031 488 000 000 000 000 : 262674
[ 91 09 14 -- -- -- ]: 000 000 000 000 000 067 1070 085 1239 034 505 000 000 000 000 : 262618
[ 91 09 15 -- -- -- ]: 000 000 000 000 000 060 1070 081 1268 036 485 000 000 000 000 : 262605
[ 91 09 16 -- -- -- ]: 000 000 000 000 000 067 1058 078 1227 039 531 000 000 000 000 : 262706
[ 91 09 17 -- -- -- ]: 000 000 000 000 000 062 1060 087 1257 032 502 000 000 000 000 : 262643
[ 91 09 18 -- -- -- ]: 000 000 000 000 000 071 1039 078 1245 040 527 000 000 000 000 : 262725
[ 91 09 19 -- -- -- ]: 000 000 000 000 000 064 1044 088 1252 026 526 000 000 000 000 : 262710
[ 91 09 20 -- -- -- ]: 000 000 000 000 000 058 973 081 1310 045 533 000 000 000 000 : 262910
[ 91 09 21 -- -- -- ]: 000 000 000 000 000 066 1035 083 1262 020 534 000 000 000 000 : 262737
[ 91 09 22 -- -- -- ]: 000 000 000 000 000 061 1020 070 1300 047 502 000 000 000 000 : 262758
[ 91 09 23 -- -- -- ]: 000 000 000 000 000 066 1073 064 1249 039 509 000 000 000 000 : 262649
[ 91 09 24 -- -- -- ]: 000 000 000 000 000 059 1115 085 1198 038 505 000 000 000 000 : 262556
[ 91 09 25 -- -- -- ]: 000 000 000 000 000 061 1047 082 1266 042 502 000 000 000 000 : 262687
[ 91 09 26 -- -- -- ]: 000 000 000 000 000 067 1039 086 1263 022 523 000 000 000 000 : 262703
[ 91 09 27 -- -- -- ]: 000 000 000 000 000 073 1002 069 1317 033 506 000 000 000 000 : 262753
[ 91 09 28 -- -- -- ]: 000 000 000 000 000 060 1002 085 1319 027 507 000 000 000 000 : 262772
[ 91 09 29 -- -- -- ]: 000 000 000 000 000 054 1028 080 1238 043 557 000 000 000 000 : 262859
[ 91 09 30 -- -- -- ]: 000 000 000 000 000 060 976 084 1314 033 533 000 000 000 000 : 262883
[ 91 09 31 -- -- -- ]: 000 000 000 000 000 059 1064 091 1256 032 498 000 000 000 000 : 262632
[ 91 09 32 -- -- -- ]: 000 000 000 000 000 064 1049 076 1259 028 524 000 000 000 000 : 262710
[ 91 09 33 -- -- -- ]: 000 000 000 000 000 072 1049 084 1253 031 511 000 000 000 000 : 262655
[ 91 09 34 -- -- -- ]: 000 000 000 000 000 063 1026 077 1307 030 497 000 000 000 000 : 262706
[ 91 09 35 -- -- -- ]: 000 000 000 000 000 061 1056 095 1233 035 520 000 000 000 000 : 262685
[ 91 09 36 -- -- -- ]: 000 000 000 000 000 061 1090 077 1238 032 502 000 000 000 000 : 262596
[ 91 09 37 -- -- -- ]: 000 000 000 000 000 062 1031 080 1285 039 503 000 000 000 000 : 262717
[ 91 09 38 -- -- -- ]: 000 000 000 000 000 066 991 076 1294 040 533 000 000 000 000 : 262850
[ 91 09 39 -- -- -- ]: 000 000 000 000 000 078 1067 063 1264 040 488 000 000 000 000 : 262585
[ 91 09 40 -- -- -- ]: 000 000 000 000 000 076 1068 081 1265 029 481 000 000 000 000 : 262546
[ 91 09 41 -- -- -- ]: 000 000 000 000 000 057 1041 084 1321 031 466 000 000 000 000 : 262626
[ 91 09 42 -- -- -- ]: 000 000 000 000 000 056 1083 071 1307 025 458 000 000 000 000 : 262536
[ 91 09 43 -- -- -- ]: 000 000 000 000 000 076 1069 068 1308 035 444 000 000 000 000 : 262489
[ 91 09 44 -- -- -- ]: 000 000 000 000 000 065 1094 089 1272 025 455 000 000 000 000 : 262463
[ 91 09 45 -- -- -- ]: 000 000 000 000 000 076 1074 068 1320 031 431 000 000 000 000 : 262449
[ 91 09 46 -- -- -- ]: 000 000 000 000 000 069 1097 084 1273 040 437 000 000 000 000 : 262429
[ 91 09 47 -- -- -- ]: 000 000 000 000 000 057 1103 077 1284 036 443 000 000 000 000 : 262468
[ 91 09 48 -- -- -- ]: 000 000 000 000 000 069 1108 077 1243 025 478 000 000 000 000 : 262481
[ 91 09 49 -- -- -- ]: 000 000 000 000 000 067 1114 071 1270 035 443 000 000 000 000 : 262421
[ 91 09 50 -- -- -- ]: 000 000 000 000 000 066 1092 079 1292 033 438 000 000 000 000 : 262448
[ 91 09 51 -- -- -- ]: 000 000 000 000 000 066 1069 085 1246 027 507 000 000 000 000 : 262620
[ 91 09 52 -- -- -- ]: 000 000 000 000 000 057 1123 090 1266 024 440 000 000 000 000 : 262397
[ 91 09 53 -- -- -- ]: 000 000 000 000 000 057 1088 092 1244 031 488 000 000 000 000 : 262568
[ 91 09 54 -- -- -- ]: 000 000 000 000 000 065 1074 085 1300 032 444 000 000 000 000 : 262492
[ 91 09 55 -- -- -- ]: 000 000 000 000 000 067 1085 089 1311 030 418 000 000 000 000 : 262406
[ 91 09 56 -- -- -- ]: 000 000 000 000 000 083 1123 079 1238 025 452 000 000 000 000 : 262355
[ 91 09 57 -- -- -- ]: 000 000 000 000 000 065 1080 080 1304 041 430 000 000 000 000 : 262466
[ 91 09 58 -- -- -- ]: 000 000 000 000 000 069 1086 077 1261 032 475 000 000 000 000 : 262526
[ 91 09 59 -- -- -- ]: 000 000 000 000 000 068 1106 087 1301 033 405 000 000 000 000 : 262340
[ 91 09 60 -- -- -- ]: 000 000 000 000 000 077 1076 086 1246 027 488 000 000 000 000 : 262534
[ 91 09 61 -- -- -- ]: 000 000 000 000 000 067 1081 083 1287 030 452 000 000 000 000 : 262488
