coolant leak??
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Re: coolant leak??
Post by chitownV »
The 3.2 uses the Euro blue coolant, known as G48 spec. Zerex G48, Zerex Euro, Peak Euro, are some of the types you can usually find at local stores.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
For where you live 50:50 Coolant to distilled water (unless you purchase coolant that is already 50:50)
Take a look at this blog
https://blog.fcpeuro.com/how-to-pick-th ... r-your-car
The G11 Glysantin G48 (HOAT, Silicates) (VW G11, Volvo, BMW, Mercedes) is an older technology.
I have upgraded my coolant systems to
Glysantin GG40 ("Si-OAT" - hybrid organic acid technology)(VW G13)
You can get if from VW or Audi just ask for G13 or you can get it from Pentosin --> Pentofrost E
The G11 isn't compatible with G12
The G11 is compatible with G12+
The G11 is compatible with G12++
The G11 is compatible with G13
Good luck
Paul
ylwgto
Year and Model: 2009 xc90 3.2 R
Has thanked: 9 times
Been thanked: 7 times
Post by ylwgto »
ordered the hose, o-ring and thermostat. eager to see if my thermostat is bad! will report back.
2009 XC90 3.2 R-Design 150K
ylwgto
Post by ylwgto »
Did this job today.
You were all right, the thermostat WAS broken...terrible design. The plastic end of the hose was also broken just as you all suggested it would be...it is amazing it did not just pop out from coolant pressure on the freeway.
Terrible job to replace the thermostat under the manifold, but got it done and it is all good now. thanks!
pgill
Post by pgill »
Well done!!!
The 3.2 is a really great engine but it needs care and attention.
Now that you have completed Letter A
Typical repairs for high mileage 3.2
A) Thermostat – replaced mine at 10 years (also replaced two coolant hoses)
Here is the complete list
https://www.freel2.com/forum/topic32504.html
I need to add the purge valve to the list of typical repairs (I know you replaced yours)
Good luck
Paul
ylwgto
Post by ylwgto »
Thanks. It is a great engine and, with care, so is the transmission unlike past aisin iterations.
I've done it all except for the serpentine belt, idler pulleys, water pump job...been putting that one off bigtime and may actually pay to have it done. I even decided not to do it when I replaced the AC compressor b/c it looks so awful :(
