Thanks for that. I wound up making my own connector, but the MAC valve TCV has just failed I think, as we've been seeing a P0245 code the past couple of weeks, and there is power to the unit. I have a Pierberg one on order that we're going to install.acrazyjohnny wrote: ↑11 Nov 2020, 12:55i had the same issue because it was a typo. if you look at the original post pics you can see part number is 978153
but by the time i figured that out i had already ordered a set of 5 male plugs and 5 female plugs
Build your own TCV, save 50%
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Re: Build your own TCV, save 50%
Hello , i just purchased this mac valve , but ias not working with my car (volvo 850 T5 M4.3) Until today i used IPD 2nd Valve but i had some issues , so i decided to change it. Could you please tell me if there is polarity on connection or the hose routing is different from IPD? Thank you!
- cleven
- Year and Model: 2001 V70 T5
- Been thanked: 5 times
Does it route the same?ndphotonl wrote: ↑06 Nov 2020, 05:52 I have been using the Porsche TCV for quite some time with good results, highly recommended. Costs about 25-30 euro/USD
Volvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on Flickr
- Has thanked: 304 times
- Been thanked: 517 times
Yes, it does.cleven wrote: ↑10 Jun 2021, 18:22Does it route the same?ndphotonl wrote: ↑06 Nov 2020, 05:52 I have been using the Porsche TCV for quite some time with good results, highly recommended. Costs about 25-30 euro/USD
The Mac unit is supposed to be faster to respond, so you get more consistent and reliable boost. However the problem that's been found over the years is that they don't hold up to daily driving very well. I have heard that they are good for track use though.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
well, i still don't understand what we are talking about... Does it have matter with turbo ?bmdubya1198 wrote: ↑26 Apr 2022, 20:10The Mac unit is supposed to be faster to respond, so you get more consistent and reliable boost. However the problem that's been found over the years is that they don't hold up to daily driving very well. I have heard that they are good for track use though.
Correct
