Hey Guys;
Just got the word from my mechanic that he won't replace my oil breather/separator box for me.
He said he is afraid about how many things will break during the process and that it may take him
longer than the book rated 3.0 hrs.
I wanted to tell him that if he is afraid to get a dog!
Anyway, does anyone have a good video for me for my P2 (Non-turbo)?
I have all of the necessary parts minus any new bolts needed. Should I be replacing any manifold bolts
or other hardware in the process? Thanks.
Oil Separator Box replacement (P2 - base)
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
The only items outside of all of the hoses and standard stuff that comes in the PCV service kits that got me :
4 x 12mmx16mm copper washers
Throttle Body Gasket
Thermostat Gasket
YES absolutely get the 2020 upgraded banjo bolt. There are comprehensive threads that have entire shopping lists basically (I think theres one on swedespeed). Funny the mechanic refused the job. It wasn't really bad and took me about 3 hours all-in on a DIY first attempt.
The best way is to look at the comprehensive service kits on iPD/FCP and that gives you a good idea of what you should have on your bill of material.
Thermostat Gasket
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
On Youtube, the FCP Volvo guy goes thru the job on a 2004 S60. Watch the video and take notes on the order of things and how he gets things apart and back together.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
- Been thanked: 504 times
- Just replace the hoses etc.
- The oil trap can be cleaned and re-used. They last up to 300K.
- I posted a photo some yrs ago, when I cut it in half to show people the inside anatomy...
- Has thanked: 311 times
- Been thanked: 817 times
I mostly agree except: don't just replace the hoses - for sure also replace the banjo bolt.
- Been thanked: 4068 times
If you are 150k plus it a perfect time to have your alternator rebuilt. While it’s out, the banjo bolt replacement is a lot easier.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Probably not so true in this case though. The non-turbo separator boxes have a built in diaphragm that is supposed to control the amount of vacuum placed upon the PCV system. Over time it gets all coked up inside and the diaphragm can’t do it’s job. I have a photo somewhere of what mine looked like inside when I cut it open. If I can find the pic I’ll post it.
That’s why Fora Rock. When I go to do my 2005 I’ll watch out for thus
- br0dy519
Crap I forgot to mention the other things I forgot that pushed my job back another day :
Fuel injector o-rings
Fuel injector pintle caps
You will need to replace some of them as they are old and brittle! Else you’ll get a leak there.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
@chrism et al,
I do NOT have the cutaway view of a P2 oil trap, my guess is the P2 oil trap is very similar to P80 oil trap...
The photo below is my 1998 V70 (non-turbo) Oil Trap with 100K, I cut it in half to see the anatomy:
it is a simple box.
PS: If anyone has a P80 oil trap, please post a cutaway view...
it is a simple box.
- 14 Replies
- 2094 Views
Last post by woodycaldercloggs
- 1024 Views
Last post by tlh
- 767 Views
Last post by Vvvvvvvvvv
- 1189 Views
Last post by Capndirk
- 12 Replies
- 1968 Views
Last post by erikv11
