The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
The japanifold offers the best flow of them all.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
bmdubya1198 wrote: 02 Nov 2021, 11:54 The japanifold offers the best flow of them all.
So japanifold is the performance alternative? Although the short length may not make much difference.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
volvolugnut wrote: 02 Nov 2021, 12:01
Yes. From what I've read there's also a difference in the internal runners as well as in the metallurgy to prevent that cracking.
What I don't know is what years / models the japanifold was used. I don't think it was for long before they went to the " R ".
1999 V70 GLT
bmdubya1198
Sveedy wrote: 02 Nov 2021, 16:04 Yes. From what I've read there's also a difference in the internal runners as well as in the metallurgy to prevent that cracking.
Correct. A buddy of mine over on Swedespeed (ScottishBrick) did a lot of work on this, including flow testing both the Japanifold and R manifolds. I don't remember if he ended up posting results, but I know the Japanifold is better overall.
It was used on 2001-2004 T5 and all 2.4T P2s. 2005+ turbos and all 2.5Ts had the "R" manifold.
Been thanked: 4068 times
👍🏼Power steering rack, have ordered from Detroit axle
👍🏼Replace lousy hose clamps on oil cooler lines
👍🏼Replace cheap clamps on induction path, especially the one on the lower intercooler which snags my belly every time I roll underneath
Turbo control hoses still original, evaluate
👍🏼Change MT fluid, 100k
Replace rusty clutch slave line
👍🏼Rebuild starter...already at auto electric shop
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Why is it a Japanifold? This is a Volvo stamped part made in Japan?
bmdubya1198
BlackBart wrote: 03 Nov 2021, 09:32 Why is it a Japanifold? This is a Volvo stamped part made in Japan?
Bingo.
The R manifold was made in Japan as well, but the Japanifold came first, so that's where it got the name.
Got the turbo on.
Four mani to Turbo studs
Load coolant return stub hose onto coolant line
Load coolant supply stub hose onto line
Load turbo onto four mani studs, loose nut
SLip in coolant return stub
Slip on coolant supply stub
Clamp Oetiker clamps - need both end on and side on crimpers
Start oil supply line banjo
TIghten mani nuts
Tighten oil supply banjo
tighten coolant banjo.
Intall TCV lines
The tailagate is starting to be empty of project boxes.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
@Abscate - you're a machine!
Have a turn signal bulb I can't get into the socket, may stop over tomorrow if you're in the local area. Need a hand tomorrow by chance?
bmdubya1198
The list is getting shorter!
