Yep. Can't remember if it came from FCP or IPD.
P80 P2 Coolant pipe o-ring & install 976045 Topic is solved
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Re: Coolant pipe o-ring & install
1999 V70 GLT
1999 V70 GLT
- Sveedy
Abscate, can you move some of the pics / diagrams from the other sticky over to this thread ?
Also I came across this outfit either on this forum or another...
https://www.captainoring.com/
I'm planning on removing the coolant pipe again tomorrow. Will go in search of o-ring then.
Worst case scenario..
I have thought about the possibility of having to remove the water pump. If that ends up being the only way to do this then I'll make a wooden ( my go to material )rod about 3- 4" long and the same diameter as the coolant pipe. I'll feed that in from the pump side till it gets to the recess. Then from the block side, push the o-ring in its recess while pushing the dowel through to hold o-ring in place. I should then be able to take the coolant pipe and use it to push the dowel back out while allowing the pipe to slide into the o-ring.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 304 times
- Been thanked: 517 times
So I talked to one of my whiteblock expert friends, and he tells me that the o-ring should seal on the ID against the pipe, not the block. It's supposed to fit loosely in that groove, which is how it gets pinched. The only way to do this is to pull the water pump and hold it in place as you insert the pipe.
- Sveedy
^ Please tell me this can be done with the engine in place....
And looking at the pic, it looks like the cut end on the new pipe is slightly peened or tapered as opposed to how mine was just cut.
That would certainly help.
1999 V70 GLT
1999 V70 GLT
- Sveedy
Part # from FCP - # 30622784
Part # from dealer - # 31109233
I have ordered both, so we will see.
1999 V70 GLT
1999 V70 GLT
It can be done with the engine in. Just a little tighter access, as you would expect!
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I would not use Vaseline. I would use silicone grease. Vaseline will likely make the rubber swell, which would be great for sealing, but no so great for getting it put together as it will swell on the outside and the inside diameters.Sveedy wrote: ↑03 Feb 2022, 14:10 ^ That is exactly it. So left hand on pipe, right hand index finger in water pump side trying to push o-ring around into place. If my hand would fit around the timing cover.. And it would all have to be done by feel.
But your idea of stretching the o-ring before install is golden ! I could put it on the pipe, heat the pipe with a heat gun and let it cool a few times, then try installing it, maybe while it's still a little warm. Lots of Vaseline and it just might work.
If it does, I owe you a beer !
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2652 times
- Been thanked: 1240 times
All the above except the most recent several posts split from What did you do to your Volvo today? I think I got everything.
Please do edit your posts in this topic if you want to. Editing time window is now infinite on your posts.
- Sveedy
You'll know it's lined up because of the additional pipe going to the cylinder head, with the oval gasket.That needs to line up, so that's an easy way to tell that it's all the way seated.
[/quote]
But not that it's seated right. As it is now, everything fit and bolted up just fine. But it still drips...
[/quote]
1999 V70 GLT
1999 V70 GLT
- Sveedy
Zooming in on that pic of the new style of pipe, it is apparent that the end in question is way tapered now. As said before, that makes a lot of sense.
Me thinks that they realized the problem and tried that approach to fix it. Must not affect coolant flow at that point in the system.
Good enough for them, good enough for me.
I'm going to try the same thing.
1999 V70 GLT
1999 V70 GLT
- 981 Views
Last post by volvodork
- 4801 Views
Last post by darrylrobert