[ 91 09 62 -- -- -- ]: 000 000 000 000 000 054 1103 089 1278 037 439 000 000 000 000 : 262458
[ 91 09 63 -- -- -- ]: 000 000 000 000 000 057 1118 083 1255 027 460 000 000 000 000 : 262457
[ 91 09 64 -- -- -- ]: 000 000 000 000 000 069 1125 083 1277 027 419 000 000 000 000 : 262325
[ 91 09 65 -- -- -- ]: 000 000 000 000 000 055 1129 074 1280 034 428 000 000 000 000 : 262393
[ 91 09 66 -- -- -- ]: 000 000 000 000 000 073 1079 086 1307 023 432 000 000 000 000 : 262424
[ 91 09 67 -- -- -- ]: 000 000 000 000 000 072 1118 079 1220 035 476 000 000 000 000 : 262456
[ 91 09 68 -- -- -- ]: 000 000 000 000 000 067 1085 069 1278 039 462 000 000 000 000 : 262523
[ 91 09 69 -- -- -- ]: 000 000 000 000 000 060 1074 082 1300 030 454 000 000 000 000 : 262528
[ 91 09 70 -- -- -- ]: 000 000 000 000 000 068 1100 073 1235 025 499 000 000 000 000 : 262546
[ 91 09 71 -- -- -- ]: 000 000 000 000 000 068 1083 091 1312 030 416 000 000 000 000 : 262401
[ 91 09 72 -- -- -- ]: 000 000 000 000 000 066 1075 080 1279 029 471 000 000 000 000 : 262543
[ 91 09 73 -- -- -- ]: 000 000 000 000 000 068 1096 087 1278 036 435 000 000 000 000 : 262423
[ 91 09 74 -- -- -- ]: 000 000 000 000 000 067 1065 078 1270 034 486 000 000 000 000 : 262597
[ 91 09 75 -- -- -- ]: 000 000 000 000 000 064 1109 079 1249 034 465 000 000 000 000 : 262475
[ 91 09 76 -- -- -- ]: 000 000 000 000 000 058 1120 091 1263 029 439 000 000 000 000 : 262402
[ 91 09 77 -- -- -- ]: 000 000 000 000 000 055 1112 086 1247 031 469 000 000 000 000 : 262494
[ 91 09 78 -- -- -- ]: 000 000 000 000 000 084 1068 069 1287 024 468 000 000 000 000 : 262503
[ 91 09 79 -- -- -- ]: 000 000 000 000 000 067 1151 089 1255 023 415 000 000 000 000 : 262261
[ 91 09 80 -- -- -- ]: 000 000 000 000 000 053 1040 070 1274 046 517 000 000 000 000 : 262771
[ 91 09 81 -- -- -- ]: 000 000 000 000 000 072 1037 099 1289 029 474 000 000 000 000 : 262588
[ 91 09 82 -- -- -- ]: 000 000 000 000 000 069 1103 087 1217 035 489 000 000 000 000 : 262513
[ 91 09 83 -- -- -- ]: 000 000 000 000 000 065 1043 073 1298 041 480 000 000 000 000 : 262647
[ 91 09 84 -- -- -- ]: 000 000 000 000 000 072 1103 082 1272 026 445 000 000 000 000 : 262412
[ 91 09 85 -- -- -- ]: 000 000 000 000 000 073 1102 077 1286 034 428 000 000 000 000 : 262390
[ 91 09 86 -- -- -- ]: 000 000 000 000 000 076 1042 083 1322 026 451 000 000 000 000 : 262533
[ 91 09 87 -- -- -- ]: 000 000 000 000 000 062 1093 086 1280 021 458 000 000 000 000 : 262479
[ 91 09 88 -- -- -- ]: 000 000 000 000 000 063 1089 086 1262 036 464 000 000 000 000 : 262511
[ 91 09 89 -- -- -- ]: 000 000 000 000 000 070 1074 079 1294 027 456 000 000 000 000 : 262502
[ 91 09 90 -- -- -- ]: 000 000 000 000 000 064 1087 073 1271 036 469 000 000 000 000 : 262535
[ 91 09 91 -- -- -- ]: 000 000 000 000 000 063 1101 079 1286 034 437 000 000 000 000 : 262438
[ 91 09 92 -- -- -- ]: 000 000 000 000 000 073 1066 082 1299 036 444 000 000 000 000 : 262491
[ 91 09 93 -- -- -- ]: 000 000 000 000 000 060 1072 086 1311 029 442 000 000 000 000 : 262503
[ 91 09 94 -- -- -- ]: 000 000 000 000 000 073 1097 086 1240 024 480 000 000 000 000 : 262485
[ 91 09 95 -- -- -- ]: 000 000 000 000 000 075 1115 079 1264 035 432 000 000 000 000 : 262365
[ 91 09 96 -- -- -- ]: 000 000 000 000 000 064 1099 079 1326 026 406 000 000 000 000 : 262369
[ 91 09 97 -- -- -- ]: 000 000 000 000 000 069 1058 079 1313 037 444 000 000 000 000 : 262523
[ 91 09 98 -- -- -- ]: 000 000 000 000 000 069 1079 073 1274 031 474 000 000 000 000 : 262541
[ 91 09 99 -- -- -- ]: 000 000 000 000 000 072 1074 089 1259 029 477 000 000 000 000 : 262530
0: 20 = 262910
1: 30 = 262883
2: 29 = 262859
3: 38 = 262850
4: 11 = 262842
5: 01 = 262780
6: 28 = 262772
7: 80 = 262771
8: 22 = 262758
9: 27 = 262753
10: 05 = 262752
11: 12 = 262744
12: 21 = 262737
13: 07 = 262733
14: 10 = 262727
15: 18 = 262725
16: 37 = 262717
17: 02 = 262713
18: 19 = 262710
19: 32 = 262710
20: 34 = 262706
21: 16 = 262706
22: 26 = 262703
23: 00 = 262702
24: 25 = 262687
pin[2] candidate: 20 with latency 262910
Candidate PIN 0x91 0x09 0x20 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 658 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 1233.74 seconds
done
Resetting all ECUs.
- RickHaleParker
- Been thanked: 958 times
Shoot no wonder the 2011 not working. No sufficient difference in latency.
Increase BUCKETS_PER_US, for better resolution? Then hope for the best ..
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
For me it looks like to much noise on the can bus, i dont trust this 3,3V transceivers.
This is mcp original with 16mhz crystall and the buckets are much better sorted with less noise.
