coolant leak
beenagoodcar
Year and Model: 2006 V70
coolant leak
Post by beenagoodcar »
Coolant leak on a Volvo V70 2.4 turbo. Every 20 to 2hours of driving I need a cup or two of coolant. After turning the car off and waiting 15 or so minuites the overflow tank still has pressure. There is no wet areas on the driver's side or passengers side floor. the oil level is good and no sign of anti-freeze mixed. How can I have a leak if it maintains pressure?
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
If it isn't a blown headgasket, maybe the heater core is leaking? That..is a pain in the ar*e to fix, because the whole dashboard needs to come out. Speaking from experience with other car brands, sometimes when attempting to remove the whole heater unit behind the dash, breaks it.
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
Heater core would mean wet driver's footwell, but the foam is so thick and porous it would take months to notice. Might be worth removing the carpet completely and inspecting.
My two coolant leaks were the radiator itself, and the thermostat on both my cars. You don't see any cruddy buildup near any fittings ?
04s60 2.4
04xc70 2.5t
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Feels like I’m repeating myself but buy a coolant pressurizer. They’re cheap, HF has a kit that works fine. Coolant leaks can be very hard to find without that type of tool. Could of course be a warped head also.
BMW 540i 2002
S70 Base 2000
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
beenagoodcar wrote: 28 Nov 2022, 13:51 Coolant leak on a Volvo V70 2.4 turbo. Every 20 to 2hours of driving I need a cup or two of coolant. After turning the car off and waiting 15 or so minuites the overflow tank still has pressure. There is no wet areas on the driver's side or passengers side floor. the oil level is good and no sign of anti-freeze mixed. How can I have a leak if it maintains pressure?
15 minutes isn't long enough, try it after it sits overnite and is stone cold.
If you still get pressure, its the head gasket.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 44 times
Post by 93SCMax »
Mileage on car?
When was the last time the water pump was changed?
I'd recommend you take off the timing belt plastic cover and look for coolant residue around the water pump and on the plastic cover.
Good luck.
beenagoodcar
93SCMax wrote: 29 Nov 2022, 05:48 Mileage on car?
Good luck.
ill check that tomorrow .Thank you
beenagoodcar
kallekula wrote: 28 Nov 2022, 23:36 Feels like I’m repeating myself but buy a coolant pressurizer. They’re cheap, HF has a kit that works fine. Coolant leaks can be very hard to find without that type of tool. Could of course be a warped head also.
Ill try removing the timeing belt cover then the coolant pressurizer. Thank yuou
beenagoodcar
br0dy519 wrote: 28 Nov 2022, 15:29 Heater core would mean wet driver's footwell, but the foam is so thick and porous it would take months to notice. Might be worth removing the carpet completely and inspecting.
Did the rad and pressure tank parts only cost $ 160 can
beenagoodcar
prwood wrote Should come to Canada to work on car. Its -15 F today, good chance of snow and ill be taking my timing belt cover off in the carport
