Electric Floor Jack Topic is solved
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: Electric Floor Jack
Post by vtl »
abscate wrote: 04 Jul 2021, 04:40 Are you set for an engine brace to lower the engine amd trans? Could meet you halfway sometime if you want to borrow it. In Albany.
Thanks, much appreciated! I do have an engine support bar and a cherry picker.
vtl
Post by vtl »
Didn't want to drain coolant, so it took twice longer, thanks to the upper bell housing bolt (the one hidden behind crankshaft position sensor).
Lifting the car 23" was way-way over, it actually made everything much harder, since I could not reach the bolts from beneath laying flat on my back, without some prolonged 6-pack workout (not the one 6-pack I like). 20" would do it, I think.
My 5k miles old, barely driven collar sleeve started to loose teeth shape already, with a new angle gear ("new", but with perfect teeth)! :( I think I will replace it with GP one, which is tempered better, as I've heard.
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Your garage mid-project looks a lot like my garage mid-project. Except I would likely have a small pond of fluid spreading out across the floor.
vtl
Post by vtl »
I've had my ATF puddle wiped off - see a darker concrete below the radiators? =)
BlackBart
Post by BlackBart »
Nothing better than slimey smelly ATF on everything.....
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
BlackBart wrote: 04 Jul 2021, 22:38 Your garage mid-project looks a lot like my garage mid-project. Except I would likely have a small pond of fluid spreading out across the floor.
when I lived in Boston, I would have considered that to be a Garagemahal.
Anything to get out of the snow or blistering hot sunlight .
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Oka wrote: 03 Jul 2021, 12:35
MoVolvos wrote: 01 Jul 2021, 17:18
Oka wrote: 01 Jul 2021, 09:16
Here's a YouTube typical video. Seems it's just for 12V battery operated; does not have a combination of AC also.
I still like it with it's only 12V. Will be very convenient for me.
https://www.youtube.com/watch?v=jq0yizqa2iw
I consider these as portable emergency use only.
Have made up my mind not to bother with the power jack, with respect to the cost.
Good decision! Without 12V it's useless also.
