The classic ticking Topic is solved
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Re: The classic ticking
Post by rguzz »
As Scott 850 has so aptly pointed out (more than once) the oil pan pick up tube O rings are highly suspect. Maybe you can check oil pressure? Let's assume we are talking about lifter tick and not some other origin noise. Classic symptoms are goes away with spirited driving (your oil pressure increased) comes back when idles (your oil pressure drops). Not so noticed immediately after a start (oil pressure is higher) but 15 minutes later as oil thins, (pressure drops). Abscate will tell you it's not a bad lifter. I'm willing to stand corrected on both counts...but only if I am wrong. After multiple oil changes and numerous additives, I replaced the O rings and, voila, lifter tick gone. The only thing that might possibly go against this is your relatively low miles. I think I went 250k before doing mine. Do not tear your engine apart until you have done this repair first, without success. Yeah, sure, take a compression test along the way.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
rguzz wrote: 26 Oct 2021, 16:42 As Scott 850 has so aptly pointed out (more than once) the oil pan pick up tube O rings are highly suspect. Maybe you can check oil pressure? Let's assume we are talking about lifter tick and not some other origin noise. Classic symptoms are goes away with spirited driving (your oil pressure increased) comes back when idles (your oil pressure drops). Not so noticed immediately after a start (oil pressure is higher) but 15 minutes later as oil thins, (pressure drops). Abscate will tell you it's not a bad lifter. I'm willing to stand corrected on both counts...but only if I am wrong. After multiple oil changes and numerous additives, I replaced the O rings and, voila, lifter tick gone. The only thing that might possibly go against this is your relatively low miles. I think I went 250k before doing mine. Do not tear your engine apart until you have done this repair first, without success. Yeah, sure, take a compression test along the way.
I'm ordering the o-rings kit, anaerobic sealer, and gasket solvent now that I'm off nights. Last night after I drove to work I tried listening yet again with the naked ear, and had a coworker listen as a fresh set of ears, and this time the sound definitely seemed to be coming from the oil cap. It would be silly to not at least try this first, I just wish I bought even more oil with the Mobil-1 rebate.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
rguzz
Post by rguzz »
There's a write up somewhere, maybe robertdiy, you'll find it if you look around, maybe you won't need it, sounds like you're on it, good luck.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
I'm not saying don't change the gaskets/o-rings, but if it is a single lifter having the issue, and the rest is working correctly - do you really think it is an oil pressure issue?
850 T5-R '95 auto Image
jsrnsis
Post by jsrnsis »
hausmeister wrote: 29 Oct 2021, 01:52 I'm not saying don't change the gaskets/o-rings, but if it is a single lifter having the issue, and the rest is working correctly - do you really think it is an oil pressure issue?
rguzz wrote: 28 Oct 2021, 12:58 There's a write up somewhere, maybe robertdiy, you'll find it if you look around, maybe you won't need it, sounds like you're on it, good luck.
Since I got rescheduled for work, and we've had some pretty cold days, I just brought it to a local Volvo/Saab place. He listened to it and the way it was cycling he was sure it was the oil pan, so for $500 he dropped the pan, cleaned the pan, pickup screen, oil passages, and replaced all the o-rings. Ticking noise is gone, and he also confirmed the oil pressure light works, so at least I know that.
I think with having done everything else so far besides an alignment myself on this car, I'd pay for this.
Now the only problem is driving my other car made me realize how much I missed having even a low pressure turbo and a dashboard that's more intact than broken.
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
Has thanked: 1842 times
Been thanked: 1710 times
Glad you found a solution. Many owners do not realise the issue this can cause over time. Rubber does not last for ever in heat and oil and hydraulic lifters are more likely to tick than the solid ones in the later cars.
Thanks for updating us.
rguzz
Post by rguzz »
It's a reasonable job to pass on. I had someone do my last Volvo that needed said repair. I also passed on my head gasket, burnt valve and am glad I did, as a bunch of other stuff was discovered that needed attention along the way. We all need to cut ourselves a break and be okay with it.
hausmeister
jsrnsis wrote: 05 Nov 2021, 12:49 Now the only problem is driving my other car made me realize how much I missed having even a low pressure turbo and a dashboard that's more intact than broken.
I can relate to that.. once you go turbo it is hard to go back ;)
Glad it worked out fine, I'll keep it in mind if mine gets worse to also drop the pan.
You know, I am seriously considering going back to an NA and no AWD. Working on the low mileage V70 NA a couple of days ago and when it started up its engine was so nice and smooth. The 00 V70 NA I sold I still regret and my buddy who bought it just loves that car. I can't use the performance of the turbo car, especially in the tuned form it was as bought. We do mostly city driving these days and any longer trips if bad weather comes can be done in the Toyota if needed.
Long live the NA!!
Has thanked: 1502 times
Been thanked: 3817 times
With two turbos and two NAs in my P80 fleet the B———S engines are silky smooth beasts, and I don’t miss the extra stuff and access when servicing.
It is all forgotten , though, when I drop BimmerBiffy in the rear view mirror
