1993 rotor removal
potroast
Year and Model:
Post by potroast »
I am going to replace my front rotors on my 1993 854... I have removed the wheels, wheel-locating-bolt, calipers, and caliper mounts. What else must be removed to get my rotors off? I have tried removing them but they feel welded on. They are VERY solidly attached to the hubs. Is there something I'm missing?
Thank you in advance for your replies.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
They rust on... you need a rubber mallet or steel mallet with a wood block between the hammer and rotor.
Also -> Amazon link
Guest
Post by Guest »
hmm, okay. Guess I'll just muscle them off then.
matthew1
Site Admin
Post by matthew1 »
Ah, hold on! Memory tells me there's also a small hex(?) holding them on... thinking back...
Also -> Amazon link
is_potroast
Post by is_potroast »
Yes, the haynes manual references a small hex, but I have no clue where it is, and the manual doesn't have a pic... I feel so stupid for not being able to get it off, but the only reason I didn't use a mallet because I had this suspicion something else was there.
any ideas?
matthew1
Site Admin
Post by matthew1 »
I remember it has something to do with the metal prong at the 7 o'clock postition in this picture.
Also -> Amazon link
MikesS70
Year and Model: S70 1999
Post by MikesS70 »
potroast wrote:I am going to replace my front rotors on my 1993 854... I have removed the wheels, wheel-locating-bolt, calipers, and caliper mounts. What else must be removed to get my rotors off? I have tried removing them but they feel welded on. They are VERY solidly attached to the hubs. Is there something I'm missing?
RUST..... it's what holds the rotor to the hub. I just got done R&R-ing the front rotors on my '99 S70 and had the same problem. The fit of the rotor to the hub is *very* precise and it doesn't take much rust to wedge it to the hub. Go to your local FLAPS (Friendly Neighborhood Auto Parts Store) and get this stuff called "PB Blaster"; this stuff is emensely better than WD40 for loosening rusted stuff. The drawback is that it stinks a bit. Give the hubs a good shot of this stuff and go have lunch. Come back, get a plastic mallet or rubber hammer, and start wanging away on the rotor.... it should free itself.
1999 S70
matthew1
Site Admin
Post by matthew1 »
Whoa, what happened to my picture? potroast was probably sitting around scratching his head on that one. :shock:
The pic is here:
http://members.shaw.ca/heeeeee/strut/1.htm
Also -> Amazon link
TAFinley
Year and Model:
Post by TAFinley »
The front caliper brackets on my 854 T-5 are held on by two 7mm hex nuts. These are the brackets you have to remove to get the rotors off. I didn't have a 7mm hex driver, but I did have a 7mm hex key that I was able to insert and then turn with a wrench. Your 850 may be similar.
Potroast is correct; those rotors are probably welded on with rust, just like mine were. I used WD-40, waited a while, then wailed away on the rotors with a rubber mallet until they popped free. I'm not familiar with "PB Blaster", so I can't comment on it, but WD-40 worked fine in my case.
Tom Finley
'97 854 T-5
'85 245 GL
