Hi all,
I have a 2000 C70 that I acquired in 2010 or so with about 125k miles.
The timing belt was last changed and replaced with a Gates belt at 121k miles per a sticker in the engine compartment.
Over the past ten years, I've put about 10k miles on the car.
Do I need to replace the timing belt again simply due to age? The engine is running well otherwise.
Thanks!
Timing belt 2000 C70
- Has thanked: 1856 times
- Been thanked: 1717 times
It is recommended at 10 years due to the belt deteriorating whether used or not. Just like tires there is a material lifespan for safe use.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
I agree with Neil; it's not just the belt, the bearing in the idler and tensioner can both get stiff with age. Keep in mind the penalty for waiting a bit too long can be severe.cyanmauve wrote: ↑26 Aug 2022, 09:39 Hi all,
Thanks!
Take a hard look at the water pump as well, if it's still original replace it too, comfortable in the thought you will be good for another 10/100k.
Welcome to the tribe.
