V70 cluster power wires
Khyren
Year and Model: 1998
Has thanked: 3 times
Post by Khyren »
I have a V70R cluster to go with my engine swap. Before I go through the process of pulling the dash pad, anyone know what two pins will power the cluster so that I can see what the mileage is on the cluster?
Has thanked: 292 times
Been thanked: 765 times
Go to the dash and look at the connector on top of the cluster. It's I think the second and third wires in from the right side edge,
back (nearest the engine) row of wires. the positive is Red/Black and the ground is Black. So if you can ID those two wires, it's the pins that match to them.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1505 times
Been thanked: 3818 times
Ooof, this is for a 1999, but you might s EE the same power in, the hard part will be finding the grounds
1999 cdm electrical diagram
Khyren
Post by Khyren »
Misha and abscate, you are much appreciated!
I actually found a 1998 CDM in my stash. Now I need to power it up
Watch out , terminal A1 ejects the warp core….