Code: Select all
1000 pins in 717 ms, 1394 pins/s
00 00 00 00 00 00: 000 000 295 000 2414 000 2099 000 192 000 000 000 000 : 434376
01 00 00 00 00 00: 000 000 304 000 2366 000 2134 000 196 000 000 000 000 : 434444
02 00 00 00 00 00: 000 000 353 000 2216 000 2226 000 205 000 000 000 000 : 434566
03 00 00 00 00 00: 000 000 373 000 2238 000 2180 000 209 000 000 000 000 : 434450
04 00 00 00 00 00: 000 000 359 000 2184 000 2263 000 194 000 000 000 000 : 434584
05 00 00 00 00 00: 000 000 375 000 2186 000 2230 000 209 000 000 000 000 : 434546
06 00 00 00 00 00: 000 000 342 000 2240 000 2235 000 183 000 000 000 000 : 434518
07 00 00 00 00 00: 000 000 360 000 2129 000 2314 000 197 000 000 000 000 : 434696
08 00 00 00 00 00: 000 000 348 001 2147 000 2295 000 209 000 000 000 000 : 434729
09 00 00 00 00 00: 000 000 333 000 2259 000 2198 000 210 000 000 000 000 : 434570
10 00 00 00 00 00: 000 000 352 000 2172 001 2234 000 241 000 000 000 000 : 434729
11 00 00 00 00 00: 000 000 351 000 2150 001 2266 000 232 000 000 000 000 : 434759
12 00 00 00 00 00: 000 000 377 002 2145 001 2267 000 208 000 000 000 000 : 434611
13 00 00 00 00 00: 000 000 354 000 2243 000 2189 000 214 000 000 000 000 : 434526
14 00 00 00 00 00: 000 000 370 000 2178 000 2226 000 226 000 000 000 000 : 434616
15 00 00 00 00 00: 000 000 415 000 2172 000 2204 000 209 000 000 000 000 : 434414
16 00 00 00 00 00: 000 000 380 000 2140 000 2259 000 221 000 000 000 000 : 434642
17 00 00 00 00 00: 000 000 370 000 2201 000 2199 000 230 000 000 000 000 : 434578
18 00 00 00 00 00: 000 000 321 000 2112 000 2357 000 210 000 000 000 000 : 434912
19 00 00 00 00 00: 000 000 347 000 2214 000 2241 000 198 000 000 000 000 : 434580
20 00 00 00 00 00: 000 000 304 000 2360 000 2149 000 187 000 000 000 000 : 434438
21 00 00 00 00 00: 000 000 148 000 2159 000 2214 000 479 000 000 000 000 : 436048
22 00 00 00 00 00: 000 000 399 000 2055 000 2290 000 256 000 000 000 000 : 434806
23 00 00 00 00 00: 000 000 375 000 2079 000 2326 000 220 000 000 000 000 : 434782
24 00 00 00 00 00: 000 000 369 000 2081 001 2337 000 212 000 000 000 000 : 434785
25 00 00 00 00 00: 000 000 368 000 2126 000 2296 000 210 000 000 000 000 : 434696
26 00 00 00 00 00: 000 000 383 000 2086 000 2313 000 218 000 000 000 000 : 434732
27 00 00 00 00 00: 000 000 385 000 2149 000 2228 000 238 000 000 000 000 : 434638
28 00 00 00 00 00: 000 000 380 000 2105 000 2299 000 216 000 000 000 000 : 434702
29 00 00 00 00 00: 000 000 365 000 2129 000 2235 000 271 000 000 000 000 : 434824
30 00 00 00 00 00: 000 000 344 000 2196 000 2250 000 210 000 000 000 000 : 434652
31 00 00 00 00 00: 000 000 405 000 2121 001 2243 000 230 000 000 000 000 : 434597
32 00 00 00 00 00: 000 000 403 000 2138 000 2253 000 206 000 000 000 000 : 434524
33 00 00 00 00 00: 000 000 406 000 2183 000 2207 000 204 000 000 000 000 : 434418
34 00 00 00 00 00: 000 000 354 000 2122 000 2317 000 207 000 000 000 000 : 434754
35 00 00 00 00 00: 000 000 350 000 2163 000 2252 000 235 000 000 000 000 : 434744
36 00 00 00 00 00: 000 000 357 000 2115 000 2292 000 236 000 000 000 000 : 434814
37 00 00 00 00 00: 000 000 358 000 2097 000 2345 000 200 000 000 000 000 : 434774
38 00 00 00 00 00: 000 000 364 000 2104 000 2324 000 208 000 000 000 000 : 434752
39 00 00 00 00 00: 000 000 370 000 2280 000 2142 000 208 000 000 000 000 : 434376
40 00 00 00 00 00: 000 000 339 000 2232 000 2214 000 215 000 000 000 000 : 434610
41 00 00 00 00 00: 000 001 387 000 2273 000 2157 000 182 000 000 000 000 : 434265
42 00 00 00 00 00: 000 000 349 000 2318 001 2110 000 222 000 000 000 000 : 434411
43 00 00 00 00 00: 000 000 344 000 2321 000 2148 000 187 000 000 000 000 : 434356
44 00 00 00 00 00: 000 000 371 000 2297 000 2134 000 198 000 000 000 000 : 434318
45 00 00 00 00 00: 000 000 320 000 2265 000 2214 000 201 000 000 000 000 : 434592
46 00 00 00 00 00: 000 000 346 000 2302 000 2133 000 219 000 000 000 000 : 434450
47 00 00 00 00 00: 000 000 325 000 2334 000 2135 000 206 000 000 000 000 : 434444
48 00 00 00 00 00: 000 000 391 000 2301 002 2126 000 180 000 000 000 000 : 434192
49 00 00 00 00 00: 000 000 316 001 2319 000 2161 000 203 000 000 000 000 : 434501
50 00 00 00 00 00: 000 000 366 000 2211 000 2211 000 212 000 000 000 000 : 434538
51 00 00 00 00 00: 000 000 322 001 2318 000 2150 000 209 000 000 000 000 : 434491
52 00 00 00 00 00: 000 000 357 000 2289 000 2157 000 197 000 000 000 000 : 434388
53 00 00 00 00 00: 000 000 320 000 2266 000 2188 000 226 000 000 000 000 : 434640
54 00 00 00 00 00: 000 000 393 000 2316 000 2077 000 214 000 000 000 000 : 434224
55 00 00 00 00 00: 000 000 342 000 2262 000 2180 000 216 000 000 000 000 : 434540
56 00 00 00 00 00: 000 000 364 000 2289 000 2162 000 185 000 000 000 000 : 434336
57 00 00 00 00 00: 000 000 328 000 2349 001 2117 000 205 000 000 000 000 : 434399
58 00 00 00 00 00: 000 000 336 000 2294 000 2157 000 213 000 000 000 000 : 434494
