I agree, no junk hardware, but spending up for t-stat bolts is pushing the practicality limits for me. Cam cover bolts work perfectly! Scavenge them by the handfuls from Volvos in the junkyard.abscate wrote: ↑11 Jan 2022, 06:14 Counterpoint. Hardware isn’t a commodity anymore. There is so much cheap junk out there with pot metal in the mix that you can’t just buy them from hardware stores anymore.
I won’t put anything back on my cars now without Volvo hardware if it sees corrosion or if it’s a steel into Aluminum fastener. That’s sAved me hours of nasty wrenching
On that thermostat job
Volvo says remove 2 liters of coolant to make thermostat removal dry.
Torque on the thermostat housing bolts is 17 Nm. That’s not very tight. The gasket does the work.
New Volvo 850 Purchase!
- Has thanked: 292 times
- Been thanked: 765 times
Re: New Volvo 850 Purchase!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
Right.... that's how I know that a VIC exists.
Fantastic, I will look for that.Air pump is a poorly designed system. A check valve (SAS valve) above the exhaust wears out, sticks open, then the pump fills with water and dies. You can also opt to get rid of it search for "SAS delete."
Maybe I'm blind.... I will look again, but I don't see any cup holder.Center console cup holders no good for you? Get a skinnier cup!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Agreed the VIC elusive but my point is ... not worth the effort to find, tells you nothing.
The cup holders are in the arm rest, they pull out. viewtopic.php?t=67635
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
454cid
Oh! I thought the double pull, but single latch was weird. It never occurred to me that the wider one pulls out, to be a cup holder. Thankserikv11 wrote: ↑11 Jan 2022, 13:48
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1498 times
- Been thanked: 3810 times
Erik takes the $100 Volvo cop holder finder fee in PayPal, bitcup, Venmo, and Russett
454cid
I guess I could send him some potatoes
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
You’re the straight guy here, sorry. Erik and I a long standing joke about he being in IA, the potato capital (ID of course)
I think I started it, years ago, but maybe it has lost its..a…peel.
454cid
I assumed Russett was a payment service or e-currency I hadn't heard of.... Google doesn't give me anything of relevance.
I went out into the cold, and verified that I do in fact have a cup holder... using it has gotten a bit more important, as I've discovered the brakes on my current daily driver, must have a slight leak someplace. If I hit the pedal hard, it starts sinking, and I don't want to fix that.
Volvo parts are supposed to start arriving Thursday.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Keep an eye out for the early Russett iPO , although its a bit baked at the moment.
- Has thanked: 1836 times
- Been thanked: 1709 times
Typical half-baked answer from abscate!!
Glad you found the cup holder. They are not particularly strong so be careful how big a cup you put in it or it ends up on the floor.
