Ok, so I need a new fan.
How much do these run at a boneyard?
And....
If I am driving 50-70 mph, and watch the temp guage....no ac....
Can I drive it and keep the engine cool enough to get home? (30 miles)
I would shut her down at stop lights once I am on the city streets
Thanks
(On the side of the road now.....)
Big Al
1998 v70 GLT, main cooling fan froze up Topic is solved
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
And further inspection reveals that the fan spins one direction, but not the other.
This is when I try to push it by hand, engine off.
(I would disconnect the fan, and drive home, if the moving air will cool the vehicle enough)
Al
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
surfbug1
And.....while trying to "gently' push the fan in the opposite direction, it just fell off the
-fan motor shaft-
Hmmmmm
-fan motor shaft-
Hmmmmm
Ping me!
Ping me!
surfbug1
Turning 1800 rpm
Heater on full
55 mph
Guage heater temp indicator 3 o'clock position
15 miles to go
Eyes glued to temp guage
80 degrees ambient outside temp.
Any input would help tons!
Heater on full
55 mph
15 miles to go
Ping me!
Ping me!
surfbug1
46 mph
Sun is down....73 degrees ambient temp
Heater on full hot
Outside vent open.
Ac off ....duh
Driver heater vents closed
12 miles to go....
Needle at 3 o'clock steady
Heater on full hot
Outside vent open.
Ac off ....duh
12 miles to go....
Ping me!
Ping me!
surfbug1
35 mph
1500 rom
73 deg ambient
3 miles to go
Temp holding steady
1500 rom
73 deg ambient
3 miles to go
Temp holding steady
Ping me!
Ping me!
- Has thanked: 1501 times
- Been thanked: 3812 times
You will make it fine. The fan isn’t needed unless the AC is on or it’s brutally hot
surfbug1
Yup!
Got home ok.
Now, how much should I be paying for a boneyard fan, and any links on replacement / how difficult is this operation.
Al
Ping me!
Ping me!
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Oh i see your issue is a broken fan my issue was not the fan itself it was the coolant sensor. Had to replace that not the fan or the fan motor.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
- 1142 Views
- 785 Views
Last post by shiloh51933
