Cam cover installation tools.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I like this for engine assembly lube: Lubriplate No. 105
Lubriplate 105.png (58.49 KiB) Viewed 593 times
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
That one worked great.
Screenshot at 2022-02-22 12-28-11.png (302.17 KiB) Viewed 586 times
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Can't remember where I saw it but cam cover draw down tools can be made from old spark plugs, knock the porcelain out and weld a length of all thread rod in, use matching nuts and fender washers to draw the cover down.
I think it was shown in the Haynes printed service manual....along with the homemade cam shaft locking tool made from angle iron.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
The top of the head that mates with the cam cover has stains that do not come off. Is this okay?
Since the oil is drained, and the engine has been sitting a while, is it okay if I rotate the engine with the cams and timing belt installed to make sure no valves are hitting?
Also, the exhaust cam is vvt, and I never took the vvt hub off. What do I have to do differently for aligning it properly?
2002 v70 X/C 288k miles
vtl
Post by vtl »
Pics?
02V70
Post by 02V70 »
Here are some. The cam cover is similar, but a little better.
vtl
Post by vtl »
Looks ok to me.
Don't forget to lubricate camshaft valleys. Tappets, too.
Has thanked: 1609 times
Been thanked: 4065 times
vtl wrote: 12 Mar 2022, 14:35 Looks ok to me.
And the camshaft thrust surface on the first journal from left. I left that bare and it took me 6bweeks to figure out why my cams locked up
02V70
Post by 02V70 »
I almost forgot to do that. Thanks!
Also, is it safe to turn the engine manually if there is no oil in it? Since I have a vvt cam (I never took the hub off) the gear should be aligned instead of the cam right?
vtl
Post by vtl »
Safe to return as long as all surfaces are lubricated during assembly.
Yes, align using timing marks on the sprockets.
