How much to tighten worm gears? (Hose clamps, jubilee clamps, band clamps)
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Re: How much to tighten worm gears? (Hose clamps, jubilee clamps, band clamps)
Post by BlackBart »
Now THAT was entertaining and educational!
What about these good-looking Swedish ABBA singing clamps that the kids at ipd sell?
https://www.ipdusa.com/products/4769/Ho ... 032-113924
Has thanked: 1507 times
Been thanked: 3824 times
Take a chance on those??
If they break , you can hear the SOS
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
So isn't the coolant system on cars usually running around 16psi ?
I'll go ahead and chance it with clamps that can handle 500 - 1000psi. Just call me a man of danger... :twisted:
1999 V70 GLT
Has thanked: 1853 times
Been thanked: 1714 times
Wow what a lot of input for a fairly simple task, but I guess if you don't know you don't know! It is hard to explain how hard to tighten the clamp. I seldom have had issues on clamps being re-used on the original hose it was on. I have had a few with new rubber hoses as they get warm and 'relax' they have weeped a little requiring a 'nip up' to reseal them.
Volvo did have a torque somewhere I read a long time ago, maybe for the turbo hoses, but can't recall now. I do recall tightening them to the prescribed value, but then having to re-tighten as the hoses settled.
I don't mind either type of clamp. Most places I use oetikers are areas I don't plan to remove for a good long time. I have tools that allow perpendicular access as well as straight on. I think both tools were Lisle branded.
With the clamps I try to only use the ABA or Norma type, but I have had the crappy ones from Volvo and took them back!
BlackBart
Post by BlackBart »
scot850 wrote: 06 Sep 2022, 19:26 It is hard to explain how hard to tighten the clamp...
I crank them down until the band cuts into the hose, the screw slots cheese grater the rubber, and the hose buckles! ..and then another half turn! Just in case.
:lol: :lol:
TLDR
SCreenshots of leak test and tensile failure points
Screenshot 2025-10-01 at 08.17.13.png (150.46 KiB) Viewed 254 times
Screenshot 2025-10-01 at 08.16.35.png (147.01 KiB) Viewed 254 times
Screenshot 2025-10-01 at 08.13.25.png (168.58 KiB) Viewed 254 times
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
Now that is news you can use in these tough times.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
I have not seen that episode. I'll have to look for it. I've purchased several items after Project Farms evaluations.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
