mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
cuhfs wrote: 26 Jun 2021, 16:48 You can easily recover from this situation. and Be sure to Rotate the crank 2 times around by hand to be sure you are back in time. Robert DIY has other timing vids too.
Thank you. I was sweating bullets.
Used to have a 01 c70 convertible
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I really want to try Ospho, I've heard it's great stuff. I'm going to order some to fix some surface rust in my E30 where the floor isn't too far gone.
mdr1220 wrote: 26 Jun 2021, 20:07
Yeah, it's a trial and error process. No need to worry about valve damage unless the engine is run with it out of alignment.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Tackled the tank vent issue in the wife's GLT today.
Trans jack came in handy, mainly for stability, as I asked my wife to not fill up her car this week until after I took care of this. There was maybe 3-4 gallons in there.
Once the tank was dropped, I was able to get my eyes on the issue. It wasn't the big "s" hose (but I knew that already), but instead rodents had chewed a good 3/4" of vent hose apart at some point in the past.
Got that tended to and replaced the "s" hose, since I was in there and I had one. Was a mild hassle, as the hose clamp on the smaller end was oriented so the screw head was on the bottom of the hose and pointed at the fuel line fittings on top of the tank. Took a little finagling to get that loose, but easy enough outside of that.
All together (I vacuumed out the rodent debris after I took the pic)
That's out of the way now (after a good 4-5 years of ownership)
mdr1220
Post by mdr1220 »
I'm f***ed. One of the exhaust cam bolts snapped as I was rotating the cam to line back up with the marks.
mdr1220
Post by mdr1220 »
Damn!
Damn!
Is this a brick now?
Has thanked: 2200 times
Been thanked: 1852 times
Thanks Foggydogg. Funny how some things don't really change. We used to use phosphoric acid to clean rust on our cars 45+ years ago. Worked pretty well as it turned the remaining rust black and neutralised it.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
mdr1220 wrote: 27 Jun 2021, 13:10 One of the exhaust cam bolts snapped as I was rotating the cam to line back up with the marks.
Take the pulley off and back out the broken bolt with Liquid Wrench and Left hand drill bits.
The idea is to get the Left hand drill bit to bite and turn the bolt not cut it. A Left hand drill bit turns and cuts counterclockwise. You turn a bolt counterclockwise to remove it. Once the bit has enough bite in the bolt it should turn the bolt rather then cut it.
The Liquid Wrench is to lubricate the threads, reduce the friction and keep from burning the drill tip. Go slow on the drill.
Active
Past
mdr1220
Post by mdr1220 »
Will PB blaster be a good substitute? This is what I have at home.
RickHaleParker
scot850 wrote: 27 Jun 2021, 13:38 We used to use phosphoric acid to clean rust on our cars 45+ years ago.
Phosphoric Acid a ingredient in some Rust converters. Phosphoric acid converts some iron oxides into an inert layer of ferric phosphate.
The main ingredient in rust converters is Tannic Acid which converts iron oxides into Ferric Tannate which is stable and acts as a protective.
One of my dads favorite chemicals was Water Glass ( Sodium Silicate ). He had all kinds of uses for that. Including emergency Head Gasket repair.
Active
Past
Chuck W
Post by Chuck W »
mdr1220 wrote: 27 Jun 2021, 15:07 Will PB blaster be a good substitute? This is what I have at home.
Are you sure it's actually even seized in there? What were you doing when it snapped?