59 00 00 00 00 00: 000 000 329 000 2276 000 2192 000 203 000 000 000 000 : 434538
60 00 00 00 00 00: 000 000 359 000 2196 000 2255 000 190 000 000 000 000 : 434552
61 00 00 00 00 00: 000 000 320 000 2306 000 2161 000 213 000 000 000 000 : 434534
62 00 00 00 00 00: 000 000 367 000 2282 000 2139 001 211 000 000 000 000 : 434391
63 00 00 00 00 00: 000 000 308 000 2356 000 2151 000 185 000 000 000 000 : 434426
64 00 00 00 00 00: 000 000 341 000 2310 000 2163 000 186 000 000 000 000 : 434388
65 00 00 00 00 00: 000 000 326 000 2358 000 2095 000 221 000 000 000 000 : 434422
66 00 00 00 00 00: 000 000 376 000 2278 000 2153 000 193 000 000 000 000 : 434326
67 00 00 00 00 00: 000 000 334 000 2293 001 2156 000 216 000 000 000 000 : 434509
68 00 00 00 00 00: 000 000 357 000 2234 000 2201 000 208 000 000 000 000 : 434520
69 00 00 00 00 00: 000 000 350 000 2348 000 2106 000 196 000 000 000 000 : 434296
70 00 00 00 00 00: 000 000 369 000 2256 000 2180 000 195 000 000 000 000 : 434402
71 00 00 00 00 00: 000 000 349 000 2336 001 2091 000 223 000 000 000 000 : 434377
72 00 00 00 00 00: 000 000 366 000 2280 000 2137 000 217 000 000 000 000 : 434410
73 00 00 00 00 00: 000 000 313 000 2310 000 2171 000 206 000 000 000 000 : 434540
74 00 00 00 00 00: 000 000 357 000 2286 000 2157 000 200 000 000 000 000 : 434400
75 00 00 00 00 00: 000 000 329 000 2240 000 2231 000 200 000 000 000 000 : 434604
76 00 00 00 00 00: 000 000 389 000 2279 000 2133 000 199 000 000 000 000 : 434284
77 00 00 00 00 00: 000 000 339 000 2320 000 2125 000 216 000 000 000 000 : 434436
78 00 00 00 00 00: 000 000 369 000 2358 000 2085 000 188 000 000 000 000 : 434184
79 00 00 00 00 00: 000 000 341 000 2238 001 2209 000 211 000 000 000 000 : 434581
80 00 00 00 00 00: 000 000 360 000 2122 001 2295 000 222 000 000 000 000 : 434759
81 00 00 00 00 00: 000 000 360 000 2178 001 2277 000 184 000 000 000 000 : 434571
82 00 00 00 00 00: 000 000 332 000 2226 000 2222 000 220 000 000 000 000 : 434660
83 00 00 00 00 00: 000 000 360 000 2137 000 2275 000 228 000 000 000 000 : 434742
84 00 00 00 00 00: 000 000 390 000 2278 000 2125 000 207 000 000 000 000 : 434298
85 00 00 00 00 00: 000 000 324 000 2392 000 2082 000 202 000 000 000 000 : 434324
86 00 00 00 00 00: 000 000 385 000 2275 000 2142 000 198 000 000 000 000 : 434306
87 00 00 00 00 00: 000 000 311 000 2359 000 2125 000 205 000 000 000 000 : 434448
88 00 00 00 00 00: 000 000 360 000 2338 000 2119 000 183 000 000 000 000 : 434250
89 00 00 00 00 00: 000 000 317 000 2380 001 2103 000 199 000 000 000 000 : 434369
90 00 00 00 00 00: 000 000 384 000 2248 001 2148 000 219 000 000 000 000 : 434405
91 00 00 00 00 00: 000 000 313 000 2305 000 2162 000 220 000 000 000 000 : 434578
92 00 00 00 00 00: 000 000 402 000 2241 000 2149 000 208 000 000 000 000 : 434326
93 00 00 00 00 00: 000 000 306 000 2408 000 2055 000 231 000 000 000 000 : 434422
94 00 00 00 00 00: 000 000 340 000 2412 000 2059 000 189 000 000 000 000 : 434194
95 00 00 00 00 00: 000 000 325 000 2375 000 2077 000 223 000 000 000 000 : 434396
96 00 00 00 00 00: 000 000 359 000 2238 000 2195 000 208 000 000 000 000 : 434504
97 00 00 00 00 00: 000 000 309 000 2418 000 2052 000 221 000 000 000 000 : 434370
98 00 00 00 00 00: 000 000 324 000 2364 000 2122 000 190 000 000 000 000 : 434356
99 00 00 00 00 00: 000 000 301 000 2388 000 2102 000 209 000 000 000 000 : 434438
0: 21 = 436048
1: 18 = 434912
2: 29 = 434824
3: 36 = 434814
4: 22 = 434806
5: 24 = 434785
6: 23 = 434782
7: 37 = 434774
8: 11 = 434759
9: 80 = 434759
10: 34 = 434754
11: 38 = 434752
12: 35 = 434744
13: 83 = 434742
14: 26 = 434732
15: 08 = 434729
16: 10 = 434729
17: 28 = 434702
18: 07 = 434696
19: 25 = 434696
20: 82 = 434660
21: 30 = 434652
22: 16 = 434642
23: 53 = 434640
24: 27 = 434638
pin[0] candidate: 21 lat 436048
21 00 00 00 00 00: 000 000 133 000 2240 000 2124 000 503 000 000 000 000 : 435994
21 01 00 00 00 00: 000 000 095 000 2261 000 2149 000 495 000 000 000 000 : 436088
21 02 00 00 00 00: 000 000 131 000 2228 000 2149 000 492 000 000 000 000 : 436004
21 03 00 00 00 00: 000 000 116 001 2269 000 2118 000 496 000 000 000 000 : 435987
21 04 00 00 00 00: 000 000 125 000 2212 000 2158 000 505 000 000 000 000 : 436086
21 05 00 00 00 00: 000 000 136 000 2301 000 2089 000 474 000 000 000 000 : 435802
21 06 00 00 00 00: 000 000 117 001 2341 000 2056 000 485 000 000 000 000 : 435817
21 07 00 00 00 00: 000 000 133 000 2244 000 2108 000 515 000 000 000 000 : 436010
21 08 00 00 00 00: 000 000 135 000 2258 000 2131 000 476 000 000 000 000 : 435896
21 09 00 00 00 00: 000 000 117 000 2252 000 2134 000 497 000 000 000 000 : 436022
21 10 00 00 00 00: 000 000 129 000 2255 000 2112 000 504 000 000 000 000 : 435982
21 11 00 00 00 00: 000 000 115 001 2232 000 2134 000 518 000 000 000 000 : 436109
21 12 00 00 00 00: 000 000 128 000 2281 000 2096 000 495 000 000 000 000 : 435916
21 13 00 00 00 00: 000 000 116 000 2280 000 2125 000 479 000 000 000 000 : 435934
