The Great Debate is settled by the wiring diagram
The two fuel level senders in the saddle tank senders are in fact wired in series and thus provide a single, total resistance to the CDM which imparts the fuel gauge to indicate total fuel.
See how 6/33L and 6/33R are series wired and feed into A4 and A5 on the CDM
P80 1998 1999 2000 AWD Fuel gauge averaging (NO) or totalling(YES) ?
- Has thanked: 1500 times
- Been thanked: 3810 times
- Screen Shot 2022-09-22 at 10.33.13 AM.png (738.74 KiB) Viewed 986 times
- Screen Shot 2022-09-22 at 10.33.39 AM.png (965.88 KiB) Viewed 986 times
- Has thanked: 1836 times
- Been thanked: 1709 times
That is correct, unless one or other level sensor or wiring is bad!
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
That is correct. It also uses the left tank to keep the right tank full. The total resistance is the same as the FWD P80's, therefore each AWD sender is half of the FWD sender.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I wonder if this has anything to do with the 850OBD2 app having two fuel levels. They're not the same, one is usually higher. I've always assumed it had something to do with the fuel light, but I'm not really sire of that, as the difference changes. I've also noticed that neither goes as high as they used to, which makes me think my sender is starting to get wonky.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Maestrours
- Year and Model: 03/2000 V70 XC 2.4T
- Has thanked: 29 times
- Been thanked: 9 times
Hello,
Can someone please tell me what resistance correspond to what level ?
It seems that my fuel gauge is wrong (when empty it says aroynd 10 liters).
What should be the values at empty, half and full tank ?
Regards,
Cyril
Regards,
Cyril
