Coolant on manual shift cable
99TurboBrick
Year and Model: 1999 S70 T5 Manual
Has thanked: 35 times
Been thanked: 13 times
Post by 99TurboBrick »
I had a heater core leak for the last 1.5 years that I just discovered. It's on me, as I had not tightened the T25 screw enough to attached the core to the pipes.
So, on top of coolant soaked carpet and underlayment, my worn manual shifter cable sheathing allowed coolant in, and it traversed most of the length of the cable, even through the firewall.
Anything I can do short of replacing the cable? Would soaking the heck out of it with something like WD-40 clean off this coolant? Coolant being very corrosive, I feel this should be addressed. Thanks.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Coolant shouldn't be corrosive. Preventing corrosion is part of it's job in the cooling system. I'd guess any crustiness is mostly dried coolant. If the cable is still functionally well, I'd leave it.... unless it would be easier to replace now rather than later.
Edit: Maybe the anti-corrosive properties require a sealed system?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