21 14 00 00 00 00: 000 000 126 000 2207 000 2172 000 495 000 000 000 000 : 436072
21 15 00 00 00 00: 000 000 108 000 2254 000 2137 000 501 000 000 000 000 : 436062
21 16 00 00 00 00: 000 000 118 000 2204 000 2174 000 504 000 000 000 000 : 436128
21 17 00 00 00 00: 000 000 096 000 2256 001 2120 000 527 000 000 000 000 : 436157
21 18 00 00 00 00: 000 000 111 001 2275 000 2145 000 468 000 000 000 000 : 435939
21 19 00 00 00 00: 000 000 103 000 2285 000 2112 000 500 000 000 000 000 : 436018
21 20 00 00 00 00: 000 000 111 000 2266 000 2142 000 481 000 000 000 000 : 435986
21 21 00 00 00 00: 000 000 110 000 2272 000 2152 000 466 000 000 000 000 : 435948
21 22 00 00 00 00: 000 000 101 000 2252 001 2164 000 482 000 000 000 000 : 436055
21 23 00 00 00 00: 000 000 110 000 2242 000 2144 000 504 000 000 000 000 : 436084
21 24 00 00 00 00: 000 000 112 000 2319 000 2091 000 478 000 000 000 000 : 435870
21 25 00 00 00 00: 000 000 138 000 2281 000 2101 000 480 000 000 000 000 : 435846
21 26 00 00 00 00: 000 000 114 000 2258 000 2134 000 494 000 000 000 000 : 436016
21 27 00 00 00 00: 000 000 118 001 2263 000 2133 000 485 000 000 000 000 : 435969
21 28 00 00 00 00: 000 000 123 000 2294 000 2084 000 499 000 000 000 000 : 435918
21 29 00 00 00 00: 000 000 140 000 2298 000 2138 000 424 000 000 000 000 : 435692
21 30 00 00 00 00: 000 000 113 000 2277 000 2167 000 443 000 000 000 000 : 435880
21 31 00 00 00 00: 000 000 140 000 2246 000 2138 000 476 000 000 000 000 : 435900
21 32 00 00 00 00: 000 000 110 000 2283 000 2119 000 488 000 000 000 000 : 435970
21 33 00 00 00 00: 000 000 107 000 2308 000 2083 000 502 000 000 000 000 : 435960
21 34 00 00 00 00: 000 000 117 000 2237 000 2123 000 523 000 000 000 000 : 436104
21 35 00 00 00 00: 000 000 088 000 2284 000 2162 000 466 000 000 000 000 : 436012
21 36 00 00 00 00: 000 000 107 000 2283 000 2128 000 482 000 000 000 000 : 435970
21 37 00 00 00 00: 000 000 119 000 2274 000 2123 000 484 000 000 000 000 : 435944
21 38 00 00 00 00: 000 000 127 000 2235 000 2125 000 513 000 000 000 000 : 436048
21 39 00 00 00 00: 000 000 136 000 2207 000 2150 000 507 000 000 000 000 : 436056
21 40 00 00 00 00: 000 000 133 000 2197 000 2177 000 493 000 000 000 000 : 436060
21 41 00 00 00 00: 000 000 125 000 2196 000 2190 000 489 000 000 000 000 : 436086
21 42 00 00 00 00: 000 000 111 001 2284 000 2119 000 485 000 000 000 000 : 435955
21 43 00 00 00 00: 000 000 127 000 2201 001 2191 000 480 000 000 000 000 : 436049
21 44 00 00 00 00: 000 001 113 000 2312 000 2066 000 508 000 000 000 000 : 435935
21 45 00 00 00 00: 000 000 093 000 2340 000 2098 000 469 000 000 000 000 : 435886
21 46 00 00 00 00: 000 000 120 000 2251 000 2139 000 490 000 000 000 000 : 435998
21 47 00 00 00 00: 000 000 110 000 2295 000 2067 000 528 000 000 000 000 : 436026
21 48 00 00 00 00: 000 000 123 000 2230 000 2141 000 506 000 000 000 000 : 436060
21 49 00 00 00 00: 000 000 114 000 2343 000 2095 000 448 000 000 000 000 : 435754
21 50 00 00 00 00: 000 000 097 000 2273 000 2161 000 469 000 000 000 000 : 436004
21 51 00 00 00 00: 000 000 119 000 2233 000 2148 000 500 000 000 000 000 : 436058
21 52 00 00 00 00: 000 000 120 000 2260 000 2158 000 462 000 000 000 000 : 435924
21 53 00 00 00 00: 000 000 125 000 2255 000 2155 000 465 000 000 000 000 : 435920
21 54 00 00 00 00: 000 000 125 000 2201 000 2200 000 474 000 000 000 000 : 436046
21 55 00 00 00 00: 000 000 115 000 2287 000 2115 001 482 000 000 000 000 : 435931
21 56 00 00 00 00: 000 000 095 000 2290 000 2140 000 475 000 000 000 000 : 435990
21 57 00 00 00 00: 000 000 116 000 2320 000 2086 000 478 000 000 000 000 : 435852
21 58 00 00 00 00: 000 000 114 000 2278 000 2093 000 515 000 000 000 000 : 436018
21 59 00 00 00 00: 000 000 113 000 2277 000 2126 000 484 000 000 000 000 : 435962
21 60 00 00 00 00: 000 000 113 000 2253 000 2148 000 486 000 000 000 000 : 436014
21 61 00 00 00 00: 000 000 117 001 2322 000 2068 000 492 000 000 000 000 : 435869
21 62 00 00 00 00: 000 000 111 000 2280 000 2116 000 493 000 000 000 000 : 435982
21 63 00 00 00 00: 000 000 127 000 2240 000 2108 000 525 000 000 000 000 : 436062
21 64 00 00 00 00: 000 000 125 001 2273 000 2120 000 481 000 000 000 000 : 435913
21 65 00 00 00 00: 000 000 115 000 2336 000 2079 000 470 000 000 000 000 : 435808
21 66 00 00 00 00: 000 000 000 000 2096 000 2202 001 701 000 000 000 000 : 437211
21 67 00 00 00 00: 000 000 085 001 2259 000 2180 000 475 000 000 000 000 : 436089
21 68 00 00 00 00: 000 000 131 000 2260 000 2108 000 501 000 000 000 000 : 435958
21 69 00 00 00 00: 000 000 134 000 2292 000 2071 000 503 000 000 000 000 : 435886
21 70 00 00 00 00: 000 000 111 000 2242 000 2138 000 509 000 000 000 000 : 436090
21 71 00 00 00 00: 000 000 132 000 2274 000 2092 000 502 000 000 000 000 : 435928
21 72 00 00 00 00: 000 000 117 000 2302 000 2102 000 479 000 000 000 000 : 435886
21 73 00 00 00 00: 000 000 111 000 2340 000 2073 000 476 000 000 000 000 : 435828
