Electric Floor Jack Topic is solved
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: Electric Floor Jack
Post by MoVolvos »
Oka wrote: 01 Jul 2021, 09:16
BlackBart wrote: 30 Jun 2021, 18:26 No, tell us more. It has to be electrically operated hydraulic I assume, to use small motion to lift large weight....?
Here's a YouTube typical video. Seems it's just for 12V battery operated; does not have a combination of AC also.
I still like it with it's only 12V. Will be very convenient for me.
https://www.youtube.com/watch?v=jq0yizqa2iw
I consider these as portable emergency use only.
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
jonesg wrote: 01 Jul 2021, 13:28 $120 to jack your car.
I used to use an 18v drill to drive my scissor jack, it was a lot faster.
You made a good point about the cost versus the alternate of using a scissors jack with a drill. I don't think I have used a scissors jack in the last twenty-five years or more. I went from a small floor jack to the 3-ton floor jack. It is quick but kinda bulky.
Oka
Post by Oka »
MoVolvos wrote: 01 Jul 2021, 17:18
Another good point.
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Oka wrote: 01 Jul 2021, 11:42Thanks about the caution!
I currently have a nice high capacity floor jack. I have NEVER EVER jacked the vehicle up, without two jack stands, no matter, even for a quick work. I’m always paranoid about fails. None of my past and present Jack’s have ever failed, but jack stands are always used.
My big floor jack is probably 30 years old now. Never even think about it. I never go under a car without jack stands, and I leave the jack under slight pressure as well. Recently I was under there studying something, and I heard that funny loud TINK sound from the jack....... Another time I heard the weight settling slightly on the jack stands. Hmm... It might be time to rebuild this jack I thought.
I can see this electric jack as something quick to just change tires or brakes, plus keep it in the trunk for emergencies. I had the factory scissor jack slip out on ice and collapse (blown tire on the side of the road). Broke the plastic rocker trim on my 850 as it fell, but not on me thankfully.
Has thanked: 1507 times
Been thanked: 3823 times
With the rash of recalls on Jack stands ive gone to triple redundancy if I am going underneath
Jack
Jack stands
Wood cribbing
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
About $120 in 2x4s and screws. Well, I drunk a whole 12-pack (+$16) while converting the lumber and screws into the jack stands - it was a long night =)
Floor jack and HiLift I had already. Gives 23" of ground clearance, enough for 16" tall transmission on 5" tall dolly. Very safe.
Oka
Post by Oka »
Sure the 12-pack was not right before working on the vehicle. LOL
What a setup you have there. What car is that, and what are you doing to it?
Oka
Post by Oka »
Have made up my mind not to bother with the power jack, with respect to the cost.
vtl
Post by vtl »
Oka wrote: 03 Jul 2021, 12:32 Sure the 12-pack was not right before working on the vehicle. LOL
05 XC70, swapping the transmission with a DIY rebuilt one.
vtl wrote: 03 Jul 2021, 12:55
Are you set for an engine brace to lower the engine amd trans? Could meet you halfway sometime if you want to borrow it. In Albany.
