1998 v70 GLT, main cooling fan froze up Topic is solved
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
Ok, so I need a new fan.
How much do these run at a boneyard?
And....
If I am driving 50-70 mph, and watch the temp guage....no ac....
Can I drive it and keep the engine cool enough to get home? (30 miles)
I would shut her down at stop lights once I am on the city streets
Thanks
(On the side of the road now.....)
Big Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
surfbug1
Post by surfbug1 »
And further inspection reveals that the fan spins one direction, but not the other.
This is when I try to push it by hand, engine off.
(I would disconnect the fan, and drive home, if the moving air will cool the vehicle enough)
Al
Ping me!
:D
surfbug1
Post by surfbug1 »
And.....while trying to "gently' push the fan in the opposite direction, it just fell off the
-fan motor shaft-
Hmmmmm
Ping me!
:D
surfbug1
Post by surfbug1 »
Turning 1800 rpm
Heater on full
55 mph
Guage heater temp indicator 3 o'clock position
15 miles to go
Eyes glued to temp guage
80 degrees ambient outside temp.
Any input would help tons!
Ping me!
:D
surfbug1
Post by surfbug1 »
46 mph
Sun is down....73 degrees ambient temp
Heater on full hot
Outside vent open.
Ac off ....duh
Driver heater vents closed
12 miles to go....
Needle at 3 o'clock steady
Ping me!
:D
surfbug1
Post by surfbug1 »
35 mph
1500 rom
73 deg ambient
3 miles to go
Temp holding steady
Ping me!
:D
Has thanked: 1611 times
Been thanked: 4075 times
You will make it fine. The fan isn’t needed unless the AC is on or it’s brutally hot
surfbug1
Post by surfbug1 »
abscate wrote: 06 Oct 2022, 18:00 You will make it fine. The fan isn’t needed unless the AC is on or it’s brutally hot
Yup!
Got home ok.
Now, how much should I be paying for a boneyard fan, and any links on replacement / how difficult is this operation.
Al
Ping me!
:D
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Oh i see your issue is a broken fan my issue was not the fan itself it was the coolant sensor. Had to replace that not the fan or the fan motor.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
