Timing belt 2000 C70
cyanmauve
Year and Model: 2000 C70
Post by cyanmauve »
Hi all,
I have a 2000 C70 that I acquired in 2010 or so with about 125k miles.
The timing belt was last changed and replaced with a Gates belt at 121k miles per a sticker in the engine compartment.
Over the past ten years, I've put about 10k miles on the car.
Do I need to replace the timing belt again simply due to age? The engine is running well otherwise.
Thanks!
Has thanked: 1857 times
Been thanked: 1718 times
It is recommended at 10 years due to the belt deteriorating whether used or not. Just like tires there is a material lifespan for safe use.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
cyanmauve wrote: 26 Aug 2022, 09:39 Hi all,
Thanks!
I agree with Neil; it's not just the belt, the bearing in the idler and tensioner can both get stiff with age. Keep in mind the penalty for waiting a bit too long can be severe.
Take a hard look at the water pump as well, if it's still original replace it too, comfortable in the thought you will be good for another 10/100k.
Welcome to the tribe.
cyanmauve
Post by cyanmauve »
Thanks for the replies - that's what I figured the response would be.
Water pump replacement likely a good idea as well, as it's original to the car.
