240 Jumping Voltmeter
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
warmblood58
Year and Model: 1989 245
Has thanked: 5 times
Post by warmblood58 »
I am having a intermittent problem with spiking voltage - I cleaned battery ground and removed the quick disconnect that had been installed by previous owner hoping that this might have been culprit but no go. My volt meter will be fine and then suddenly start spiking, lights increase in brightness, blower speed increases . . . any ideas as to what would cause this situation? Thanks!
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
You likely have a bad voltage regulator on the alternator. With some soldering skills and the part you do not need to replace the alternator. Do something soon before you have other damage.
warmblood58
I think I may have found the problem - fuse panel was powdered up with light corrosion so I dremeled the contacts with a brass wire wheel and also cleaned the contact ends of the fuses - so far so good!
