Pic didn't do it justice. It wasn't just under the console, it was everywhere. My guess is spilled drink - at least that's what I told myself.bmdubya1198 wrote: ↑11 Aug 2021, 10:55 Yuck! It's nasty how much crap gets built up down there. I bet those new parts will feel much better!
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
A little steering fluid stuck to my accessory belt. I ordered a new one from my dealer. I disassembled the whole steering pump system to access the alternator but the one I had planned to replace (from a 1998 V70 diesel) is not compatible. So I took the opportunity to clean and degrease everything, I reassembled the alternator and power steering pump, reconnected everything and tomorrow I'll put the new belt. I was too tired to finish.
After that, a good wash at Meguiars and on the way to the test drive, then the refueling.
A question, anyway : This part is to be fix under the steering pump, with the screw of the bracket, right ? Manov
- foggydogg
Dealing with the steering rack; it froze up solid while I was driving it. Kept it out of the weeds - barely.
Found this.
Found this.
- Has thanked: 305 times
- Been thanked: 517 times
Woah, was that the result of it locking up or did you hit something that damaged the rack before? Time for a new subframe!
- Has thanked: 1506 times
- Been thanked: 3822 times
Ooof, that’s bad
- foggydogg
The car is new to me, first time under it; this feature was pre-installed.bmdubya1198 wrote: ↑11 Aug 2021, 16:19 Woah, was that the result of it locking up or did you hit something that damaged the rack before? Time for a new subframe!
Has lots of new stuff, poorly done.
Managed to keep it on the pavement during the Excitement.
- foggydogg
Just got a spreader bar for the floor jack; once I have a man-to-man chat with my back I'll finish dropping it and regroup.
- foggydogg
Curios, with that big a whump, that the airbags didn't blow.
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Well yesterday I finally finished replacement control arms, ball joints and sway bar endlink on the xc90. I will absolutely need an alignment as the wheel is off position and the passenger wheel is visibly toed out. At the end of the jon I was torquing all the bolts according to "googling" and 1 source said to tightened the ballpoint knuckle bolts to 74 ft-lbs. Dont do it!. I snapped a bolt real easy and luckly the old bolts were in perfect shape. I was able to use an ez out to extract the broken piece surprisingly quickly.. I just tightened them by hand after that and called it a day.