21 74 00 00 00 00: 000 000 121 000 2308 000 2090 000 481 000 000 000 000 : 435862
21 75 00 00 00 00: 000 000 116 000 2250 000 2152 000 482 000 000 000 000 : 436000
21 76 00 00 00 00: 000 000 089 000 2230 000 2160 001 520 000 000 000 000 : 436225
21 77 00 00 00 00: 000 000 118 000 2284 000 2092 000 506 000 000 000 000 : 435972
21 78 00 00 00 00: 000 000 114 001 2277 000 2095 000 513 000 000 000 000 : 436013
21 79 00 00 00 00: 000 000 122 000 2321 000 2077 000 480 000 000 000 000 : 435830
21 80 00 00 00 00: 000 000 130 000 2232 000 2184 000 454 000 000 000 000 : 435924
21 81 00 00 00 00: 000 000 099 000 2273 000 2105 000 523 000 000 000 000 : 436104
21 82 00 00 00 00: 000 000 135 000 2280 000 2086 000 499 000 000 000 000 : 435898
21 83 00 00 00 00: 000 000 124 000 2253 000 2122 000 501 000 000 000 000 : 436000
21 84 00 00 00 00: 000 000 122 000 2327 000 2069 000 482 000 000 000 000 : 435822
21 85 00 00 00 00: 000 000 124 000 2219 000 2155 000 502 000 000 000 000 : 436070
21 86 00 00 00 00: 000 000 115 001 2247 000 2130 000 507 000 000 000 000 : 436057
21 87 00 00 00 00: 000 000 119 000 2273 000 2123 000 485 000 000 000 000 : 435948
21 88 00 00 00 00: 000 000 109 000 2341 000 2096 000 454 000 000 000 000 : 435790
21 89 00 00 00 00: 000 000 113 000 2274 000 2125 000 488 000 000 000 000 : 435976
21 90 00 00 00 00: 000 000 119 000 2259 000 2141 000 481 000 000 000 000 : 435968
21 91 00 00 00 00: 000 000 124 000 2294 000 2108 000 474 000 000 000 000 : 435864
21 92 00 00 00 00: 000 000 110 000 2328 000 2073 000 489 000 000 000 000 : 435882
21 93 00 00 00 00: 000 000 109 000 2340 000 2097 000 454 000 000 000 000 : 435792
21 94 00 00 00 00: 000 000 096 000 2302 000 2106 000 496 000 000 000 000 : 436004
21 95 00 00 00 00: 000 000 121 000 2237 000 2166 000 476 000 000 000 000 : 435994
21 96 00 00 00 00: 000 000 135 000 2251 000 2113 000 501 000 000 000 000 : 435960
21 97 00 00 00 00: 000 000 127 000 2251 000 2147 000 475 000 000 000 000 : 435940
21 98 00 00 00 00: 000 000 118 000 2272 000 2107 000 503 000 000 000 000 : 435990
21 99 00 00 00 00: 000 000 101 000 2274 000 2138 000 487 000 000 000 000 : 436022
0: 66 = 437211
1: 76 = 436225
2: 17 = 436157
3: 16 = 436128
4: 11 = 436109
5: 81 = 436104
6: 34 = 436104
7: 70 = 436090
8: 67 = 436089
9: 01 = 436088
10: 41 = 436086
11: 04 = 436086
12: 23 = 436084
13: 14 = 436072
14: 85 = 436070
15: 63 = 436062
16: 15 = 436062
17: 48 = 436060
18: 40 = 436060
19: 51 = 436058
20: 86 = 436057
21: 39 = 436056
22: 22 = 436055
23: 43 = 436049
24: 38 = 436048
pin[1] candidate: 66 lat 437211
21 66 00 00 00 00: 000 000 000 000 2212 000 2125 000 663 000 000 000 000 : 436902
21 66 01 00 00 00: 000 000 000 000 2276 000 2025 000 699 000 000 000 000 : 436846
21 66 02 00 00 00: 000 000 000 000 2201 000 2212 000 587 000 000 000 000 : 436772
21 66 03 00 00 00: 000 000 000 000 2212 001 2288 000 499 000 000 000 000 : 436573
21 66 04 00 00 00: 000 000 000 000 2253 000 2167 000 580 000 000 000 000 : 436654
21 66 05 00 00 00: 000 000 000 000 2259 000 2189 000 552 000 000 000 000 : 436586
21 66 06 00 00 00: 000 000 000 000 2258 000 2145 000 597 000 000 000 000 : 436678
21 66 07 00 00 00: 000 000 000 000 2238 000 2276 000 486 000 000 000 000 : 436496
21 66 08 00 00 00: 000 000 000 000 2252 000 2160 000 588 000 000 000 000 : 436672
21 66 09 00 00 00: 000 000 000 000 2211 000 2226 000 563 000 000 000 000 : 436704
21 66 10 00 00 00: 000 000 000 000 2151 000 2248 000 601 000 000 000 000 : 436900
21 66 11 00 00 00: 000 000 000 000 2247 000 2219 000 534 000 000 000 000 : 436574
21 66 12 00 00 00: 000 000 000 000 2112 000 2384 000 504 000 000 000 000 : 436784
21 66 13 00 00 00: 000 000 000 000 2226 000 2211 000 563 000 000 000 000 : 436674
21 66 14 00 00 00: 000 000 000 000 2185 000 2252 000 563 000 000 000 000 : 436756
21 66 15 00 00 00: 000 000 000 000 2194 001 2249 000 556 000 000 000 000 : 436723
21 66 16 00 00 00: 000 000 000 000 2248 000 2216 000 536 000 000 000 000 : 436576
21 66 17 00 00 00: 000 000 000 000 2192 000 2234 000 574 000 000 000 000 : 436764
21 66 18 00 00 00: 000 000 000 000 2254 000 2208 000 538 000 000 000 000 : 436568
21 66 19 00 00 00: 000 000 000 001 2242 001 2200 000 556 000 000 000 000 : 436624
21 66 20 00 00 00: 000 000 000 000 2203 000 2107 000 690 000 000 000 000 : 436974
21 66 21 00 00 00: 000 000 000 000 1918 000 2397 000 685 000 000 000 000 : 437534
21 66 22 00 00 00: 000 000 000 001 2117 000 2335 000 547 000 000 000 000 : 436857
21 66 23 00 00 00: 000 000 000 000 2240 001 2283 000 476 000 000 000 000 : 436471
21 66 24 00 00 00: 000 000 000 000 2219 000 2263 000 518 000 000 000 000 : 436598
21 66 25 00 00 00: 000 000 000 000 2203 000 2286 000 511 000 000 000 000 : 436616
21 66 26 00 00 00: 000 000 000 000 2211 000 2282 000 507 000 000 000 000 : 436592
21 66 27 00 00 00: 000 000 000 000 2211 000 2280 000 509 000 000 000 000 : 436596
21 66 28 00 00 00: 000 000 000 000 2198 000 2288 000 514 000 000 000 000 : 436632
