2004 Xc70 cross county
Alex5150
Year and Model: 2004 xc 70
Post by Alex5150 »
It was hot 108 degrees . iwas driving then bam ! It felt like i ran over something. Then everything turned off . then the car turned on . but i had no lights no dash lights..no power windows . but i could still drive ibut it didnt have the power it normally had. But i was able to get it back home the whole time it kept flipping on to normal with lites and power then back off. With no lites and no power and ran slow like it wasnt running on all cylinders. It did it once before when got really hot over 100 degrees
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Almost seems like your battery is possibly dying. Check your voltage after sitting overnight and do a load test. Post your voltage here after sitting overnight, and while alternator is running. It does seem power related though. I have known batteries which are dying or have little fluid left in the cells to die on very hot days.
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
mine did similar on a very hot day, the ECM was over heating.
It helps to run the A/C as the cooling fan in the computer box draws its air supply from inside the cabin.
