Bench testers take note of that.3r1k wrote: 27 Apr 2021, 13:12 Are you planning to interface via the diagnostic-canbus lines on the CEM (pins 11,12,15,16) without any other can-devices attached? When I tried to do this I never got it to work when no other canbus nodes where connected to the network, instead I had to hook up my canbus-shield to any of the other "real" canbus lines on the CEM and add 120 ohm termination.
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
sparacis
- Year and Model: 2009 C30
- Been thanked: 2 times
Just got a 2008 p1 cem from the local pick and pull to play with as well, really want to be able to pull CEM dumps from the OBD2 port if possible but working with an xprog now to pull the dumps via solder connections
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
When you have P2 on bench, connect pin 8 to +12V and pin 15 to +12V, this makes CEM stay in lock pos 1 and doesn't fall asleep, guess you need to find the same pins in P1.
T5Luke
You need to write your own bootloader for this, when the problems are solved with P2 i will give it a try with P1 but the CPUs of this both CEMs are very different as the brands are...sparacis wrote: 27 Apr 2021, 14:21 Just got a 2008 p1 cem from the local pick and pull to play with as well, really want to be able to pull CEM dumps from the OBD2 port if possible but working with an xprog now to pull the dumps via solder connections
- RickHaleParker
Do you mean pins D:8 & D:15 which are power from the Ignition switch?T5Luke wrote: 27 Apr 2021, 14:22 When you have P2 on bench, connect pin 8 to +12V and pin 15 to +12V, this makes CEM stay in lock pos 1 and doesn't fall asleep, guess you need to find the same pins in P1.
If so: A:17 & A:42 on the P1 are the equivalent to D:5 & D:15 on the P2-L & P2-H.
Active
Past
Past
- RickHaleParker
Project name?
ODIN ( Open Diagnostic INterface ).
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
P1 CEM with P2 code path, but no shuffle:
In the very first pass. I'm killing the dedicated P1 code.
Code: Select all
CPU Maximum Frequency: 600000000
CPU Frequency: 600000000
Execution Rate: 600 cycles/us
Platform: P2
PIN bytes to measure: 3
Number of samples: 30
CAN high-speed init done.
CAN low-speed init done.
Initialization done.
Putting all ECUs into programming mode.
K-Line keep alive
---> ID=000ffffe data=ff 86 00 00 00 00 00 00
K-Line keep alive
K-Line keep alive
K-Line keep alive
K-Line keep alive
Reading part number from ECU 0x50
---> ID=000ffffe data=50 88 00 00 00 00 00 00
<--- ID=00000003 data=50 8e 00 00 31 25 49 03
Part Number: 000031254903
found PIN: 0x24 0x99 0x68 0x94 0x27 0x69
PIN is cracked in 945.54 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
---> ID=000ffffe data=ff c8 00 00 00 00 00 00
---> ID=000ffffe data=ff c8 00 00 00 00 00 00-
- 9659 Views
Last post by RickHaleParker
- 9864 Views
- 27 Replies
- 30511 Views
Last post by cn90
- 10 Replies
- 11524 Views
Last post by jonesg
- 6598 Views
