1998 v70 Power Windows will not work
This topic is in the MVS Volvo Repair Database » How To Check For Leaking Fuel Injector
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Switch Doctor advertises the S/V series switches as OEM (Many people list things as OEM so I am always skeptical).
I found the for real OEM switch for less money at www.Tascaparts.com (around $104.00).
P 445
Year and Model: P 445 1959
Post by P 445 »
Volvo S/C70 Master Power Window Switch 1998-2000 can be purchased from the SwitchDoctor (https://www.switchdoctor.net) with a lifetime guarantee for $25.00
Has thanked: 2205 times
Been thanked: 1852 times
I have had a Switch Doctor master switch still in the box. I bought one but when it arrived it was really plasticy compared to the OE part. I found a good OE switch and fitted it instead and the SD one is still in the box 8 years later.
Been thanked: 4069 times
Switch doctor has absolutely the most schizophrenic reviews of any vendor I’ve ever seen
abscate wrote: 21 May 2021, 04:20 Switch doctor has absolutely the most schizophrenic reviews of any vendor I’ve ever seen
…and a year later I am a customer. For $25 vs $160 new, I’m in.
Fit and finish are excellent, electrical connections perfect, function perfect
Will report on longevity.
Since I have 6 1999s, I bought two.
Installed on the T5, five minutes. Popped old one out with a scout knife. Original replaced in 2008?
Happy Spring!
C1ph3r
Year and Model: 1999 V70T5
Has thanked: 32 times
Been thanked: 7 times
Post by C1ph3r »
abscate wrote: 13 May 2022, 02:29
Happy Spring!
Hey Abscate, just stumbled across this post. i just replaced mine with switchdoctor also. i did the swap on april 27th. in about a week after the install (of which i probably only used my windows like 3 times maybe) the driver window switch stopped working. it would start working again after i turned off the car and back on again. i emailed switchdoctor support on may 2nd and had a replacement in the car by May 7th! Their warranty support was fantastic! at least that is my experience. i wish they had a switch for the other 3 doors.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
Those other three doors are junkyard specials. I’ve got a ton of them. They never break due to low duty cyvle
C1ph3r
Post by C1ph3r »
abscate wrote: 14 May 2022, 01:59 Those other three doors are junkyard specials. I’ve got a ton of them. They never break due to low duty cyvle
Yeah I can see that. But the switchdoctor ones function so nice. Nice smooth, light clicks
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
They have clearly improved their product over the years as those look nothing like the one I bought all those years ago. I just replaced an aftermarket one in my friends car a couple of days ago. About a year old I'm told. It was still working but the driver's door switch had come loose.
Update, first unit failed 14dats after install. I’ll chase warranty this week. Using my second one in meantime 😎
Here is some info for driver door switch bypassing. Putting +-12 volts across A3 and A4 on the driver door switch plug will operate the window up/down if the switch goes out. This won’t fix a jammed window or bad motor of course.
