The electrical part ($50) won’t fix the key spinning or sticking problem, that needs a new tumbler ($400, or junkyard)
The junkyard route introduces a new problem of getting a set of keys that will work, plus extraction is probably a 1-2 hour job
Write up is here
viewtopic.php?f=1&t=98078
DIY: 1998 Volvo V70 Ignition Switch & Cylinder Lock
DIY 1998 Volvo V70 Ignition Switch & Cylinder Lock Replacement
- Has thanked: 2199 times
How worn is your key? You should have a non-chipped key. Once the keys get really worn, this issue can happen as the lock does not see the key as correct to the car. A good locksmith may be worth trying and see if a new key will help or if the whole lock mechanism is bad. Also try some WD40 in the mechanism and see if that will remove a build of of dirt and release the tabs that may be sticking as well.
Otherwise replacement is the only option as abscate says.
If i replace it myself is there any need to bring it to the volvo dealer for any programming or recoding? Called up the local dealer to price the part and he made it seem as though I would have to bring it in to be re-coded. Then the fella at IPD told me that my key is likely chipped and may need to be recoded. I thought buying a part based on VIN solved the recoding issue.
In Europe chipped keys started earlier than in North America. Many Volvo parts guys have no idea about these older cars. 99 was the year we went with chipped keys. No programming is needed on -98 keys. They need special cutting tools but many good locksmiths have the equipment needed.
Vin# is mostly a true definer of what you had but in change over years they sometimes go wonky. Post a picture of the ignition key and the tumbler unit were you put the key in and we should be able to guide you.
On the car is fine.
jzd wrote: 14 Mar 2022, 16:17 If i replace it myself is there any need to bring it to the volvo dealer for any programming or recoding? Called up the local dealer to price the part and he made it seem as though I would have to bring it in to be re-coded. Then the fella at IPD told me that my key is likely chipped and may need to be recoded. I thought buying a part based on VIN solved the recoding issue.
In North America, as Neil says
-1998 no chip, no coding
1999- FULL VIDA needed with internet connection to Volvo
You can order a tumbler from Volvo$ which will be correctly keyed to your keys, which are ordered separately.
I went this route with 1999 Evita rather than trying to cut out a junkyard one and then have to deal with chipped keys
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
As mentioned earlier, if the car is a true '98, it won't need connected to the Mother Ship.jzd wrote: 14 Mar 2022, 16:17 If i replace it myself is there any need to bring it to the volvo dealer for any programming or recoding? Called up the local dealer to price the part and he made it seem as though I would have to bring it in to be re-coded. Then the fella at IPD told me that my key is likely chipped and may need to be recoded. I thought buying a part based on VIN solved the recoding issue.
Virginia is a big place, try calling Don Beyer in Falls Church, I always had good luck with them earlier in my childhood. Parts guys may be more helpful than a service writer. If you aren't having any luck with legit locksmiths, a Volvo-cut key based on the VIN may be the lesser of the evils.
Foggydog - Thanks for the tip. Funny story. 25+ years ago I am working a temp job in Alexandria as the guy answering the phone at an advertising agency. Call comes in and the guy I’m working for is on the other line. I take the name down and tell him they’ll call him back. I later get fussed at by the boss for not putting the call through immediately because the caller was Don Beyer who was then the Lt. Governor of Virginia. I didn’t pay attention to that stuff back then.
- 18 Replies
- 15072 Views
Last post by LadieRed
- 4077 Views
Last post by lummert
- 2812 Views
Last post by Mark60
- 1265 Views
Last post by alschnertz
- 1284 Views
Last post by RickHaleParker
