My temp guage pegged today while idling before I was getting ready to leave. Temp outside is almost 90F. I shut it off, popped the hood, and let it cool off. I did notice the upper radiator hose was extremely hot and the lower radiator hose was still cold.
My question is would this be the water pump, thermostat, or possibly something else? Even if the thermostat didn't open wouldn't there still be heat in the lower radiator hose? Any help would be greatly appreciated.
Thermostat or water pump bad?
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
Sounds easy enough to do. Is there a way to keep from losing too much coolant when I swap the thermostat?
- gnalan
I see the stock Volvo one is set at 90C, Vaico is set at 87C, and Mahle is set at 92C, all from FCPEuro. Has anyone tried any of the other two besides the Volvo one, or a different one from anywhere else? If so did you notice any difference in gas mileage, or engine performance?
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
Let the engine get warm at idle and turn on the heater (yes, and don't look at 90F outside). If you get HOT air, then water pump is OK and thermostat is the prime suspect. But not the only.
If my English is bad, please correct me
- gnalan
The temp guage pegs as soon as I start it. The engine is cold and the hoses are cold. Could it be a bad sensor? Where is it located at?
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
You stated that one hose is hotter that the other right? That could be a sign that your radiator has hit the end of it's life.
Here's the right radiator for your model, and they also have a cheaper one for $105
https://www.fcpeuro.com/products/volvo- ... 0-31319056
I think the best course of action is to let a dedicated independent volvo mechanic take a look; they should tell you what's going on.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Look closer at the two wires going to the coolant temp sensor connector on the stat housing. Or maybe the sensor is shot
- gnalan
This is with the engine cold, and not running. The key is in position 2. Looks more like a sensor or wiring issue. I'm in the process of replacing my starter, and removed the two rear nuts holding the starter to the bracket on the engine block. I didn't have a problem before that, and I was removing the nuts with my arm wedged in between the power steering line and the intake manifold. I'm assuming from looking at the wiring that it runs along the block under the intake manifold and connects around the starter? Maybe I bumped something loose, or one or both of the wires are grounding out on the block causing the needle to peg. Any thoughts? I'd rather not pull the intake manifold off, but I'll have more access when the starter is removed probably this weekend. It's raining right now, and if there's a problem other than the sensor I don't want to drive it into the barn to work on it out of the rain. I really don't want to blow the engine.
- 24 Replies
- 5308 Views
Last post by XC70Rider
- 5091 Views
Last post by kallekula
- 2168 Views
- 1407 Views
Last post by e777
- 240 Views
Last post by pinegrovedave
