Subframe Bushing insert job
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Re: Subframe Bushing insert job
Post by azureblue »
thanks again. I put a little red locktite on them to be sure. I don't do much driving anyway. Those bushing inserts are looking better by the day..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
You can reuse the 14 mm bolts, The bushings you got in the picture are for the rear of the car, the front ones should all be identical with same part number. You're in the homestretch now.........just get the right parts and finish the job, I'll pretend I didn't read that part about the bushing inserts! :D
2003 XC 70 (sold)
azureblue
Post by azureblue »
I torqued the 17MM to 80 ft/lbs with a a dab or red locktite. I'm going to the dealer to get the right bushings, but it may be a few days before I can get time to do the work.
Thanks for the advice and support.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Been thanked: 471 times
Post by cn90 »
I have a question for the bushing gurus...
What is the BEST way to inspect the subframe bushings?
Do you guys use VISUAL inspection or go by other symptoms?
If Visual, where do I look?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
I think the sub frame bushing inserts is one of those inexpensive add on so I think most people don't have it in mind to inspect them. Having done two I either was going to go through the trouble of replacing the sub bushings in addition to the inserts or just the inserts.
Below is the 00 S70 rear inserts. Haven't gotten to the fronts yet. Will do so with the strut install. The rear inserts was part of the rear suspension refresh with springs and shocks besides the U sub frame brace. Purchased from the owner of the car pictured. He had several.
00 S70 Sub Inserts Lube.png (2.82 MiB) Viewed 131 times
00 S70 Sub Inserts.png (3.1 MiB) Viewed 131 times
00 S70 U Chassis Brace C70.png (4.28 MiB) Viewed 131 times
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
cn90 wrote: 07 Nov 2023, 21:12 I have a question for the bushing gurus...
I recently replaced the subframe bushings on my 08 S60. Hard to tell how hard the rubber has gotten until you pull them out. Not a terribly bad job and Volvo bushings aren’t too expensive. I found a Harbor Freight electric impact to be quite helpful driving them in…just make sure they are squared up right.
08 C702.5T (sold)
The non-Swedes:
