hi everybody.
i had the oil pressure warning....so i put a mechanical guage on it.
at startup...i get 50psi.....during 10 minutes of idle the oil pressure slowly reduces to 15psi.
im trying to get opinions? the cracked O-ring on the pickup? or the oil pump itself? or a clogged oil pickup screen?
do you think a shadetree mechanic like me can remove and replace the oil pan?
kindest regards
jason
2005 xc-70 slowly decreasing oil pressure
xc70newbie
- Year and Model: 2005 xc70
- Been thanked: 4 times
- Been thanked: 504 times
Wait a minute, that is normal...
How many miles in your car?
Why did you measure oil P to start with?
All cars do that: when COLD, engine oil pressure is 30-50 psi at idle, as engine warms up, the oil becomes
thinner, and idle oil P will be around 8-12 psi or so, depending on car...
- Has thanked: 1613 times
- Been thanked: 4077 times
I agree that it’s not clear there is a problem
Once warm , a rough rule of thumb is that an engine should have 10 psi pressure per 1000 rpm
It can be quite low at idle, below 10 psi
The oil light pressure switch closes at X psi, to be researched and posted.
Remember your manual says the oil light can flicker at idle after hard driving, which is normal.
You are in Michigan. You can get anything car related done.
xc70newbie
thanks for the vote of confidence!
oil press was 75psi at start and like 15 after a very warm idle.
i measured oil pressure it because i got the red oil pressure warning light after a few miles of driving.
also.....
when removing the stock oil pressure sensor....it was QUITE loose and the connector was barely!! inserted (most likely due to previous owner and difficult to reach switch)
there was no oil pressure light with the sensor completely removed ...i was expecting a fail-to-on logic .
so a loose connection would have NOT caused a warning light
also.....
Right. It works by grounding at low pressure, so the wire and sensor has to be snug and firm
xc70newbie
oh...180,000 miles are on this 2005 xc70
It’s not quite broken in yet
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I took a vanity shot just prior to crossing the 300K border, turned out kinda cool
(this is more current, and not as cool). I’ll see if I can find it.
Oh, are you getting the “NO OIL PSI, STOP IMMEDIATELY” message in the DIM or the red oil psi light?
If the former, I would heed all notions & sensations of caution until proven otherwise.
The oil pan removal/cleaning/etc (& the likely forthcoming PCV job) is a great first project to learn on. You really won’t know why your oil psi is negligible until you investigate further. Surely, your oil pump is still good, rest assured.
- 56E06F6A-D206-462A-B619-D24899A9096C.jpeg (100.96 KiB) Viewed 1429 times
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 31 Replies
- 2752 Views
Last post by tjmartin317
- 1511 Views
Last post by Salomons Driveway
- 17 Replies
- 5559 Views
Last post by mecheng
- 1151 Views
Last post by cn90
- 2626 Views
Last post by nsomlai
