STARTER
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
STARTER
This is what I've found. There is a cable with small adapter that looks broken off. Here is the pic. It goes to a rounded part behind the starter. Sorry Matt need help. I know you don't like anyone saying Help but what is that and does that require soldering.Thanks guys.
SirBrickWagon
- Year and Model: 1997 Volvo 850
- Has thanked: 7 times
- Been thanked: 11 times
yep. that would be your negative terminal on the solenoid connecting it to the ground on the starter.
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Time for a new starter. Had that happen on one of our cars.
SirBrickWagon
i don't think you'd need a new starter, move the ground wire back onto the solenoid terminal closest to the wire (with a bolt over it) and see if that works. by no means a permanent fix, but certainly worth a shot.
loveMy850
It is like as short as my little finger nail and I don't have long nails, I can see where he tightened that nut a twisted the wire and terminal. I really don't see how I can do that it's a flat copper piece on the end.,,hey what about one of those round end things that go over bolts ya know. I wonder if I squeezed one of those on the wire. Does this have to be copper.oh man I'm really bummed
- Has thanked: 1498 times
- Been thanked: 3810 times
Be careful with that short wire. When the solenoid pulls in it carries u fused high current 12V. It can’t touch metal anywhere.
If it’s broken off the terminals it is hard to fix. A $60 starter is a piece of junk I’m afraid, unless it was a Volvo one from a junkyard.
SirBrickWagon
i think that would absolutely work, if you just find a way to, and i can't stress this enough PROPERLY wire the ground back onto the solenoid, double check connections before you even consider putting power through it.loveMy850 wrote: ↑26 Oct 2021, 13:39 It is like as short as my little finger nail and I don't have long nails, I can see where he tightened that nut a twisted the wire and terminal. I really don't see how I can do that it's a flat copper piece on the end.,,hey what about one of those round end things that go over bolts ya know. I wonder if I squeezed one of those on the wire. Does this have to be copper.oh man I'm really bummed
It’s not a ground wire. It must not touch ground or your car will catch on fire, literally
