Nevada1906 1995 850 S60R m56 build thread
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
It's a wonderful feeling getting the engine back in its place. Second only to hearing start up for the first time !
Good work !
1999 V70 GLT
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Sveedy wrote: 06 May 2022, 15:54 It's a wonderful feeling getting the engine back in its place. Second only to hearing start up for the first time !
Good work !
Thank you!
I can't wait to get it running.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Nevada1906
abscate wrote: 06 May 2022, 02:37 Wait, you have coil on plug ignition on a -1998 style ps pump motor?
Don’t forget to put the aluminum exhaust shield on before the turbo pipe, much easier
Yeah, the accessory drive is from the 850.
It fits, though - after a fashion.
Nevada1906
Since I have to wait to get the rest of the engine mounts, I thought I'd take care of some other items.
First up, I plumbed the turbo with vacuum lines. They're on there so tight I'm not going to bother with clamps.
Then I found out the fan shroud won't clear the power steering pressure line. I'll probably trim it to fit.
Then I started unwrapping the wiring harness, starting with the coolant sensor and working backwards. I have the injector connections unwrapped in preparation for rerouting and new tape & conduit.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I would replace any plastic wire loom that shows any signs of deterioration. They will never get any easier to reach. Use only high temperature rated loom.
Nevada1906
volvolugnut wrote: 07 May 2022, 13:25 I would replace any plastic wire loom that shows any signs of deterioration. They will never get any easier to reach. Use only high temperature rated loom.
I agree.
From what I can see, the wiring itself looks solid. There don't seem to be any breaks in the insulation, the colors are all still pretty vibrant, the connector insulation is intact and smooth. The wiring's stiff from thermal cycling, but I'm going slow and careful with it. The conduit and electrical tape are pretty sooty and nasty, but I've actually got two separate harnesses to work with - the one that came with the engine from the junkyard, and one I bought separately.
Most likely, I'll replace all the conduit and rewrap it in fresh tape.
Nevada1906
Started laying out the wiring.
Nevada1906
A few updates.
I installed the spark plugs and coil packs.
Started running new wiring conduit:
Continued mapping out the reconfigured wiring harness:
Test fit some parts like the computer box base, the overflow tank, the engine's cosmetic covers & upper mount and if you look down by the radiator, the lower wiring guide:
Here're a few overall shots:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Getting closer!
Has thanked: 2197 times
Been thanked: 1851 times
This is looking incredible! I would suggest you may want to wrap the coil and VVC wires over the head to help protect from the heat. Even using the split corrugated cable cover would help. Cars came with this originally so I can only assume it was for this reason in the decade of decomposing wiring harnesses! You may have already done this as I saw in one picture a short piece in place.