21 66 29 00 00 00: 000 000 000 000 2209 000 2281 000 510 000 000 000 000 : 436602
21 66 30 00 00 00: 000 000 000 000 2242 000 2161 001 596 000 000 000 000 : 436709
21 66 31 00 00 00: 000 000 000 000 2235 000 2244 000 521 000 000 000 000 : 436572
21 66 32 00 00 00: 000 000 000 001 2194 000 2281 000 524 000 000 000 000 : 436657
21 66 33 00 00 00: 000 000 000 000 2232 000 2209 000 559 000 000 000 000 : 436654
21 66 34 00 00 00: 000 000 000 000 2203 000 2233 000 564 000 000 000 000 : 436722
21 66 35 00 00 00: 000 000 000 000 2176 000 2281 000 543 000 000 000 000 : 436734
21 66 36 00 00 00: 000 000 000 000 2267 000 2188 000 545 000 000 000 000 : 436556
21 66 37 00 00 00: 000 000 000 001 2196 000 2244 000 559 000 000 000 000 : 436723
21 66 38 00 00 00: 000 000 000 000 2218 000 2203 000 579 000 000 000 000 : 436722
21 66 39 00 00 00: 000 000 000 000 2324 000 2123 000 553 000 000 000 000 : 436458
21 66 40 00 00 00: 000 000 000 001 2226 000 2310 000 463 000 000 000 000 : 436471
21 66 41 00 00 00: 000 000 000 001 2187 000 2296 000 516 000 000 000 000 : 436655
21 66 42 00 00 00: 000 000 000 000 1989 000 2276 000 735 000 000 000 000 : 437492
21 66 43 00 00 00: 000 000 000 000 2030 000 2293 000 677 000 000 000 000 : 437294
21 66 44 00 00 00: 000 000 000 000 2135 000 2252 000 613 000 000 000 000 : 436956
21 66 45 00 00 00: 000 000 000 000 1996 000 2310 000 694 000 000 000 000 : 437396
21 66 46 00 00 00: 000 000 000 000 2017 000 2268 000 715 000 000 000 000 : 437396
21 66 47 00 00 00: 000 000 000 000 2166 000 2272 000 562 000 000 000 000 : 436792
21 66 48 00 00 00: 000 000 000 000 2187 000 2248 000 565 000 000 000 000 : 436756
21 66 49 00 00 00: 000 000 000 001 2054 000 2291 000 654 000 000 000 000 : 437197
21 66 50 00 00 00: 000 000 000 000 2216 000 2321 000 463 000 000 000 000 : 436494
21 66 51 00 00 00: 000 000 000 000 1990 001 2305 000 704 000 000 000 000 : 437427
21 66 52 00 00 00: 000 000 000 000 2013 000 2278 000 709 000 000 000 000 : 437392
21 66 53 00 00 00: 000 000 000 000 2071 000 2274 000 655 000 000 000 000 : 437168
21 66 54 00 00 00: 000 000 000 000 2064 000 2319 000 617 000 000 000 000 : 437106
21 66 55 00 00 00: 000 000 000 000 2003 000 2278 000 719 000 000 000 000 : 437432
21 66 56 00 00 00: 000 000 000 000 2028 000 2302 000 670 000 000 000 000 : 437284
21 66 57 00 00 00: 000 000 000 000 2143 000 2322 000 535 000 000 000 000 : 436784
21 66 58 00 00 00: 000 000 000 000 2206 000 2287 000 507 000 000 000 000 : 436602
21 66 59 00 00 00: 000 000 000 000 2008 000 2293 000 699 000 000 000 000 : 437382
21 66 60 00 00 00: 000 000 000 000 2189 000 2304 000 507 000 000 000 000 : 436636
21 66 61 00 00 00: 000 000 000 000 2118 000 2279 000 603 000 000 000 000 : 436970
21 66 62 00 00 00: 000 000 000 000 2099 000 2267 000 634 000 000 000 000 : 437070
21 66 63 00 00 00: 000 000 000 000 2177 000 2241 000 582 000 000 000 000 : 436810
21 66 64 00 00 00: 000 000 000 000 2136 000 2306 000 558 000 000 000 000 : 436844
21 66 65 00 00 00: 000 000 000 000 2073 000 2289 000 638 000 000 000 000 : 437130
21 66 66 00 00 00: 000 000 000 000 2087 000 2287 000 626 000 000 000 000 : 437078
21 66 67 00 00 00: 000 000 000 000 2200 000 2247 000 553 000 000 000 000 : 436706
21 66 68 00 00 00: 000 000 000 000 2151 000 2331 000 518 000 000 000 000 : 436734
21 66 69 00 00 00: 000 000 000 000 2126 000 2317 000 557 000 000 000 000 : 436862
21 66 70 00 00 00: 000 000 000 000 2127 000 2378 000 495 000 000 000 000 : 436736
21 66 71 00 00 00: 000 000 000 001 2153 000 2242 000 604 000 000 000 000 : 436899
21 66 72 00 00 00: 000 000 000 000 2193 000 2290 000 517 000 000 000 000 : 436648
21 66 73 00 00 00: 000 000 000 000 2183 000 2294 000 523 000 000 000 000 : 436680
21 66 74 00 00 00: 000 000 000 000 2181 000 2330 000 489 000 000 000 000 : 436616
21 66 75 00 00 00: 000 000 000 000 2113 000 2328 000 559 000 000 000 000 : 436892
21 66 76 00 00 00: 000 000 000 000 2111 000 2337 000 552 000 000 000 000 : 436882
21 66 77 00 00 00: 000 000 000 000 2273 000 2244 000 483 000 000 000 000 : 436420
21 66 78 00 00 00: 000 000 000 001 2221 000 2304 000 474 000 000 000 000 : 436503
21 66 79 00 00 00: 000 000 000 000 2225 000 2314 000 461 000 000 000 000 : 436472
21 66 80 00 00 00: 000 000 000 000 2199 000 2292 000 509 000 000 000 000 : 436620
21 66 81 00 00 00: 000 000 000 000 2173 000 2345 000 482 000 000 000 000 : 436618
21 66 82 00 00 00: 000 000 000 000 2265 000 2152 000 583 000 000 000 000 : 436636
21 66 83 00 00 00: 000 000 000 000 2200 000 2289 000 511 000 000 000 000 : 436622
21 66 84 00 00 00: 000 000 000 000 2072 000 2298 000 630 000 000 000 000 : 437116
21 66 85 00 00 00: 000 000 000 000 2001 000 2296 000 703 000 000 000 000 : 437404
21 66 86 00 00 00: 000 000 000 000 2226 000 2350 000 424 000 000 000 000 : 436396
21 66 87 00 00 00: 000 000 000 000 2135 000 2322 000 543 000 000 000 000 : 436816
21 66 88 00 00 00: 000 000 000 000 2137 000 2289 001 573 000 000 000 000 : 436873
