V70 cluster power wires
Khyren
- Year and Model: 1998
- Has thanked: 3 times
I have a V70R cluster to go with my engine swap. Before I go through the process of pulling the dash pad, anyone know what two pins will power the cluster so that I can see what the mileage is on the cluster?
- Has thanked: 292 times
- Been thanked: 765 times
Go to the dash and look at the connector on top of the cluster. It's I think the second and third wires in from the right side edge,
back (nearest the engine) row of wires. the positive is Red/Black and the ground is Black. So if you can ID those two wires, it's the pins that match to them.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- misha
- Has thanked: 152 times
- Been thanked: 402 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1505 times
- Been thanked: 3818 times
Ooof, this is for a 1999, but you might s EE the same power in, the hard part will be finding the grounds
1999 cdm electrical diagram
- 10C01159-3F7D-4AA7-82AA-4EA35472C31A.png (1.01 MiB) Viewed 470 times
- 4E1F114C-4470-4160-B6D9-851657DD5B7D.png (1.13 MiB) Viewed 470 times
- FE87223C-456B-489C-BF4E-B090FC8BC396.png (1.21 MiB) Viewed 470 times
- 66174359-AE8F-450B-A46F-B394E3C8E090.png (1.71 MiB) Viewed 470 times
I actually found a 1998 CDM in my stash. Now I need to power it up
Watch out , terminal A1 ejects the warp core….
- 11 Replies
- 3877 Views
Last post by Faheyk1981
- 1265 Views
Last post by MDK
