engine not sitting right in engine bay
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Re: engine not sitting right in engine bay
Post by bmdubya1198 »
That's very possible that they sent you the wrong rack. Check for any identification stamps/marks on it.
bmdubya1198
Hate to bump this thread, but I’m pondering the way my S70’s engine sits... it looks to be crooked. It’s been sitting like this since I dropped it in last year, but I hadn’t worried about it until I’m really looking at it again. Am I remembering correctly that you figured this out?
I’m thinking it may have something to do with the passenger side engine mount.
Has thanked: 1505 times
Been thanked: 3817 times
There is a chassis break on the front engine mount , on the passenger side of the car, so if you grabbed one from the parts bin......😀
Good news is the 1999- one is the cheap one. I think I would stay Volvo here
bmdubya1198
I have to double check that today. I wouldn’t be surprised if I somehow ended up with the wrong one.
bmdubya1198
So that PN is for the front engine mount bracket, on the front of the subframe. All I can think is that a PO had used the bracket from the 2001 V70 the engine came from (the engine I had replaced was previously replaced). 01 P2 bracket PN is 8649262. It’s visually different, so I’ll double check that tomorrow. I’m pretty certain I have a P80 bracket on there, though.
As far as the side engine mount bracket (front of engine, below crank pulley) this is what I found on VIDA...
01 (P2) bracket is PN 8683931
2000 (P80) bracket is PN 9135179 for -1377795
2000 P80 bracket is PN 9180961 for 1377796-
As far as the mount itself, there are a TON of numbers for P80s. The two relevant to my VIN (sequence number starts with 6 something) 9480189 (ALTER 2 S70 FC1 565001-, FC2 566269-) and 9480191 (ALTER 1, S70 FC1 565001-). Both are still available. It seems the -191 PN is for cars with 4 bolt control arms, so -189 is the correct one for this car.
Will update with my findings.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 335 times
Post by Chuck W »
When we put the '02 motor in the wife's '97 GLT, I'm pretty sure I left the P2 bracket on the engine and used the -189 mount.
bmdubya1198
Chuck W wrote: 16 Apr 2021, 21:37 When we put the '02 motor in the wife's '97 GLT, I'm pretty sure I left the P2 bracket on the engine and used the -189 mount.
Good to know! So it should be the same if your engine isn’t crooked.
I know it’s subtle, but unless I’m going nuts this engine is definitely askew.
Maybe measure these two distances and I’ll measure on my 2000 to see what’s askew?
Chuck W
Post by Chuck W »
That does look off.
A little hard to compare with the current set-up in her car, as we reinstalled the "N" bits, but I don't recall anything being off when we put it back together. I know I wasn't happy to have to buy the more expensive PS motor mount, as we had just installed a new one of the older type a few months before the engine swap.
bmdubya1198
Yeah, your engine definitely looks to be sitting straight int the engine bay. I’ll check these measurements today.
