V70 won’t start. Out of ideas.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Re: V70 won’t start! Out of ideas, please help!
Post by volvolugnut »
These plugs do not look to be a problem for soot, but the gap looks wide. Did you gap the new plugs? Proper gap for this engine is 0.7 mm (0.028 inch). Yes, it is small, but that is what the turbo gap should be.
Vaswamp
Year and Model: 2001 V70 T5
Post by Vaswamp »
My dumb a** did not. They looked similar to the old ones and it didn’t start before I changed, so I marked that off my list.
Thanks again volvolugnut. I’m going to pull them all in the morning and test the gap.
I’ll update them, hope to update you with better news….thanks again!
Good luck tomorrow!
Vaswamp
Post by Vaswamp »
Update. It finally turned over!! Great news, but now it runs like a dog and I’ve got these codes:
p0201 p0202 p0203 p0204 p0205
Any ideas? Assuming I forgot something here, I know I’m close to fixing this thing.
Thanks again!
Vaswamp
Post by Vaswamp »
I should add a re-gapped all the plugs. I shouldn’t have trusted the “oem pre gapped” claim from advance auto. Thanks volvolugnut!
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
Injector circuit,
you never said if the car was left in the rain with the hood open, if it was then you should check the computer box next to the coolant bottle. Water on the ECM contacts would play havoc such as you have now. Same for the fuses and relays in the engine bay.
Vaswamp
Post by Vaswamp »
No water got into those areas, thankfully I had waterproof pads over both sides. I checked my ecu relay, it’s opening and resistance checks out.
Thanks for your help.
Vaswamp wrote: 25 Jul 2021, 09:14 Update. It finally turned over!! Great news, but now it runs like a dog and I’ve got these codes:
Thanks again!
Google all those codes to see what they are. Then search this forum for likely causes.
A quick check shows problem with all of the injectors. Another post talked of loose injector connections. Check that the injector connections are dry and secure.
jonesg
Post by jonesg »
Vaswamp wrote: 25 Jul 2021, 11:18 No water got into those areas, thankfully I had waterproof pads over both sides. I checked my ecu relay, it’s opening and resistance checks out.
Ok then, back probe the injector connectors and monitor whilst cranking or running, should be ...what ? 5 v?
The injector connectors can easily allow water to flow down into the socket, unplug a couple and look for moisture.
Vaswamp
Post by Vaswamp »
3.46 Volta at cranking on each injector connector.
