squeel under hood
squeel under hood
After driving, noted a squeel under the hood. Not real loud. All fluids fine. After cooling off, started and ran fine. No squeel. All belts appear to be in good condition. There was no indicator of overheating. The sound was not very noticable in the car. From outside the car it was noticable.
- Has thanked: 927 times
- Been thanked: 1000 times
How old are your idler pulleys? They can get old and before they die make noise. If they fail, they can take out your belts and do major damage when the valves hit pistons.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Most likely the horses under the hood seem to be unhappy at times when you hear the squeal.
I suggest you also check your PCV system, it's probably a failing diaphragm causing excessive vacuum in the crankcase
This is a known premature failure on our 4-cyl. engines.
Hope this helps
Hope this helps
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 32 Replies
- 5037 Views
Last post by MrAl
- 1174 Views
Last post by flatlander84
