Yes, you can blow through the mesh from the valve body suction side port and I tried this way first, air and cleaner repeatedly, It worked for about 100 miles before the filter clogged up again. I think it just open up a small area of the clogged filter surface. The bottle brush contacting and scrubbing the mesh surface was needed to loosen the friction fibers stuck to the mesh, I was surprised how well the crud was clinging to the mesh. With the brush I was also able to reach and clean a much larger area of the filter mesh. You do need the access hole for the brush method though.
Is it time for a new automatic gearbox ?
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Re: Is it time for a new automatic gearbox ?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 605 times
Right, that's why I mentioned kerosene under pressure
Just a cleaner spray is not enough.
Maybe even heated low viscous ATF under pressure to avoid ATF dilution with non-ATF liquid?
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
How's the transmission working with declogged filter? Like normal again or does it still have some hiccups? That's a lot of clutch material coming from somewhere.
BMW 540i 2002
S70 Base 2000
- Has thanked: 1500 times
- Been thanked: 3810 times
I think there are a couple of years on the “ punched out filter” thread now.
Key is keep up with your drain and fills if you don’t have a filter
- firstv70volvo
greffel
- Year and Model: 2003 S60
- Has thanked: 11 times
- Been thanked: 7 times
Huge thanks everyone…
My gearbox is now working again, but let's give it a couple of days before I celebrate
Purchased the M14 x 1.25 oil plug from my local Volvo dealer
Borrowed the M14 tap and a tool to get a nice even surface from work ( called a Granlund in Swedish
I didn't invest in a inspection camera so I cant say how clean the filter got, but now its quite easy to do the process all over again.
If this works it must have been the cheapest repair so far.
Used the measurement 31mm and 25.5 and that was perfect position to get in to the filter
Polestar 2 - All electric daily driver
S60 2.5T AWD with a little bit more power
- firstv70volvo
Nice work and good to hear your gearbox is working again. Just curious, before the filter clogged up completely you originally had problems with a 3-4 shift delay/flare, did this shift problem get any better with the filter cleaning?
Did you use a bottle brush to clean the filter mesh?
greffel
The first 20 min of the test drive I was driving quite slow and the flare was gone
I used a straw cleaning brush and bottle brush and lost of Breakleen ....
- firstv70volvo
Yes, there will need to be some adaptation time needed because it probably was adapted to a lower pressure from a gradually clogging filter.greffel wrote: ↑15 Oct 2021, 12:06The first 20 min of the test drive I was driving quite slow and the flare was gone
Did you use a bottle brush to clean the filter mesh?Did a harder acceleration close to home and the flare was back but maybe a little bit better. Let's give it a couple of days to settle, the downshifts and some up shifts feels a little bit rough. Might need to re adapt to new pressure.
greffel
The car is still working just "fine".....but now to the bad news.
It's almost impossible to explain with my poor English, and it won't show on a move clip
But changing to 4th gear the car now vibrates for a second as the shift is preformed.
This hole thing started when I did manual shift to 4th gear from 5 on a uphill.
Could that have slipped the clutch that much that the filter clogged immediately ?
I have driven with a flaring gearbox 3 to 4 almost 2 years....
Have looked at a lot of tear down videos lately of the AW55
I feel quite confident I can rebuild the gearbox with good instructions....
But what should I get?
