Help! window jumped off track 1995 940
I am Marilyn, I am 75 years old I own a 1995/940 volvo. My grndson slamed my right back door and window jumped off track I am trying to take off panel to put it back on. Can't find out how to remove the panel can I get any help? Thanks so much
- RickHaleParker
- Been thanked: 981 times
Removal
- 1. lock button (1).
2. Retaining clip (2) behind inside door handle.
3. Window winder handle (3).
4. Screw inside winder handle.
5. warning lamp.
6. Clip inside warning lamp (4).
7. Loudspeaker grille (5) -1988 model; pull straight out. 1989- press grille forward.
8. Screw inside loudspeaker grille.
9. Three clips (6) on the lower edge of the panel.
10. Lift out bottom edge of panel. Pull straight up
Install:
In reverse order.
If you cannot read this click on it to enlarge.
Active
Past
Past
- 2750 Views
Last post by 686 Sport
- 1201 Views
Last post by mapleleafer
- 781 Views
Last post by Vovo_merz
- 13 Replies
- 3177 Views
Last post by Clemens
- 2010 Views
