'04 S60 - flex issues and middle exhaust
ionianp2
Year and Model: 2004 Volvo s60
Has thanked: 16 times
Been thanked: 10 times
Post by ionianp2 »
Hi Everyone,
Following an oil change I decided to take a peak and see what's going on. I've had a minor leak that has gotten worse over time.
I found out that my flex pipe is shot and the the flange from the middle exhaust to the cat is completely rotted out. The middle exhaust also is due for replacement.
My rear silencer is ok though. If I were to do a refresh I would need at minimum the middle exhaust (Starla 8684279 which unfortunately is back ordered) or the OEM and I need a new flexible. I saw Oragex's video on welding the flex pipe to the cat but I dont have any welding skills nor the space for that type of work.
Does anyone have good experience with walker or aftermarket catalytic converters (e.g. walker, etc) I may get the full assembly: flexible/cat and keep my old cat as a backup.
Also are there any good aftermarket stock exhausts besides starla? Otherwise I may have to bite the bullet and go with the OEM.
Also if anyone has a muffler shop they swear by in the Boston area, feel free to PM me.
I am all about using the original cat if possible but $1500 for the OEM assembly new is a bit steep.
Best Regards,
IonianP2
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Try Erie volvo or ebay for used OEM parts.
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
Around here (Toronto area) I can get a flex joint welded in for about $250 US including the part. I have a local exhaust guy that TIG welds really well. He is a big fan of patching factory exhaust systems rather than replacing them with aftermarket, which only lasts about 3 years on our salty roads.
2012 s60 t5
2006 XC70
2004 XC70
ionianp2
Post by ionianp2 »
Thank you for the input. I am also a fan of saving the original cat especially since it is working properly.
I did order a new middle OEM exhaust. No good decent aftermarket ones. It also seems that. The supply chain for some parts is out of whack.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
ionianp2 wrote: 25 Aug 2021, 05:28 Thank you for the input. I am also a fan of saving the original cat especially since it is working properly.
Did you end up removing the cat converter section and bring it to a welding shop to weld in a new piece of flex? Does one need to remove the prop shaft in order to get the cat section out of a 2.5T model ? Or is it able to clear it without too much headache.
04s60 2.4
04xc70 2.5t
ionianp2
Post by ionianp2 »
Sorry I didn't see this in time. I did end up having a shop welding a new flex pipe to the old cat. Have had it for a year now and it has been good so far. It's as quiet as it was when new.
jonesg
Post by jonesg »
ionianp2 wrote: 18 Jul 2022, 08:41 Sorry I didn't see this in time. I did end up having a shop welding a new flex pipe to the old cat. Have had it for a year now and it has been good so far. It's as quiet as it was when new.
what did you do about the flange joint after the cat.
ionianp2
Post by ionianp2 »
It was salvageable. Ended up getting new bolts and gasket.
Has thanked: 1613 times
Been thanked: 4077 times
In the US they have basically shut off the used cat market. You can get one by buying a whole car at auction, then parting it out to recover your cost but that’s a lot of time
Has thanked: 2215 times
Been thanked: 1853 times
Where do you think all the stolen cats are going too..................!
