Ok, I almost bought it, but ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one insteadvtl wrote: 18 Feb 2022, 15:01 It sounds like you have too much fun alone with your 720. I think, two more beers and I'll convince myself I need that 720 CEM on ebay =)
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- RickHaleParker
- Been thanked: 980 times
It might not be a knock off. A lot of name brands are generics with a expensive name on them. Today it is marketing hype not the product that often determines price.vtl wrote: 21 Feb 2022, 13:05 ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one instead
Active
Past
Past
vtl
I know. Either a rebranded generic device, or authentic device unofficially manufactured during night shiftRickHaleParker wrote: 22 Feb 2022, 13:13It might not be a knock off. A lot of name brands are generics with a expensive name on them. Today it is marketing hype not the product that often determines price.vtl wrote: 21 Feb 2022, 13:05 ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one instead
I liked a lot that with DSLogic you can easily write your own protocol dissector.
- RickHaleParker
Sirloin took my hardware interrupt idea and ran with it. Added some of his own to the idea. It is getting good results.
Cracked with Calc_Bytes = 5, One range only, Samples = 10.
Candidate PIN 55 28 90 50 37 -- : brute forcing bytes 5 to 5 (1 bytes), will take up to 0 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..done
found PIN: 50 28 37 55 52 90
PIN is cracked in 1005.44 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Validating PIN
PIN verified.
done
Resetting all ECUs.
Active
Past
Past
- RickHaleParker
Calc_Bytes = 5 : 1005.44 seconds ( 16.75 minutes )
Calc_Bytes = 4 : 814.80 seconds ( 13.58 minutes ) <== Sweet Spot.
Calc_Bytes = 3 : 1658.67 seconds ( 27.64 minutes )
Active
Past
Past
- RickHaleParker
This applies to the CEM-B ?vtl wrote: 20 Feb 2022, 10:17 - latency accumulation is very visible when the right subsequence is sent. 1 or 2 bytes don't make a difference, but 3 and, especially, 4 totally triggers it. Of course, CALC_BYTES=4 would be very slow on a 250 Kbps,
If so, the 1 million 3 byte strings ( 3 bytes at a time ) in 1 hour 6 minuites at 250 pins per second.
( 00 00 00 XX XX XX - 99 99 99 XX XX XX ) not ( 00 XX XX XX XX XX - 99 99 99 XX XX XX )
Active
Past
Past
sirloins
- Year and Model: 2010 V50 T5 AWD M66
- Been thanked: 3 times
I have 3 P1 CEMs. I am sending one away, and I can send you one as well if you'd like. I have pretty much confirmed there is no difference between the 719 and 720 CEMs. I am happy to send you either a 719 or a 720. I think you can even flash a 719 with the files from a 720 without issue.vtl wrote: 21 Feb 2022, 13:05 Ok, I almost bought it, but ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one insteadI feel my 8MHz Saleae knock-off limits me and for sure I need a 400 MHz logic analyzer that works with sigrok
I do still plan to do the analysis with my logic analyzer, thanks for the sigrok reference, I had not seen that before. Although I have also mostly confirmed through trial and error that the timing issues all relate to the CAN interrupts, it would still be good to show once and for all.
- RickHaleParker
Sirloin's code base keep getting faster and the reliability is looking good.RickHaleParker wrote: 22 Feb 2022, 19:31 Calc_Bytes = 5 : 1005.44 seconds ( 16.75 minutes )
pin[3] choose candidate: 50
Candidate PIN 55 28 90 50 -- -- : brute forcing bytes 4 to 5 (2 bytes), will take up to 20 seconds
PIN is cracked in 493.06 seconds ( 8.22 minutes)
( 40% improvement in speed over the last one. )
Validating PIN
PIN verified.
done
Resetting all ECUs.
Active
Past
Past
vtl
Yes, the very first software version cracked my CEM in under 5 minutes. It is much longer now for a reason
Once we figure out what's going on, the change will be happily applied.
- 9326 Views
Last post by RickHaleParker
- 9299 Views
- 27 Replies
- 28790 Views
Last post by cn90
- 10 Replies
- 10796 Views
Last post by jonesg
- 5923 Views
