Oil pump Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Oil pump
Post by Sveedy »
So if I'm rebuilding the engine, should I go ahead and replace the oil pump even though it's good ?
On other non-Volvo engines I have done, I replaced it, regardless. But at over $300 for a pump, which is over 3 times what I'd expect, I don't want to spend that, if all was/ is good.
Thoughts ?
1999 V70 GLT
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Sounds good. While you're in there order a crate motor from Volvo too.
BMW 540i 2002
S70 Base 2000
Sveedy
Post by Sveedy »
So are you trying to say i should replace the pump ? From what I've read, they very rarely fail.
And why would I need another motor ??
1999 V70 GLT
kallekula
Post by kallekula »
Sorry bad joke.
Just replace the gasket behind the pump and you're good.
BMW 540i 2002
S70 Base 2000
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I would go with the odds on this oil pump. Do not replace unless you had 300K miles on the pump or know it ingested some crap.
I thought the Volvo crate motor idea was funny.
kallekula
Post by kallekula »
I have never heard or seen a broken oil pump on a "newer" Volvo. Ever.
BMW 540i 2002
S70 Base 2000
Has thanked: 1503 times
Been thanked: 3817 times
kallekula wrote: 04 Dec 2021, 09:08 Sorry bad joke.
I was with you , K
Dr S. A R Khasm
Run your original with no worries, Sveedy
