- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
V70 developped a bad knock a few days ago, finally got to dig into it.
Started by taking compressions, all good up there
Took the oil pan out and found out the culprits
Not sure how that happened, oil level was fine, in a straight line, pan o-rings replaced 15k miles ago...
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Lol, this video is "age restricted".... what exactly are you trying to show us???Goupil wrote: 14 May 2022, 14:42 V70 developped a bad knock a few days ago, finally got to dig into it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
etzal
- Year and Model: 95 850 GLT
- Been thanked: 4 times
Just replaced the entire cooling system on my 850 after radiator started leaking suddenly.
Could not find a genuine Volvo radiator so bought a Nissens which cost about half.
Reused the two rubber grommets for the mounting holes but did not replace the round metal inserts.
Spent the next day replacing the heater core and coupler.
Expected the steel heater pipe to be corroded but mine looked practically brand new.
I did replace it with the aluminum type.
Removed the accelerator pedal but still found it difficult to remove the coupler.
I removed some of the insulation around the firewall hole which made it a lot easier to install the new coupler.
Replaced all the hoses with genuine Volvo.
1995 850 261400 miles
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
What A Struggle Deux: Should've taken ten minutes,
Actual clock time: two hours, to here:
In British aviation circles, they would describe braking efficiency as "Nil."
Good thing I still have a few parts on the shelf, stockpiled from Nearly Normal time.
- Has thanked: 316 times
- Been thanked: 531 times
The title describes it perfectly!Goupil wrote: 14 May 2022, 14:42 V70 developped a bad knock a few days ago, finally got to dig into it.
Ouch... I don't envy you.foggydogg wrote: 14 May 2022, 17:35 What A Struggle Deux: Should've taken ten minutes,
Those jack stands are pretty great though, aren't they? I picked up a couple sets a few weeks ago when they were on sale. Really nice compared to HF's old ones.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
It's probably the video title
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
For sure the title...
850 T5-R '95 auto
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 673 times
- Been thanked: 164 times
Iv' taken time to treat seats with meguyards creme, glue once again the dashboard following an advice given couple a weeks ago by I've forgotten who (sorry), replaced bulbs behind the clock.
