Nevada1906 1995 850 S60R m56 build thread
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
volvolugnut wrote: 16 Oct 2021, 18:16
Nevada1906 wrote: 13 Oct 2021, 19:50
volvolugnut wrote: 13 Oct 2021, 19:45
I can be humorless and well as clueless...
Nah, I've just got a real Jack Webb style of delivery.
It appears I am also blind and cannot read. I just noticed you have always had the tag line about zip ties.
Apologies.
You have a great engine build going together.
No problem, and thanks!
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Nevada1906
Next step: The PCV lines.
This Genuine Volvo system for the 2004 S60R is available from either FCPEuro or IPD, and it costs about $370.
It consists of two lines: The red line is for coolant and the blue line is for air.
36060 - A.jpg (60.15 KiB) Viewed 611 times
I am NOT paying almost four hundred bucks for a couple of pipes. Whoever set those prices must've been smoking the good stuff - you know, the stuff that makes you hallucinate Fat Elvis driving a freight train made of pineapples.
So I just need a couple of lines, one of which can handle moderately-hot liquid. Okay, I can do that. Lowe's plumbing section to the rescue.
This line has to run from this nipple on the thermostat housing to this banjo fitting (not shown) on the back of the head.
I'll flare the ends of the resulting line, blast it with some high-temp clearcoat and join it to the fittings with rad hose. Simple. Throw a couple of insulated clamps on it to hold it in place and done. I'm not sure about the air line yet. I'll probably see what McMaster-Carr has in the way of plastic line. So for probably $70-$90 bucks, I've solved the problem.
$400. They don't think much of us, do they?
Nevada1906
Addendum.
I know that the lines I'm replacing are a $200 part, instead of $400 for the whole kit. That's still outrageous.
Besides, I'd rather make the new lines myself.
Nevada1906
Moving on to the coolant bypass line.
I measured the tubing, cut it to length and taped it. Obviously this is just the mockup. I still have to solder the lines together, flare the ends and get some insulated brackets to hold the line securely.
Been thanked: 4068 times
You just introduced a big surface area of Cu into your Aluminum cooling system. I wonder where the more chemically active Aluminum will erode??
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Nice work! That hose is outrageously priced, and that's one reason we don't typically replace those with the PCV job on these '99+ engines. They usually don't fail, being aluminum hoses. That certainly doesn't mean they can't be clogged though.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
abscate wrote: 17 Oct 2021, 16:29 You just introduced a big surface area of Cu into your Aluminum cooling system. I wonder where the more chemically active Aluminum will erode??
In the thin, expensive parts of the radiator?
I really don’t know but dissimilar metals in hot conductive Electrolyte can create a battery of potential problems
Nevada1906
abscate wrote: 17 Oct 2021, 18:15 I really don’t know but dissimilar metals in hot conductive Electrolyte can create a battery of potential problems
Maybe I can coat the inside of the line with something.
This is the same reason you do not want to use a galvanized pipe in a copper or brass piping system. It may take years, but a leak will form.
