Engine run without oil...makes noise...can you identify?
VolvoDJ
Year and Model: 2006 XC70
Has thanked: 46 times
Been thanked: 4 times
Post by VolvoDJ »
Hello,
My wife ran her 2006 XC70 essentially without oil for...a while. I have no idea how long it was low, but it took 4 quarts to get it to register between the high and low marks on the dipstick. She is absolutely brutal on cars...has murdered two Volvos and a Subaru since I met her 20 years ago... :cry:
It's now making the noise in the attached linked video. I'm guessing a fried exhaust valve, but not so sure as I'm more familiar with the B230 engines than I am these modern marvels in the P2 generation. The noise is loudest on the back of the engine, right below the circular plug in the center of the video.
Any thoughts? Thank you in advance for your help.
https://youtu.be/hfaDtFOCCSI
1987 240GL
1994 940
1991 940T (24 Hours of Lemons entry)
2003 V70
2006 XC70 (MBW*)
2007 XC70
2008 V70 (MBW*)
2008 XC70 (MBW*)
*Murdered by wife :cry:
Been thanked: 472 times
Post by cn90 »
Main bearings gone south...
Has thanked: 1506 times
Been thanked: 3819 times
Main or rod bearing. It doesn’t really matter which, it’s a tear down
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
abscate wrote: 01 Jun 2022, 02:40 Main or rod bearing. It doesn’t really matter which, it’s a tear down
Engine swap would make more sense. T2 is plentiful and cheap.
Post by cn90 »
This underscores the importance of checking oil level every 1,000 or 1,500 miles in the 2.5T engines.
Simply bc these 2 5T engines consume ~ 1 qt every 1,500 miles or so.
Virtually all cars have oil PRESSURE sensors, some do not have oil LEVEL sensors.
Many BMW have oil LEVEL sensor, but the P2 cars do not.
vtl
Post by vtl »
B5452T4 has the oil level sensor.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
VolvoDJ wrote: 31 May 2022, 20:48 Hello,
My wife ran her 2006 XC70 essentially without oil for...a while....
Ouch.
Regular low knock knock knock at idle is usually main bearings. A higher pitched clatter as you rev it up is usually rod bearings.
But as Abscate said, it doesn’t matter.
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
maybe a tesla next.
Post by cn90 »
Nah,
By a horse, all you need is 1 HP...
How do horses drive in the rein? Are the Un- stable? They have seen on our Mane street , but not Herd.
