Well guys After replacing all the motor and subframe mounts and bushings it feels like the vibration is a little worse.
Not sure what more I can check, starting to feel like it's in the engine -(maybe)
I've checked the compression all cylinders in the 180s all coils and fuel injectors are contributing. Locked the Cams and checked the timing - still spot on. Check for vacuum leaks - none found.
Lost now...
Vibration at idle and acceleration after hitting a deer
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
what do other people say?
has anyone else felt it.
You say you broke your back and have neck problems.
maybe ask an indie to throw it up on a lift and assess it.
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
So far no one has said anything..
I live in the boonies.
If it's not a Ford,Chevy, Dodge pickup or a John deere no one close by that I would trust...
And wouldn't take it to a dealership in the city..
I found one vacuum check valve that works sometimes I have to dig out a replacement I know I have somewhere...
That's all I have so far.
Didn't break my back just 3 vertebrae my neck had plates put in to repair the vertebrae but it was too late nerve damage was done.
2 years later I had a triple fusion in my neck done stupid idea.
mrjay62
Don't know how to attach a video comes up invalid.
1st 2 picture are after idle dropped to 750 rpm.
Next 2ND 2 is vacuum check valve I replaced, its for a Saab that works good on my tractor.
- jonesg
same here, up in northern Maine.mrjay62 wrote: ↑03 May 2021, 08:56 So far no one has said anything..
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I've tested with beer only, which apparently has a different viscosity, but I think the waves here are excessive indeed. I'll try to make another video later today, now with water.
