What non automotive projects and repairs are you doing?
Forum rules
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Re: What non automotive projects and repairs are you doing?
Post by gnalan »
:lol: :lol: :lol:
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
volvolugnut wrote: 04 Jun 2022, 18:59 No pet pandas, although that may solve my problem.
A next door neighbor planted the bamboo. It is native to some areas in the south. There are many varieties, but they are all very invasive. It crossed to our property and kept expanding. It grows from root runners and sends up new shoots in the spring. This type can get to 15-18 feet tall here and stalks at ground 2 inches in diameter.
I only want to get rid of it. I have written about it before in this thread (I think). It will die back with a freeze below -10 degrees, but we seldom get that here. Clearing it to the ground for several years will kill that area. Usual herbicides do not kill it.
Our new dog is doing great. The saddle backpack is helpful for behavior engineering and family walk in woods. Washing paws and a coat rinse afterward has accelerated becoming a pack -- ALL GOOD!
I'm finding my self immersed in quality of grass around our property, see this https://edustore.purdue.edu/epub/TURF-100-W21.pdf
Has thanked: 1505 times
Been thanked: 3817 times
Is puppy settling in and finding the right pack position?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
This attachment, what is it called? I need to buy several of these for summer plant irrigation projects.
Also -> Amazon link
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Kind of looks like this, but I didn't know that they worked rigid pipe.
https://sprinklersupplystore.com/produc ... oNEALw_wcB
1999 V70 GLT
gnalan
Post by gnalan »
matthew1 wrote: 11 Jun 2022, 17:31 This attachment, what is it called?
Looks like point source drip emitters.These look like the one in your pic.
(Above post beat me to it.)
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
matthew1 wrote: 11 Jun 2022, 17:31 This attachment, what is it called? I need to buy several of these for summer plant irrigation projects.
It is called an emitter or dripper. They just push into the drip tube with a barb on the dripper. They come in various flow rates and pressure ranges. Does your drip irrigation system have a pressure regulator at the water connection? The pressure may be important when you go to the big box store to buy them.
I used to sell drip irrigation systems for Christmas tree growers.
Next stage of my home outside renewal is replacing siding at the eves above the brick veneer. It was built in the 1970's with Masonite lap siding. It has weathered OK, but will be replaced with Smart Siding panels. Yesterday, I removed the first old section using a Sawsall. I have found I will need to shim the bottom out at each of the short studs to gain clearance to the brick. I DO NOT want to knock mortar loose if the panels contact the brick at the bottom when I nail on the panels.
Check that Masonite for asbestos content, especially if you smoke.
My research found no asbestos concerns for Masonite Hardboard siding. Other credible information would be appreciated.