21 66 89 00 00 00: 000 000 000 000 2005 000 2316 000 679 000 000 000 000 : 437348
21 66 90 00 00 00: 000 000 000 000 2211 000 2315 000 474 000 000 000 000 : 436526
21 66 91 00 00 00: 000 000 000 000 1995 000 2286 000 719 000 000 000 000 : 437448
21 66 92 00 00 00: 000 000 000 000 2230 000 2315 000 455 000 000 000 000 : 436450
21 66 93 00 00 00: 000 000 000 000 2080 000 2293 000 627 000 000 000 000 : 437094
21 66 94 00 00 00: 000 000 000 000 2049 000 2294 000 657 000 000 000 000 : 437216
21 66 95 00 00 00: 000 000 000 000 2029 000 2306 000 665 000 000 000 000 : 437272
21 66 96 00 00 00: 000 000 000 000 2192 000 2389 000 419 000 000 000 000 : 436454
21 66 97 00 00 00: 000 000 000 000 2146 000 2298 000 556 000 000 000 000 : 436820
21 66 98 00 00 00: 000 000 000 000 2173 000 2348 000 479 000 000 000 000 : 436612
21 66 99 00 00 00: 000 000 000 000 2011 000 2303 000 686 000 000 000 000 : 437350
0: 21 = 437534
1: 42 = 437492
2: 91 = 437448
3: 55 = 437432
4: 51 = 437427
5: 85 = 437404
6: 45 = 437396
7: 46 = 437396
8: 52 = 437392
9: 59 = 437382
10: 99 = 437350
11: 89 = 437348
12: 43 = 437294
13: 56 = 437284
14: 95 = 437272
15: 94 = 437216
16: 49 = 437197
17: 53 = 437168
18: 65 = 437130
19: 84 = 437116
20: 54 = 437106
21: 93 = 437094
22: 66 = 437078
23: 62 = 437070
24: 20 = 436974- repair
- Year and Model: S60 II 2015
- Has thanked: 2 times
- Been thanked: 3 times
Are you experimenting with finding pin on one block and the same flash area?
If so, I can send you a dump of flash on which the cracker cannot find pin, and not just me.
I sent it to 2 participants in this forum and we all had a negative result with this dump.
Therefore, the presence of noise or the use of non-original chips is not yet the fact of a successful or unsuccessful search for a pin.
Volvo S40, V40, V50, V60, S60, S80, V70, XC60, XC70, XC90, C30, C70 - Р1, Р2, Р3, 1998 - 2016 - language replacement DIM, ICM, PHM.
T5Luke
Noise has effect on pin finding, if you have the same noise over all bytes, it will have no difference on the average cause the teensy searches for the highest average. But if noise differs on different bytes this will cause bad results. Also the average method is not the only method to find the correct byte. If you have measurements without noise, you can see right bytes very clear like here:
On the first byte:
If you look through the row you see a big shift to higher latencys, byte 21 as with 148 counts less then the half counts as byte 20.
With 479 counts at 89us it has much more later counts.
The first byte is not so clear. But look to the 2nd:
Measurements in us: 80us 83us
Here you see the very clear gap, which i see an all my tries. Byte 66 gives no response within 83us. With this gap you can be very certain you got the right byte and stop the finding for 2nd byte.
With much noise in you can't be certain about the 2nd byte...
On the first byte:
- repair
But in addition to these problematic dumps from versions H, which with most other dumps - from blocks L versions, the pin is determined very quickly, even with SAMPLES 10.
And this is all with the same chipset at the cracker.
How can you explain all this?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I recently got a straight CEM (-2004) donation from a fellow Volvo enthusiast. Waiting for K-Line chips, should be there any day.
Also yesterday tried to use the cracker on C30, and it failed, and I could not figure out what is wrong, so I got the same p/n off ebay. Should take time to ship from Poland to US.
vtl
The code must detect the latency jitter that is produced by 3 compare instructions and 3 conditional jumps. The prime latency is in Renesas M32C's (or Motorola's) clock domain, which is then converted to the clock domain of CAN. CAN's tick is much-much longer than M32C tick, the latency jitter is gone in most cases by the time the reply begins its travel over wires. But not in all. By sending hundreds-thousands of same samples these rare outliers still can be detected in software, and this is what we do.
Now, the attack method relies on the constant execution time of the rest of the CEM code. The only extra latency produced by the CEM must come from the PIN comparison routine. This approach proved to work fairly well in a large share of cases. However there's something different in other cases (where the case is the CEM software revision), where the PIN detection sees equal or random distribution for all bytes, thus the outlier is not detected.
I have a theory this is due to variation in execution time of the CEM code path outside of PIN comparison, but too lazy to proof it - it would require spending too much time reading the disassembled code. I'm splitting my free time mostly between laying out hardwood floor, fixing Volvo that, frankly, does not need to be moving at all and debating with wife whether I truly need a plasma cutter.
- 6431 Views
Last post by RickHaleParker
- 8699 Views
Last post by forumoto
