So if I'm rebuilding the engine, should I go ahead and replace the oil pump even though it's good ?
On other non-Volvo engines I have done, I replaced it, regardless. But at over $300 for a pump, which is over 3 times what I'd expect, I don't want to spend that, if all was/ is good.
Thoughts ?
Oil pump Topic is solved
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
So are you trying to say i should replace the pump ? From what I've read, they very rarely fail.
And why would I need another motor ??
1999 V70 GLT
1999 V70 GLT
- Has thanked: 927 times
- Been thanked: 1001 times
I would go with the odds on this oil pump. Do not replace unless you had 300K miles on the pump or know it ingested some crap.
I thought the Volvo crate motor idea was funny.
- Has thanked: 1506 times
- Been thanked: 3818 times
I was with you , K
Dr S. A R Khasm
Run your original with no worries, Sveedy
