Vibration at idle and acceleration after hitting a deer
mrjay62
Year and Model: V70XC 2002
Been thanked: 3 times
Re: Vibration at idle and acceleration after hitting a deer
Post by mrjay62 »
Well guys After replacing all the motor and subframe mounts and bushings it feels like the vibration is a little worse.
Not sure what more I can check, starting to feel like it's in the engine -(maybe)
I've checked the compression all cylinders in the 180s all coils and fuel injectors are contributing. Locked the Cams and checked the timing - still spot on. Check for vacuum leaks - none found.
Lost now...
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
what do other people say?
has anyone else felt it.
You say you broke your back and have neck problems.
maybe ask an indie to throw it up on a lift and assess it.
mrjay62
Post by mrjay62 »
So far no one has said anything..
I live in the boonies.
If it's not a Ford,Chevy, Dodge pickup or a John deere no one close by that I would trust...
And wouldn't take it to a dealership in the city..
I found one vacuum check valve that works sometimes I have to dig out a replacement I know I have somewhere...
That's all I have so far.
Didn't break my back just 3 vertebrae my neck had plates put in to repair the vertebrae but it was too late nerve damage was done.
2 years later I had a triple fusion in my neck done stupid idea.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Can you make a video of your engine when it is shaking? Place a jug of beer on top of it, so we could see the waves.
mrjay62
Post by mrjay62 »
Sure.. I can do that...
mrjay62
Post by mrjay62 »
Don't know how to attach a video comes up invalid.
1st 2 picture are after idle dropped to 750 rpm.
Next 2ND 2 is vacuum check valve I replaced, its for a Saab that works good on my tractor.
mrjay62
Post by mrjay62 »
Went Thu backwards and upside down. ??
mrjay62
Post by mrjay62 »
This is in gear.. drive.
To me in drive it's a little worse rpm doesn't drop when in drive...
Last thing I can think of is the strut upper mounts..
jonesg
Post by jonesg »
mrjay62 wrote: 03 May 2021, 08:56 So far no one has said anything..
same here, up in northern Maine.
vtl
Post by vtl »
I've tested with beer only, which apparently has a different viscosity, but I think the waves here are excessive indeed. I'll try to make another video later today, now with water.
