What is the function of the Oscillation Damper??
YV1LW
Year and Model: 98V70r
Has thanked: 15 times
Been thanked: 4 times
Post by YV1LW »
Listed as p/n 9480153 it looks like a box with a thin steel plate with 6 screws. It appears to be self contained. I don't believe it directly shares any fluids with the angle gear housing.
How does this unit work?
Is it filled with high density fluid(s)?
Does it require any service or periodic maintenance?
Thanks to all you reply.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
As far as I know it's just a weighted vibration damper. No maintenance needed.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
The answer is in the name. It dampens oscillations. Does this by absorbing some of of the energy of a vibration.
It is a passive device, no maintenance required.
YV1LW
Post by YV1LW »
While on the topic of 1998 automatics;
@richhaleparker
I notice you have a '98 C70 listed with the AW50-42. Is that a special version of the 4 speed automatic? While I haven't pulled all the plumbing that would enable seeing the tranny dataplate, my Owner's manual notes that the manual transmission would be a M56H and the automatic would be designated as AW5-42LE.
Do I have my part numbers wrong? There is no AW42?
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Clue regarding that box under the car: Have you ever seen the movie "Speed" with Keanu Reeves?
Don't stop oscillating.
All U.S. market models.
All running and on the road.
Has thanked: 1497 times
Been thanked: 3810 times
Definitely check it for an LED readout
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Not to be confused with the legendary device, used to gain entry to the 8th dimension:
Lord John Whorfin : "John O'Connor, install my Oscillation Overthruster!"
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
foggydogg wrote: 09 Jan 2022, 12:33 Not to be confused with the legendary device, used to gain entry to the 8th dimension:
RickHaleParker
YV1LW wrote: 04 Jan 2022, 19:14 I notice you have a '98 C70 listed with the AW50-42. Is that a special version of the 4 speed automatic?
Noting special the AW50-42 was used on a lot of the P80s. See the attached file.
AW50-42LE.pdf
(306.5 KiB) Downloaded 110 times
foggydogg
Post by foggydogg »
BEJinFbk wrote: 09 Jan 2022, 14:07
I was known to use that exact phrase on several occasions in a professional capacity at work.
